Projector Mini-Shootout Thread - Page 514 - AVS Forum | Home Theater Discussions And Reviews
 4187Likes
post #15391 of 17650 Old 11-03-2016, 07:37 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Originally Posted by jqmn View Post
I don't know if it is your DSP. Maybe it is the MKII not muting the low-end before power off. That is, I get a power on thud with the MKII if my subs are on when I turn on the MKII and one on off if I don't shut down my subs first.
It's definitely the DSP model of the iNuke. There's entire threads dedicated to modding them to eliminate the power down thud that results from cutting power to the amp rather than using the switch on the front.
jkasanic is offline
post #15392 of 17650 Old 11-03-2016, 07:47 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Originally Posted by Mike Garrett View Post
The Panamax 5400 is 15 amp. If you are running a 6000DSP and two XLS1500, when pushed, those three together easily exceed 15 amps.
Yeah, I even have it plugged into a 20 amp dedicated circuit AND I'm running 5 XLS1500's using 9 channels in addition to the iNuke. I rarely watch anything over -7 and it has never tripped. In fact, I ran dual 20A circuits for this purpose but haven't had a need to use both. Transient peaks likely exceed 15A but nothing is ever sustained long enough to be an issue in my experience. @Stoked21 turned me onto the Panamax and he's a EE...go figure!
jkasanic is offline
post #15393 of 17650 Old 11-03-2016, 08:41 AM
Mike Garrett's Avatar
Quoted: 6600 Post(s)
Liked: 4287
I must be hitting higher transient peaks in my system, because I had to add circuits. I have 3- Inukes, 3-crowns, 1-Brhringer EPH, 1-Nady and 1-Rane. I have six 20 amp circuits now. Before I added the last two 20 amp circuits, I was tripping 20 amp breakers with some of the amps paired on a breaker.
Added
I do sometimes play movies at reference and have big subs, pushing into the single digits.
Corrected the number of circuits for my equipment. Have six, not five.
mjgarrett100@gmail.com
Mike Garrett is online now
post #15394 of 17650 Old 11-03-2016, 08:51 AM - Thread Starter
zombie10k's Avatar
Quoted: 3389 Post(s)
Liked: 3471
this is going to keep me busy for a while.
I could easily hide 4 of these in the room if I wrap them in velvet.
deadpool approved
Tom Bley and cardoski like this.
zombie10k is offline
post #15395 of 17650 Old 11-03-2016, 08:58 AM
Liked: 4287
deadpool approved
Which driver is that? (looks like Ultimax 18)
What size box?
What are you going to power it with?
Are you going to add any boost down low?
PS. You just opened up Pandora's box.
mbw23air likes this.
post #15396 of 17650 Old 11-03-2016, 11:19 AM - Thread Starter
zombie10k's Avatar
Liked: 3471
What size box?
it's the Ultimax 18" + PE 4cf sealed box, very nice kit with the fit / finish. Just have to glue it all together soon.
I'm going to pick up the inuke 6000 DSP
i've been avoiding this rabbit hole for years, now that the video is locked in for another year + full velvet blackout + 7200WA + ATMOS ceiling speakers it's time to shake the house.
The DIY threads are impressive, major bang for the buck vs. ID or commercial.
mbw23air and Dave Vaughn like this.
post #15397 of 17650 Old 11-03-2016, 12:15 PM
Liked: 4287
It is a big cost savings if you do not count your labor, tools purchased, do not have to put a good finish on the box and can place a pro amp in a remote location. The first sub or two that you build will most likely not save you much over an ID sub company, just including the added tools needed. From then on it gets cheaper. People often get into DIY for the ability to get larger boxes and or special form factors. One of my subs is 8CF, after driver and bracing are taken into account and weighs 220lbs. Imagine what the cost for shipping would be on a prebuilt sub of that size and weight. Form factor plays a big part in DIY also. My LCR's have 18's in them, but I needed the completed speaker to fit into a space only 12" deep.
Anyway, for your room, I would recommend four of those subs. Then your HT will move to a different level.
