Projector Mini-Shootout Thread 2013-2014 - Page 289 - AVS Forum
post #8641 of 9117 Old 06-20-2014, 07:55 PM
StevenC56's Avatar
Quoted: 17 Post(s)
Liked: 31
My screen is a 105" wide 2.35 Seymour AV Center Stage XD retractable. Anybody know it it's polarized or not? I still have to get a 3D Blu-Ray player as well. Thinking the Oppo 103D?
StevenC56 is offline
post #8642 of 9117 Old 06-21-2014, 02:37 AM
d.j.'s Avatar
Quoted: 12 Post(s)
I have 4 pair that just arrived today, I'll check them out on the various projectors I have here.
Sent from my SCH-I545 using Tapatalk
Z10K
Do they Work with the 1100 ?
( here I Cant ordrer Them, they Will not ship to my country )
Dj
d.j. is offline
post #8643 of 9117 Old 06-21-2014, 06:51 AM - Thread Starter
zombie10k's Avatar
Quoted: 199 Post(s)
Liked: 327
Originally Posted by d.j. View Post
Z10K
Dj
DJ, hi they do work with the 1100 but it required the RJ45 -> 3 PIN Sony cable. A fellow member on the HW55 forum posted a way to directly wire the RF adapter into the Sony's RJ45 connection.
link ->> http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/1499280-owners-thread-sony-hw55es-40.html#post24780714
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
zombie10k is online now
post #8644 of 9117 Old 06-21-2014, 08:05 AM - Thread Starter
zombie10k's Avatar
Quoted: 199 Post(s)
Liked: 327
I had a chance to look at the Xpand 'Mitsubishi' glasses last night vs the RF105. From everything I can tell, they appear to be identical. The included RF transmitter also appears to be the same as the RF-X1. which.... makes that a heck of a bargain.
I tested the transmitter on the VW1100 and the JVC RS55 which isn't exactly a great performer in 3D. I was surprised how well they worked on the RS55. There is still some x-talk in tough scenes but in general it looked better than I remember with the JVC glasses / transmitter. I was watching Man of Steel 3D and didn't see any obvious x-talk.
Including in the photo are also the Epson RF glasses and the Sony RF glasses that were released for the VW500/600. I think the color tint on the Xpand glasses are more neutral than the Sony RF glasses. The Epson glasses worked perfect.
This RF transmitter is a great solution for adding various RF glasses to a 3D projector. It's a shame the Optoma/Monster glasses are using a proprietary RF setup, it would be nice to use all the glasses with 1 transmitter. I'll have to try the Xpand RF and Optoma RF transmitters at the same time using this cable I made a few years ago. it should work perfect.
post #8645 of 9117 Old 06-21-2014, 09:12 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
Thanks to you I made the dual cable a few years ago when I had the RS45. I tested these Xpand glasses on the RS4910 with both the JVC and Xpand emitter.
I also tried Dimensional Optics Value glasses with the Xpand emitter and they work great. My old Monster glasses work with their special emitter but I like the Xpand ones much more. I just have to adjust the arms with a little heat. I also tried these Mitsubshi Xpand glasses with the JVC RF emitter and they work but I did notice some ghosting. The included Xpand emitter works much better. We really appreciated you reviews and comments. If anyone is interested in getting these glasses at this amazing bargain price of $18.99 I would suggest acting fast since they are closeouts and we have no idea of how many are still available.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
If you get a Sears link instead of Amazon link search directly. There is a Redirect going around called Vig-Link which takes you to other sites for money.
rwestley is offline
post #8646 of 9117 Old 06-21-2014, 02:35 PM
AVS Club Gold
cal87's Avatar
Well, for $19 I figured these were worth a try with my Lumis 3D-S.
I can get them to work with DirecTV 3D, but not with 3D Blu-ray.
I am guessing 144Hz is not working.
The manual that came with the glasses/emitter states: "Refresh: 96Hz to 144Hz"
I am wondering if it is the emitter, the glasses, or both.
Also does not work with the Xpand IR emitter which comes with the Lumis, but that is not a shock.
The glasses also work with the Samsung LCD I have in my office, so I will at least have some use for them.
Anyone get these Mitsubishi glasses working at 144Hz? Any thoughts if a different emitter would work?
cal87 is offline
post #8647 of 9117 Old 06-21-2014, 05:09 PM
Joseph Clark's Avatar
Quoted: 68 Post(s)
Liked: 139
The easy way to test if your screen maintains polarization is to rotate the glasses. If the brightness doesn't change, you're good to go with just about any type of active glasses. For instance, my HP doesn't maintain any polarization at all, so rotating the glasses has no effect. When I had the JVC RS40/45, I could use the JVC or the Xpand 103 glasses. The JVC glasses had the opposite polarization, but it didn't make any difference.
krichter1 likes this.
