Sony VPL-HW50ES Focus Nonuniformity - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 67 Old 01-10-2013, 11:26 PM - Thread Starter
sarangiman's Avatar
Originally Posted by durack View Post
OK, couldn't resist so I played with it a bit more, just out of curiosity (yeah, watching test pattern instead of movies like I should).
Interestingly, if you go into options and decrease the aperture of the lens, the unfocused corner becomes more and more focused, at the very end the picture is obviously quite darker but the focus is near perfect.
Anyone who knows optics care to comment?
Yes, by closing the aperture, you are increasing the depth of focus (depth of field on a camera). Basically you are limiting the light rays that are leaving the projector to only the ones that do not have steep exit angles from the projector (hence using more of the center of the lens surface than the outer portions). Very oblique light rays that would otherwise travel through the outer edges of your lens are now being blocked by the aperture. Therefore, certain (outer) portions of your lens aren't being used as muchn for image-forming light. It's possible that those portions of your lens have defects; what is also possible is that your lens has a high degree of spherical aberration. The latter is an aberration that results in the outer portions of your lens having a different effective focal length compared to the center; hence, it's like there's a range of focal planes created by your lens. By stopping down the lens, you're limiting the depth of this range of focal planes (in the ideal scenario, your focal plane would have infinitesimally small depth, where you'd place your screen... but this is impossible... you can't keep closing the aperture at will because at one point it'll get so small that diffraction will soften your image). As a lens maker you're trying to create an infinite series of prisms by grinding the surface of the glass so that, for example, all light rays from infinity, which can be approximated as being parallel, entering the lens from any point along its surface, converge to a single point. That requires a very evenly curved surface where parallel light rays normal to the surface of the lens entering the center don't get bent at all, but where rays entering the outer edges of the lens get bent the most. (and at every spot in between center to outer edge, the bending angles should progress evenly from 0 to whatever the final bend angle at the outer edge is for parallel rays; poor grinding or surface imperfections will muck this up). Furthermore, multiple elements can be used in a lens to control spherical aberration. So your final image depends upon a number of these factors. But all you need to know is that by stopping down you're limiting the use of outer edges (or 'rings') of the lens as well as decreasing the effects of spherical aberration.
Here's a schematic that shows the different points at which rays from the same point being imaged are focused, based on where the rays entered the lens (projection is kind of the opposite of this, where you're taking the light from one focal plane -- the chip -- and focusing it on an outer focal plane -- the screen), from Wikipedia:
Ideally you'd want all those light rays converging to a single point. But at least by putting an aperture behind the lens, you cut out the outer oblique light rays, limiting your points of focus (for various light rays) to a smaller range. Remember: all those light rays that make it through the lens/aperture are image-forming light. So if some of them focus at a different plane, then those rays are serving to soften your image (b/c past the point at which they focus, those light rays get larger and larger... technically speaking: their circles of confusion get larger, and they blur/spread out whatever image detail they were carrying across neighboring pixels, causing a drop in MTF). Your cost, of course, is light... hence you increase the exposure on the camera (shutter speed), or go to high power on your projector and/or get a higher gain screen.
We see this problem all the time in photography. By stopping down, however, less of the image forming light passes through the outer edges of the lens surface. That doesn't mean *all* light passing through the outer edges of the lens are rejected; many of those still make it through and are image-forming. However, the ratio of those rays vs. rays passing through the center of the lens drops as you close the aperture, hence you get a sharper image.
Note: don't confuse this explanation with why a corner is more out of focus than the center; that's another story...
P.S. Kudos to you for playing around with test images smile.gif Music to my ears, haha.
sarangiman is offline
post #62 of 67 Old 01-11-2013, 04:20 PM - Thread Starter
sarangiman's Avatar
FYI I see the same thing, durack. Going to 'Auto Limited', which never allows the iris to open fully, immediately makes focus uniformity much better on my screen.
Kind of sucks, b/c it means that as the lamp ages and you open up the iris, I'm going to get less focus uniformity.
I guess that should be added to the focus uniformity check: check the NEC pattern with the iris fully open to see worst possible focus uniformity of your lens.
post #63 of 67 Old 01-14-2013, 12:15 PM
Gagorian's Avatar
I've also attached pictures of the two Sony HW50ES projectors I've had. I had the buzzing issue on my original projector so I was shipped a 2nd one. The 2nd one still had the buzz and to top off a worse focus, so I'm not happy with the new one. These are just quick snapshots, so they aren't nearly the quality of your images. Both projectors are in Auto Limited mode. I'm also using a HP screen with a mount right behind the couch so I wasn't able to take a picture without having the camera in view. The screen is square, flat and level, the lens (and my photographic skills) are just causing some geometric issues smile.gif
Sony HW50ES #1 projector focus (slightly bad focus on the center and 2 columns on both sides)
Sony HW50ES #2 (aka replacement unit) projector focus (center focus is ok on this one but 4 columns to the left is off and 3 columns to the right)
I can't see the bad center focus on the original during movie content, but the worse left side focus on the 2nd unit can be seen on subtitles.
Gagorian is offline
post #64 of 67 Old 02-24-2013, 07:29 AM
Kjelt's Avatar
Hi my projector flicker is now almost gone, only seeing it about twice per week (that it is obvious) so it is probably still there but much better then it was in the beginning so I am suspecting the lamp.
I hope it will be gone totally in another 100 hours or so. Anyway it is something I now can live with, as you said in one of your earlier posts if you really start looking...... smile.gif
Kjelt is offline
post #65 of 67 Old 02-27-2013, 05:37 PM - Thread Starter
sarangiman's Avatar
Interesting Kjelt. Thanks for your report. How many lamp hours do you have on there?
I'm on hour 260 of my lamp. I still notice it from time to time, though.
If it is the lamp, it could also have to do with the heat/how long the lamp has been on. The longer it's on the hotter it'll likely be, which can affect electrical arcing. And if that's the source of the flicker, the flicker might diminish after you've had the projector on for a long time (or by running it in high lamp).
But I still find it suspicious that, to my eye, the frequency of the flicker appears to be the same frequency of flicker evident during 3D Blu-Ray viewing (48Hz). That makes me think it's the lamp pulsing/modulation circuitry being 'leaky' in 2D. But that's a total guess/shot in the dark; I need to measure the frequency of the flicker with a high fps camera...
post #66 of 67 Old 12-18-2014, 04:30 PM
Liked: 1
Hi Kjelt,
I have the same problem with a new vpl-hw40es.
Did you found a solution, or did the problem go away after use?
BurtB is offline
post #67 of 67 Old 12-07-2015, 05:07 AM
Kjelt's Avatar
Originally Posted by BurtB View Post
Hi Kjelt,
Sorry haven't been here in awhile.
Only solution for me that works is to run in high lamp mode.
Never had flicker in that mode, it is the standard operating way for a lightbulb (nominal lampcurrent), my best guess is that the issue is in the lampdriver in low lamp mode.
Kjelt is offline
Sony Vpl Hw50es 3d Projector