Congrats on the sub. Looking forward to your eye opening revelation.
zombie10k likes this.
post #15398 of 17650 Old 11-03-2016, 12:30 PM
Point Source
beastaudio's Avatar
Quoted: 4005 Post(s)
Liked: 3308
4 of those will definitely be the hookup. You are going to love it. I will say, with all the measurement gear you have for video, you'll still want to get yourself either a UMIK-1 (preferably calibrated from cross-spectrum labs) and install REW on a laptop, or buy the omnimic system for a couple hundo. OmniMic definitely costs, more, but the ease of being up and running and measuring in less than 5 minutes is quite nice. REW can be problematic on setup until you get the hang of it.
FS: BossoBass A-14K amplifier
beastaudio is offline
post #15399 of 17650 Old 11-03-2016, 06:19 PM
mbw23air's Avatar
Quoted: 166 Post(s)
Liked: 155
He's in big trouble now.
zombie10k and Mike Garrett like this.
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
post #15400 of 17650 Old 11-04-2016, 07:32 AM
Stoked21's Avatar
Quoted: 1525 Post(s)
Liked: 927
I must be hitting higher transient peaks in my system, because I had to add circuits. I have 3- Inukes, 3-crowns, 1-Brhringer EPH, 1-Nady and 1-Rane. I have five 20 amp circuits now. Before I added the last two 20 amp circuits, I was tripping 20 amp breakers with some of the amps paired on a breaker.
Added
I run 9 xls1500 (actually only 7 active) plus a single channel on inuke 3000dsp. Jvc rs400 and everything on same circuit. I only watch at reference....never tripped the breaker. Knock on wood. Front two jtr caps are on a different circuit.
Rack (7.3.4 20,000W): Marantz AV7702mk2, Crown XLS1500 (9), iNuke3000DSP, miniDSP DDRC-88A (3), Samsung UHD HDR: UBD-K8500, Panamax M5400-PM, AppleTV Gen4
LCR: JTR 228HT (3) Surrounds: JTR S8 & S8LP (4) Atmos: JTR Slant8LP (4), RBH IC (2) Subs: JTR Captivator 1400 (2), Dayton UM18-22 NF PJ: JVC RS400 Screen: Seymour UF 130"W 2.35 Misc: SimpleControl, Philips Hue(15 light), Echo Control, Synology DS216play
STOKED Home Theater Build
Stoked21 is offline
post #15401 of 17650 Old 11-04-2016, 11:19 AM
Liked: 4287
An XLS 1502 can draw 250 watts. An Inuke 6,000 draws 620 watts (looked at mine), so a 3,000 should draw 310. That means a max wattage of 2,060 could be drawn. A 15 amp circuit can handle 1,800 watts. So you could be exceeding the circuit. If you are pushing your system to reference levels, I am surprised you are not tripping breakers.
Four of my amps draw a lot more wattage, around 1,200 each, so I can't pair them together. That means four circuits just for them. That is why I have six 20 amp circuits.
post #15402 of 17650 Old 11-04-2016, 06:56 PM - Thread Starter
zombie10k's Avatar
Liked: 3471
JVC AUTOCAL / Spyder 5
The RS600 is right at 300 hours and wanted to run through a cal since it's been a little while. I originally had the Spyder 4 and wasn't happy with the quality of this specific copy. for gamma it was fine but color was off a bit.
I decided to pick up a Spyder 5 and see how it matches up against my calibrated ID3. I got very lucky with this one, it's excellent. I know manni01 has the opposite experience so there must be some variances between the different copies.
JVC autocal is a great value-add for those willing to take the time to learn and a minimal investment. Just being able to get a quality gamma curve is worth the benefit alone. It also nailed 10-20 IRE Greyscale which has been bugging me for a little while and didn't want to use the mini 3D to correct it.
alebonau likes this.
post #15403 of 17650 Old 11-05-2016, 08:48 AM - Thread Starter
zombie10k's Avatar
Liked: 3471
3am gluing and clamping, what did I get myself into..
to keep me awake, cold brew ice coffee + Black Sabbath Gathered in their Masses (2013) Bluray. High recommend for BS fans.
tcramer likes this.
post #15404 of 17650 Old 11-11-2016, 11:51 AM
Mr. Hatcher's Avatar
Quoted: 216 Post(s)
Liked: 137
Ok, it's official. I accepted an offer on my house today so I'll be moving into an apartment in about a month or so.