Joe Clark
Joseph Clark is online now
post #8648 of 9117 Old 06-21-2014, 06:59 PM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
These glasses will only work with ACTIVE 3D systems that use the recent universal standard. They will not work with DLP Link
I am wondering if there is a setting in your Blu-Ray player that might be off. What Blu-Ray player are you using. I would also check to be sure you have the projector set for frame packing (FP) that could be it. If your projector has a vesa port they should work.
rwestley is offline
post #8649 of 9117 Old 06-21-2014, 07:19 PM
AVS Club Gold
cal87's Avatar
The Sim2 is active. Mine came with the earlier Xpand X103 IR version. The newer models use the Xpand X105 RF models. As I stated, the Mitsubishi glasses and emitter work for DirecTV 3D, which I am assuming is some multiple of 60Hz. 3D Blu-ray works as triple flash 144Hz, which does not work with this particular glasses/emitter pair. By the way, I also have the Optoma/Bit Cauldron kit which works fine with the Sim2.
cal87 is offline
post #8650 of 9117 Old 06-21-2014, 07:29 PM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
It seems that the Sim2 uses triple flash in a way that is unique to that projector. Something single chip DLP projectors can't do. That could be the reason why these glasses will not work for you. I am also sure that most of the other universal 3D glasses will also not work with your projector. The BitCauldron/Optoma glasses have a different type of emitter as you know.
Sorry that they will not work with the Sim 2. You are probably right about 144KZ issues. They will, however, work for the vast majority of users of JVC, Sony (with special cable) Epson, and other brand projectors.
rwestley is offline
post #8651 of 9117 Old 06-21-2014, 07:49 PM
AVS Club Gold
cal87's Avatar
The glasses that Sim2 are now using are labeled X105-S1. The Mitsubishi ones are labeled X105-M1.
Question is, is there any real difference between the glasses?
I am willing to try another emitter, if I can find one for a reasonable price.
cal87 is offline
post #8652 of 9117 Old 06-22-2014, 03:41 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
Zombie thinks that the glasses are the same with just different markings. I think you are correct that it has something to do with the 3 flash 144K which seems unique to SIM 2 projectors.
What Blu-Ray player are you using? Did you try to adjust the resolution set it manually for F.P (Frame Packing)
rwestley is offline
post #8653 of 9117 Old 06-22-2014, 08:32 AM
AVS Club Gold
cal87's Avatar
I agree that these glasses are probably the same. I would think the same applies to the emitters too.
I am using the Oppo BDP-93 feeding a Lumagen Radiance. Standard frame sequential output, I believe. I doubt the Sim2 is doing anything unusual. The original Sim2 kit is the older X103 generation IR glasses/emitter that works fine. You would think any of the newer X105 kits would work fine.
cal87 is offline
post #8654 of 9117 Old 06-22-2014, 01:20 PM
d.j.'s Avatar
Quoted: 12 Post(s)
Smile
Thanks, Zoombie10K
Is this the glasses / RF transmitter/ converter cable to get for the 1100, for the best Picture quality and comfort, if I want to go deeper into the 3D universe IYO ?
If so, maybe then I can get one in US, to buy them for me and ship them to me :-)
dj
d.j. is offline
post #8655 of 9117 Old 06-22-2014, 02:09 PM
AVS Club Gold
cal87's Avatar
I got the word from Xpand directly.
Seems that the Mitsubishi glasses should work at 144Hz, but the included emitter will not.
They offered to sell me the newer AD025-RF-X1 emitter directly.
Still a good deal on the glasses. Cheaper with the included emitter than glasses alone. If it all works out, I should have a bunch of extra emitters.
cal87 is offline
post #8656 of 9117 Old 06-23-2014, 02:14 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
If any of you are still looking for the Expand glasses and emitter bargain I suggest that you act fast since Amazon has only a few left in stock. Doubt if we will see this deal again.
http://www.amazon.com/gp/product/B00...=vglnk-c333-20
rwestley is offline
post #8657 of 9117 Old 06-23-2014, 07:09 AM
StevenC56's Avatar
Quoted: 17 Post(s)
Liked: 31
Walt's TV is selling them on eBay as well. The have 163 pairs available, and have sold 60 already.
post #8658 of 9117 Old 06-23-2014, 07:50 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
Great that there are more available
rwestley is offline
post #8659 of 9117 Old 06-23-2014, 08:02 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
I just noticed that some Amazon links I posted have been changed to Sears links on AVS I thought it was spyware but it has happened on tablet and phone if the new owner of AVS is doing this and getting paid for it members should complain since it might be illegal and it is certainly deceptive. The 3d glasses link is an example of a redirect
rwestley is offline
post #8660 of 9117 Old 06-23-2014, 08:24 AM
stanger89's Avatar
Quoted: 124 Post(s)
Liked: 144
They go to amazon for me.
