Projector Mini-Shootout Thread - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 3578Likes
Old 12-29-2013, 02:47 PM
Deja Vu's Avatar
Quoted: 932 Post(s)
Liked: 938
Originally Posted by blee0120 View Post
Since you have two rooms, have you thought about a passive 3D setup?
Yes, and I had everything ready to go -- 2 Optoma boxes, one for left eye and one for right eye, two projectors meticulously aligned, filters for two projectors and passive glasses. My Oppo let me down -- I thought it would output 3D at the same time from each of its two HDMI outs. Apparently it won't. I've upgraded my HTPC and may give it another try.
Deja Vu is offline
Old 12-29-2013, 02:59 PM
Deja Vu's Avatar
Quoted: 932 Post(s)
Liked: 938
Originally Posted by tigerfan33 View Post
With the brightness of the HP screen for 3D I sometimes forget to take the glasses off if I check out something in 2D -- about 5 minutes in I suddenly remember that I'm not watching 3D any longer and I don't need the glasses -- duh!
Deja Vu is offline
Old 12-29-2013, 03:12 PM
blee0120's Avatar
Quoted: 445 Post(s)
Liked: 237
What two projectors did you have? I would love to do it if I could figure out how it would work. I would do two DP LED projectors. DC4 .95 would look amazing I bet. They are going around used kind of cheap for the performance
blee0120 is offline
Old 12-29-2013, 03:24 PM
westmd's Avatar
Quoted: 772 Post(s)
Liked: 260
Originally Posted by curttard View Post
What are the best 3D glasses and emitter for a JVC 4810? Please tell me it's some cheap brand...
Wrote that already in another thread. I bought the ones from CurtPalme (Bitcauldron I think) and am very happy with them!
westmd is offline
Old 12-29-2013, 05:11 PM
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
I was looking at the Curt Palme ones, good to hear. I forgot to mention I am interested in RF only.
curttard is offline
Old 12-29-2013, 05:20 PM
Deja Vu's Avatar
Quoted: 932 Post(s)
Liked: 938
I'm not sure about the emitter, but I think the cheap Samsung 3D RF glasses work with the newer JVC projectors. I like those glasses -- very light weight and inexpensive.
Try this thread at post #746.
http://www.avsforum.com/t/1424180/jvc-dla-rs48-dla-x55-projector-with-3d-rf-glasses-and-e-shift-cedia-2012/720
Deja Vu is offline
Old 12-29-2013, 05:29 PM
Deja Vu's Avatar
Quoted: 932 Post(s)
Liked: 938
I piggy backed my Epson 7500 onto my Epson 9500, attached the filters and was ready to go, but for …..
The problem with using two projectors will be convergence. I was able to get really good convergence, but it wasn't as good as a single chip DLP. Also the filters plus the passive glasses will significantly cut light output to the screen. I haven't got my hopes up that the image will be very bright -- even with the HP screen.
Deja Vu is offline
Old 12-29-2013, 08:47 PM
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Thanks. Is there any reason to get the JVC emitter rather than one of the more inexpensive ones? For example, the Optoma one?
edit: Answered my own question, the Samsung glasses are not compatible with the Optoma emitter. I'm not sure what third-party emitter works with the Samsungs.
So the question is, would I be better off spending $90 for JVC emitter and then $40 for a couple pairs of Samsung glasses, or spending the same $130 on the Estar emitter and two pairs of Estar glasses?
curttard is offline
Old 12-29-2013, 10:18 PM - Thread Starter
zombie10k's Avatar
Quoted: 2866 Post(s)
Liked: 2878
RS57 calibration first look
Projector has 15 hours, all low lamp so far. This is impressive considering the PITA the RS55 is to calibrate. The RS4810/X55 saturation did not track this well, so this is definitely an improvement.
Picture mode -> User 1
Color profile -> Custom 1 -> CM = on, magenta brightness -2
Color temp -> Custom 1 / 6500
Gain red -23, Gain green -22
Offset red -1, offset green -2
Gamma -> Custom 1 - 2.2, no other changes IRIS = OFF
Greyscale -
Gamma -
Chromaticity / Luminance -
Saturation tracking -
zombie10k is offline
Old 12-29-2013, 11:24 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Nice. Were you unable to turn down blue luminance?
Elix is offline
Old 12-30-2013, 01:01 AM
Qualunquemente's Avatar
Quoted: 52 Post(s)
@Zombie
Only 23 cd/mq on a Da-Lite HP 2.8 ????????
PS: Can you measure the Adobe-rgb native gamut please ?
Qualunquemente is offline
Old 12-30-2013, 02:20 AM
Manni01's Avatar
Quoted: 2876 Post(s)
Liked: 2487
Originally Posted by Qualunquemente View Post
@Zombie
Manni01 is offline
Old 12-30-2013, 03:06 AM
Quoted: 52 Post(s)
Originally Posted by Manni01 View Post
Sorry but we didn't use much Ftl in Europe.
23,6 ftl are 81 cd/m2 but on a an HP 142" 2.8 gain screen (I have own one in the past and it is more like a 3.0 gain in reality).