I'll be selling off most of my theater gear (you can see what all I have if you follow the link to my build, in my sig) so if anyone is interested just shoot me a PM and I'll let you know if the item you're interested in, is for sale. I have all the original packaging for everything. The screen will be the hardest to ship as it's rigid, so maybe that will be easier to sell locally.
If I don't get any hits from anyone within a week, I'll list it all separately in the Classifieds. I just want to give the people that know me a little, first dibs.
Please don't respond to this post as I don't want to clutter Zombie's thread with non-related content.
Respectfully,
Mr. Hatcher
Mr. Hatcher's hybrid-HT
Mr. Hatcher is offline
post #15405 of 17650 Old 11-13-2016, 12:54 AM
latexii's Avatar
Quoted: 14 Post(s)
Why im reading about subwoofers in this thread ??? wtf
latexii is offline
post #15406 of 17650 Old 11-13-2016, 08:30 AM - Thread Starter
zombie10k's Avatar
Liked: 3471
Originally Posted by latexii View Post
Have anyone put up any comparisons between Epson 6040 & JVC RS400/500 ? Or maybe Epson is still too freshh.. Just need to make up my mind between RS400 / 6040 ..
a little distraction while waiting for new projectors.
did you decide between the 6040 and RS400/500? there has been a lot of discussion on this in the various threads and here as well.
One of the current topics in the 5040/6040 threads is HDR gaming issues with the current consoles, the 10.2GB HDMI setup is not helping here.
Next year the 5050/6050 is likely going to have FI in UHD mode and 18GB chipset. Similar to the updates of the 5010->5020->5030, there has to be a feature update path for the next 2 years for this chassis.
also some rumors that JVC may have a gaming mode in their next release (not the 35K model) so that is something to watch out for in the next few months. If that's the case, it will make choosing between the Epson and JVC a little easier for gamers.
post #15407 of 17650 Old 11-13-2016, 09:29 PM
latexii's Avatar
Quoted: 14 Post(s)
Actually i did made a decide, wasnt hard cause i got my brand new JVC X5000 (rs400) in 3100€ (3350$) and Epson was 3000€.. pretty f*cked up prices here in Fin atm.
latexii is offline
post #15408 of 17650 Old 11-16-2016, 08:04 AM
R Harkness's Avatar
Quoted: 2050 Post(s)
Liked: 1750
I received my copy of The Force Awakens 3D Blu-Ray yesterday and had to watch it last night (got 1/2 way through before bedtime).
Wow, what a tremendous experience on the RS600! The 3D on this movie is fantastic and for me adds hugely to the viewing experience. Star Wars is about entering another world, and 3D brings that world alive. I've watched TFA in 2D numerous times, but in 3D every shot seems a new revelation. I'd seen TFA in 3D in the theater and thought the 3D was excellent then, though the theater didn't have very good contrast. But 3D with the RS600's contrast and I have to say the 3D version will be my go-to for watching this film.
zombie10k, roxiedog13 and kohe321 like this.
R Harkness is offline
post #15409 of 17650 Old 11-16-2016, 08:48 AM - Thread Starter
zombie10k's Avatar
Liked: 3471
+1 I thought the 3D added a ton of immersive feeling to the film, this was a remarkable 3D conversion. They have it down to a science now.
I saw this at 2 premiere IMAX theaters (KOP, PA and Orlando) and the mid-low APL scenes looked much better on the RS600/HP combo vs the theater.
I'm looking forward to seeing Rogue One, we'll be talking about that 3D BD in 1 year from now.
#3D_is_not_dead
Toe, alebonau and Seegs108 like this.
post #15410 of 17650 Old 11-16-2016, 12:53 PM
R Harkness's Avatar
Liked: 1750
#3D_is_not_dead
Are you using clear motion drive on 3D titles? It defaults on still on my RS600 and I usually leave it on as I find 3D can benefit from some added smoothing of motion. Though last night I turned it off for Star Wars to leave it more film-like. I might turn it on for more of the frantic battle scenes though.
post #15411 of 17650 Old 11-16-2016, 06:55 PM
Toe
Toe's Avatar
Quoted: 1804 Post(s)
Liked: 2078
#3D_is_not_dead
Great to hear the 3d is so good on TFA. I have this on tap for Fri night. Excellent audio/bass in this film as well (I rented the 2d blu when it first hit)!
krichter1 and zombie10k like this.