See what an anamorphoscopic lens can do,
stanger89 is offline
post #8661 of 9117 Old 06-23-2014, 11:35 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
I found out that it is a redirect called VigLink someone is getting paid for the redirect. I am trying to get ride of it.
Amazon has only a few pairs left but you can buy them from the same seller on Ebay for only $1 more. You can also make an offer for less.
http://www.ebay.com/itm/Xpand-EX105B...item416f4e4b37
rwestley is offline
post #8662 of 9117 Old 06-25-2014, 11:22 PM
StevenC56's Avatar
Quoted: 17 Post(s)
Liked: 31
I've got 8 pairs of the Xpand glasses from Amazon now. If only I had a 3D Blu-Ray player too!
post #8663 of 9117 Old 06-26-2014, 02:54 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
Time to get an Oppo 103D or 105D Amazon will also have more glasses on July 3rd.
rwestley is offline
post #8664 of 9117 Old 06-26-2014, 06:52 AM
StevenC56's Avatar
Quoted: 17 Post(s)
Liked: 31
A bit off topic, but I'm thinking the 103D. I have a question posted in the Blu-Ray forum about hookup with my non-3D legacy Yamaha RX-Z11 receiver. I was hoping to run the pass-thru output from my receiver to the input on the 103D. Has anybody tried that?
I wonder if Zombie has had time to test these Xpand glasses&emitter with a JVC projector?
post #8665 of 9117 Old 06-26-2014, 07:53 AM - Thread Starter
zombie10k's Avatar
Quoted: 199 Post(s)
Liked: 327
Hi, I tested the glasses / RF emitter with my RS55 and X35(RS46), it works great, plug and play. What a bargain!!
post #8666 of 9117 Old 06-26-2014, 06:12 PM
nohjy's Avatar
Quoted: 14 Post(s)
Liked: 26
zombie,
I have an RS55. will these work directly or will I need your conversion cable as shown above? Also are they really better with hosting than the X103? I am very happy with my RS55, but I wish the ghosting in 3D was reduced.
nohjy is offline
post #8667 of 9117 Old 06-27-2014, 06:39 AM
mishari84's Avatar
Quoted: 22 Post(s)
Which is better overall, Xpand or Optoma/Estar?
mishari84 is online now
post #8668 of 9117 Old 06-27-2014, 07:48 AM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
Originally Posted by nohjy View Post
zombie,
All you will have to do is plug the included emitter into the VESA port on the JVC RS55 and you will be good to go after you link the glasses. Great buy at under $20. Amazon will have them back in stock on July 3rd.
rwestley is offline
post #8669 of 9117 Old 06-27-2014, 09:58 AM
nohjy's Avatar
Quoted: 14 Post(s)
Liked: 26
Is there a way that I can use both emitters at the same time, so that I can use my existing X103s and these simultaneously or will the new emitter work with the x103s?
nohjy is offline
post #8670 of 9117 Old 06-27-2014, 07:16 PM
rwestley's Avatar
Quoted: 58 Post(s)
Liked: 67
Zombie posted info on how to make a Y VESA connector to use two different emitters. You might want to ask him to post the info again. I am not sure if the X103's use IR or RF. If they are RF you could try them with the included Xpand 105 emitter. If they are IR you could make a Y Vesa cable and use the original JVC IR transmitter and the new Xpand emitter. There is a picture of the Y connector on page 289.
rwestley is offline
Benq W7000 Home Projection System , Jvc Dla Rs55 Bundle , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector , Sony Vpl Hw50es 3d Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Panasonic Ptae8000u Hd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc8000dbl Dlp 3d Home Theater Projector With Spare Lamp 1300 Ansi 12 6 Lbs , Darbeevision Darblet Hdmi Video Processor , Epson 5020ub Powerlite Home Cinema 3d Front Projector
Gear in this thread - V11h421020 by PriceGrabber.com