That means about 470 lumens in my calculations.
Old 12-30-2013, 03:33 AM
Quoted: 52 Post(s)
Hey wait !
I read 23,38 cd/m2 under WHITE eek.gif
Can't be that low on a gain 3.0 screen even if it's a 142" and lamp is low ...
Old 12-30-2013, 07:55 AM
Deja Vu's Avatar
Quoted: 932 Post(s)
Liked: 938
Go check out the Samsung glasses at Best Buy to see if you like them. If you do and you need more than two then it's more economical to buy the JVC emitter and the Samsung glasses (if you buy four pairs for example).
Deja Vu is offline
Old 12-30-2013, 09:24 AM
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Yeah, but on the other hand, someone in another thread said the Estars got rid of all the ghosting for him on his JVC (which sounds odd). I think I have to make a new thread for this rather than derailing this one any further. Thanks!
curttard is offline
Old 12-30-2013, 12:07 PM
wse
wse's Avatar
Quoted: 2043 Post(s)
Liked: 752
We are going to test his bias, when I send him my VW600 to compare to his VW1000. smile.gif
How do they compare?
wse is offline
Old 12-30-2013, 01:17 PM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
RonF is offline
Old 12-30-2013, 02:53 PM
Mike Garrett's Avatar
Quoted: 5698 Post(s)
Liked: 3650
Well enough that I think I am going to be very happy with my 600 when Zombie10k gets done reviewing it. smile.gif
mjgarrett100@gmail.com
Mike Garrett is offline
Old 12-30-2013, 02:56 PM
Mr. Hatcher's Avatar
Quoted: 216 Post(s)
Liked: 137
Jason, have you used, or thought about using this lag tester method?
Does anyone else have any experience with this solution?
Respectfully,
Mr. Hatcher
Mr. Hatcher's hybrid-HT
Mr. Hatcher is offline
Old 12-30-2013, 03:09 PM - Thread Starter
zombie10k's Avatar
Liked: 2878
that looks pretty cool as long as it's reliable. It's a pain to break out my heavy 20" CRT each time to run these tests. Price seems affordable, I would buy one and test it if they can ship to the US.
Old 12-30-2013, 03:40 PM
Manni01's Avatar
Liked: 2487
They seem to accept U.S. dollars as a currency, so it's a good sign smile.gif
Manni01 is offline
Old 12-30-2013, 03:46 PM
Quoted: 216 Post(s)
Liked: 137
I believe they ship to the US. I see it's sold out at the moment so you may have to send him an email...not sure if it's built-to-order or not. They do seem "affordable" though, and much easier than the CRT alternative. Displaylag.com uses one for lag testing and I've found others using them as well. Seems like the overall fastest/easiest solution available.
Here's some info from DisplayLag.
Respectfully,
Mr. Hatcher
Old 12-30-2013, 04:31 PM
WestCDA's Avatar
Quoted: 66 Post(s)
Liked: 78
Doesn't appear to be a problem for them - this is from their shipping&returns page. I've ordered a number of items from the UK, and delivery has been very good - generally the Royal Mail does a better job with delivery times than our Canada Post ... smile.gif
International Delivery Times
Europe •Royal Mail Airmail, and International Signed for - 3-5 Working Days
•Other Courier - 1-3 Working Days
Rest of the World •Royal Mail Airmail, and International Signed for - 4-5 Working Days*
•Other Courier - 2-5 Working Days
WestCDA is offline
Old 12-30-2013, 09:49 PM - Thread Starter
zombie10k's Avatar
Liked: 2878
The Sony 4K projectors look like a bargain compared to this.
Samsung just released a 110" UHD TV - yours for the low price of $150,000
that screen looks small compared to my 142"...
malis0931 likes this.
Old 12-30-2013, 09:55 PM
Liked: 3650
Do the Samsung SSG-5100GB glasses work with the VW600ES?
Old 12-30-2013, 10:02 PM - Thread Starter
zombie10k's Avatar
Liked: 2878
Old 12-30-2013, 10:04 PM
Liked: 3650
Mike, several folks mentioned the Samsung glasses + Xpand 105 would work. Here is a recent discussion:
http://www.avsforum.com/t/1492355/official-sony-vpl-vw500es-vw600es-4k-projector-thread/900
I knew the 105's worked and thought the Samsung would also, but did not know for sure. Not a big 3D guy, but thinking about getting enough pairs, so that the whole family can watch 3D. Thanks for the link.
Old 12-30-2013, 11:00 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Of course you can watch with the lights on.
millerwill is offline
Old 12-30-2013, 11:13 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
smokarz is offline
Benq W7000 Home Projection System , Jvc Dla Rs55 Bundle , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector , Sony Vpl Hw50es 3d Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Panasonic Ptae8000u Hd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc8000dbl Dlp 3d Home Theater Projector With Spare Lamp 1300 Ansi 12 6 Lbs , Darbeevision Darblet Hdmi Video Processor , Epson 5020ub Powerlite Home Cinema 3d Front Projector
