Projector Mini-Shootout Thread - Page 609 - AVS Forum | Home Theater Discussions And Reviews
 4439Likes
post #18241 of 18255 Old 10-21-2017, 07:24 AM - Thread Starter
zombie10k's Avatar
Quoted: 3881 Post(s)
Liked: 3962
@Archibald1 - I was testing a new cable configuration (all monoprice cables) last night and wanted to make sure I was passing full 18GB through my AVR. This is the path:
Panasonic UB900 - 6ft - Denon 7200 - 25ft - HDfury - 3ft - RS600. good news no issues getting max bandwidth in this setup, those cables are excellent and inexpensive.
I took a look at Billy Lynn's in 4K/60 HDR chapter 6, there is no banding at all in this movie in this setup.
The Grobi.tv folks showed this from the current Sony's in their YT video. There is a lot of back and froth in the other threads, is there any confirmation 100% that a specific configuration cannot reproduce this on the 6xx or 3xx series?
zombie10k is online now
post #18242 of 18255 Old 10-21-2017, 07:33 AM
Quoted: 107 Post(s)
Liked: 36
Nice.
Those top two pictures, look proper great. Smooth and with superior colour and realism! Hey, they should use it in their marketing!
That is what I was led to believe I would see from my 550 in HDR 60hz.
Archibald1 is online now
post #18243 of 18255 Old 10-21-2017, 07:44 AM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
Originally Posted by jorgebetancourt View Post
Well GOTG2 is a different monster I would think.. They have the biggest budget out there to do things right and I bet rendering the cgi at 8k made a difference on how the film looked... Even thought it looked amazing and I have nothing bad to say about it, Lucy looked a bit sharper and I think its because its being put out at 4k.. Guardians was brought down to 2k then upscaled to 4k..
Whatever it is I'm cutting down with the blue rays unless its truly 4k..
I'm not sure I even finished watching GOTG 1, something about it just did not sit right with me.
CTHD Sword of Destiny was ok, not nearly as terrible as the reviews suggest, but also not great. You have to give props to the Chinese for the incredible costumes and color in some of these movies, no-one can do color quite like these recent Martial Arts movies.
There was another martial arts one I saw recently which was 100x better than CTHD, but heck if I can remember the name as I wasn't paying attention to the name.
Access HERE from this thread
coderguy is offline
post #18244 of 18255 Old 10-21-2017, 11:28 AM
Wizziwig's Avatar
Quoted: 1436 Post(s)
Liked: 1005
Correct - using the HD Fury Linker to send 4K HDR BT.2020 from UB900 directly into the RS4910.
Chad and I looked 4K scaled down to 1080p (from Linker) vs e-shift on a R.Masciola 4K text pattern - hands down e-shift was sharper. Didn't get a chance to test it from the player scaling it down though...will have to see if that's an option available on the Linker to test.
Interesting. So I guess you've turned the RS4910 into an HDR projector.
Do you know what video format is actually being sent by the UB900 and what is actually received by the RS4910? Is the 3840x2160@24fps using 4:2:2 or 4:4:4 sampling and at what bit-depth - 8-bit, 10-bit, or 12-bit at each stop of your display chain? I'm guessing it's 8-bit by the time it makes it to the projector due to HDMI 1.4 spec limitations.
Wizziwig is offline
post #18245 of 18255 Old 10-21-2017, 01:57 PM
blee0120's Avatar
Quoted: 656 Post(s)
Liked: 333
I didn't know it was possible to turn a non HDR display into one.
blee0120 is offline
post #18246 of 18255 Old 10-21-2017, 03:03 PM
DavidHir's Avatar
Quoted: 2053 Post(s)
Liked: 1677
The JVC showed 8 bit in the Deep Color information screen.
DavidHir is offline
post #18247 of 18255 Old 10-21-2017, 04:51 PM
Wizziwig's Avatar
Liked: 1005
I think there are some 10-bit gradient test patterns floating around somewhere on the forum. I wonder if those are fully resolved without color banding.
Just found these for example.
Wizziwig is offline
post #18248 of 18255 Old 10-21-2017, 05:10 PM
Wizziwig's Avatar
Liked: 1005
That will depend on your definition of "HDR display". The dimmest display officially supported by the UHD HDR spec needs at least 540 nits. By that definition, no front projector is an "HDR display".
It's all approximation on front projectors which leaves room for interpretation even on SDR-only models that have enough lumens, gamma, and gamut calibration flexibility to provide some usable results.
Wizziwig is offline
post #18249 of 18255 Old 10-21-2017, 05:49 PM
blee0120's Avatar
Quoted: 656 Post(s)
Liked: 333
However, HDR can look great on the JVC projectors, you don't need as many in the right set up. But if using the Arves tool it seem possible. I would love to do a comparison to the current HDR generation.
blee0120 is offline
post #18250 of 18255 Old Yesterday, 07:28 AM
DavidHir's Avatar
Liked: 1677
It's really all about tone mapping for any display/projector. As Kris Deering pointed out, there really is not even any such thing as "SDR conversion". JVC is the only projector manufacturer that I am aware of which allows for the custom gamma curves with the Arve tool so that you can get potentially good tone mapping for HDR embedded content. But yes, the more lumens the better. Even on my RS4910, if I had more lumens I would definitely benefit more like the newer JVC models do that put out a lot more calibrated lumens. Of course, it all also depends on your room, screen size, gain, etc. Someone with a 180" 1.0 gain screen in an "okay" treated room is going to be in a much more difficult situation compared to someone with a 120" screen in a black pit room.
DavidHir is offline
post #18251 of 18255 Old Yesterday, 12:46 PM
blee0120's Avatar
Quoted: 656 Post(s)
Liked: 333
I'm sure if you can get close to 30ftL with the 49, it should perform very similar to the current models. I would have probably did the same had i known.
blee0120 is offline
post #18252 of 18255 Old Yesterday, 06:17 PM
stanger89's Avatar
Quoted: 3701 Post(s)
Liked: 2056
There's really nothing physical special/different about an "HDR" display, they use the same panels and basic physical components and technology as SDR displays. What's different is how they interpret the input signal, and since you can define arbitrary curves with JVCs, it's "easy" to calibrate them. Folks have actually done it the same thing (basically) with the some Epson machines, and Lumagen's Intensity Mapping does the same thing too.
stanger89 is online now
post #18253 of 18255 Old Yesterday, 06:32 PM
blee0120's Avatar
Quoted: 656 Post(s)
Liked: 333
I wonder how my DPI CINE 100 will look with HDR compared to the cheaper pixel shifting DLPs. Since my DPI can reach WCG, I'm hoping that there will be a device that can help.
blee0120 is offline
post #18254 of 18255 Old Yesterday, 11:18 PM
mbw23air's Avatar
Quoted: 199 Post(s)
Liked: 170
Im thinking you should just sell it to me and not worry about it.
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
post #18255 of 18255 Old Today, 04:37 AM
stanger89's Avatar
Liked: 2056
Probably quite a bit better considering you should have 2-3x the contrast and similar calibrated brightness.
And a Lumagen can help
Benq W7000 Home Projection System , Jvc Dla Rs55 Bundle , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector , Sony Vpl Hw50es 3d Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Panasonic Ptae8000u Hd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc8000dbl Dlp 3d Home Theater Projector With Spare Lamp 1300 Ansi 12 6 Lbs , Darbeevision Darblet Hdmi Video Processor , Epson 5020ub Powerlite Home Cinema 3d Front Projector
