Sony LCOS panel degradation? 5 yrs, constant use - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #121 of 133 Old 05-05-2015, 01:35 PM
Mike Garrett's Avatar
Quoted: 6709 Post(s)
Liked: 4399
Originally Posted by kucharsk View Post
What is considered "typical" projector life?
For example, if I purchased a projector, it would replace my main TV, and it accumulates around 220 hours of usage per month.
I also recently purchased an open box plasma with almost 8000 hours of use on it because it looks perfect with no sign of wear or other issue and carries its original one year warranty; from the posts here it appears doing that with a projector would mean it was effectively half dead.
The OP'er had around 28,000 hours on his projector. Most people do not put 20 hours a week on a projector. 220 a month is high usage. I don't know that you would get 5 trouble free years out of a projector with that amount of usage. You might, but then you might not.
mjgarrett100@gmail.com
Mike Garrett is online now
post #122 of 133 Old 05-05-2015, 03:32 PM
kucharsk's Avatar
Quoted: 1420 Post(s)
Liked: 772
Thanks, Mike - I'll stick with panels for now until/unless home projectors get more reliable.
kucharsk is offline
post #123 of 133 Old 05-05-2015, 03:45 PM
Seegs108's Avatar
Quoted: 4970 Post(s)
Liked: 2487
An LED DLP projector will do what you want. It will last for 30,000+ hours with no obvious signs of image degradation. That's roughly 8.5 years of continuous 24 hour a day use. Anything LCD based like projectors from Epson, JVC and Sony won't last anywhere near this long.
Seegs108 is offline
post #124 of 133 Old 05-05-2015, 09:04 PM
kucharsk's Avatar
Liked: 772
Anything but three chip DLP doesn't work for me - I can see the rainbow effect the minute I walk into the room; I even notice it on LED stage lighting.
kucharsk is offline
post #125 of 133 Old 05-06-2015, 04:19 PM
Seegs108's Avatar
Liked: 2487
If you're seeing it with stage lighting then what you're seeing isn't color separation artifacts. RBE is caused by sequential color and if you see a similar effect from solid state (aka always on) then it's some other phenomenon. I've read about others seeing a similar artifact even on other display devices.
Seegs108 is offline
post #126 of 133 Old 05-06-2015, 06:10 PM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 31
I'm curious as how you know this as fact?
Knd is offline
post #127 of 133 Old 05-06-2015, 07:01 PM
Seegs108's Avatar
Liked: 2487
It's the only solution that's rated for anywhere near the amount of use for what he's looking to do. DLP has been demonstrated in excess of 100,000 operating hours (more than 1 trillion mirror cycles). And the Phatlight PT120 LEDs that are commonly used in most of these higher end DLP projectors are rated with a half-life of 30000 hours, that is they reduce in lumen output linearly to half at 30000 hours. So given that the end user receives a unit that doesn't have lemon parts and is using the projector properly, ie does not put in overheating, high humidity, or irregular power conditions or whatever else is stipulated by the user manual, there's no reason not to expect it to last that long.
Please reference this TI white paper as a reference to DLP DMD longevity and the LED manufacturer's website for rated lifetime.
Seegs108 is offline
post #128 of 133 Old 05-06-2015, 07:19 PM
Knd
Knd's Avatar
Quoted: 111 Post(s)
Liked: 31
So I guess they don't offer a warranty nor need to.
Knd is offline
post #129 of 133 Old 05-06-2015, 07:54 PM
Seegs108's Avatar
Liked: 2487
I'm not saying every projector is 100% full-proof. Of course they'll need to offer a warranty. Like I said, there are parts that fail prematurely (lemon parts) and if the end user gets a unit that has a problem obviously it will need to be fixed. How often do you hear of a DMD that failed? DLP projectors are some of the most reliable projectors out there. A lot more so than LCD-variant projectors. With DLP projectors, it's almost always the DMD control board that fails, not the DMD, due to long term high temperature conditions. LEDs run cooler which in turn means the internal chassis temperature will be lower, which in turn helps control boards keep their longevity.
Seegs108 is offline
post #130 of 133 Old 01-17-2016, 10:19 PM
mpyw's Avatar
Quoted: 67 Post(s)
Liked: 27
Sony HT projector SUCKS!!
Claim the lamp can last 3-4000 hours, but before the lamp failed, the optical block lost a lot of its contrast and the colors are all wrong, red become pink in wide color 1, red become orange in wide color 2, and wide color 3 the red is too saturated!
and they dare to quote me a repair cost of $3,100 to replace the optical block of the HW30 after just 600 hours!!
To be or NOT to be......YOU are WHO you ARE
mpyw is offline
post #131 of 133 Old 01-17-2016, 10:35 PM
coderguy's Avatar
Quoted: 496 Post(s)
Liked: 345
I know of DLP projectors that have been severely beat up and have over 15,000 hours on them, and are still running to the exact same spec as when they were brand new. Consumer DLP projectors can easily last 50,000+ hours, average is probably 15k to 25k, but 50k many could hit, we just never do. I also know of school and govt use, DLP projectors are far far more reliable than LCD. The inorganic vs. organic thing only helped a little tiny bit, not nearly as much as the MFR's wish you to believe.
All that said, I have not noticed any panel degradation on a JVC RS-45 at 1500 hours, but there could be some. For reliability, you always buy DLP. Thing is many projectors are getting almost to the price of throw-away (at least for schools)...
Knd likes this.
Access HERE from this thread
coderguy is offline
post #132 of 133 Old 01-18-2016, 03:48 AM
kucharsk's Avatar
Liked: 772
I still wonder if Sony's cinema projectors have this issue; I can't imagine so as most AMCs are still using the initial Sonys they got when they went digital (Sony paid for a large part of the upgrade cost; I don't know if you remember the "Sony 4K" trailer that used to play before most movies.)
kucharsk is offline
post #133 of 133 Old 01-18-2016, 04:57 AM
Seegs108's Avatar
Liked: 2487
Yes, see here. It also effects the commercial 4K units in theaters from what I've been told. These units run daily for hours at a time and for some reason using them more lessens the degradation more.
Seegs108 is offline