Toe is online now
post #15412 of 17650 Old 11-17-2016, 11:46 AM - Thread Starter
zombie10k's Avatar
Liked: 3471
it's interesting you mentioned this. I didn't even realize until 1/2 way through the movie that it was on and thought it looked great. I never use it on 2D content but I think it behaves differently with 3D, it's more subtle.
This is the company that did the conversion, they have quite a catalog of 3D titles including Titanic and the Marvel movies.
http://www.stereodllc.com/projects/
post #15413 of 17650 Old 11-17-2016, 12:20 PM
stanger89's Avatar
Quoted: 3308 Post(s)
Liked: 1769
It does seem to help with 3D, and I hate it on 2D. Interestingly, the moment I would switch the glasses from to 2D (no other changes), all the sudden the dreaded SOE would rear it's head. Switch the glasses back to 3D mode, and it would be back to fine again.
stanger89 is online now
post #15414 of 17650 Old 11-19-2016, 07:00 AM - Thread Starter
zombie10k's Avatar
Liked: 3471
Epson 5040/6040 HDMI Compatability chart posted by Epson support
Epson posted an FAQ on signal input capability, they must be getting a lot of emails based on the conversations in the owners thread with capability for different devices.
The info about the Samsung UB8500 output HDR @ 4:4:4 8 bit is not correct.
it's almost a guarantee they will add the full bandwidth chipset for the 5050 next year.
post #15415 of 17650 Old 11-19-2016, 05:39 PM
R Harkness's Avatar
Liked: 1750
Finished watching The Force Awakens last night. This might be my favorite 3D movie so far.
Then I watched some of The Art Of Flight in 3D (just got that copy not long ago) and made the image more IMAX-like in size immersion (for my room) and wow, what an amazing 3D image! Felt like I was up there riding the peaks.
Watching some of the Hockey game tonight - sports have never looked as effortlessly brilliant and vivid.
The RS600 continues to strut it's stuff, even after almost a year, I still enjoy how the bar has been raised in my home theater.
mbw23air, krichter1 and zombie10k like this.
post #15416 of 17650 Old 11-20-2016, 10:56 AM
krichter1's Avatar
Quoted: 2007 Post(s)
Liked: 2254
Well?? . . . (to hear how these sounded in your room; especially an Atmos/DTS:X LFE heavy track)
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #15417 of 17650 Old 11-20-2016, 12:48 PM - Thread Starter
zombie10k's Avatar
Liked: 3471
I ran into 1 problem. 2 of these are going to turn into 4 faster than I thought. Much like high native contrast - 18" subs are very addicting..!!
i'm making a build thread in the DIY section, i'll post a link to it. impressive so far with just 1, second goes online tonight.
mbw23air, krichter1, Toe and 2 others like this.
post #15418 of 17650 Old 11-20-2016, 04:09 PM
blee0120's Avatar
Quoted: 514 Post(s)
Liked: 269
Can't wait to follow your new thread. Building my Dual 18s in January
blee0120 is offline
post #15419 of 17650 Old 11-20-2016, 11:37 PM
coderguy's Avatar
Quoted: 496 Post(s)
Liked: 344
Those subs should be illegal within city limits.
http://whyihatepeople.com/forum/viewtopic.php?f=2&t=537
Access HERE from this thread
coderguy is offline
post #15420 of 17650 Old 11-21-2016, 07:29 AM
Liked: 4287
Four 18's are a good way to go. I have one sub, nearfield that is especially suited for going low.
18" RE-XXX in 8CF sealed box:http://reaudio.com/products/woofers_xxx.php
Benq W7000 Home Projection System , Jvc Dla Rs55 Bundle , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector , Sony Vpl Hw50es 3d Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Panasonic Ptae8000u Hd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc8000dbl Dlp 3d Home Theater Projector With Spare Lamp 1300 Ansi 12 6 Lbs , Darbeevision Darblet Hdmi Video Processor , Epson 5020ub Powerlite Home Cinema 3d Front Projector
