JVC RS2 would Epson 5020 be upgrade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-04-2012, 08:03 PM - Thread Starter
mhollida's Avatar
I have a JVC RS2 in bat cave light controlled room. Screen is Jamestown 120" 1.0 gain. I like the JVC and this was my first projector purchased used from Ebay.
Now I am thinking of "upgrading" to new projector.
The Epson 5020 has peaked my interest.
Would this be an upgrade over my RS2?
> 3D is not priority but nice adder
> Would 2D picture be better?
> Black levels comparable?
> overall pic quality better with newer Epson?
I know the Epson would be MUCH brighter and my RS2 on the 120" can look a little washed at times.
Just wondering if it would be worth the new purchase.
Mark
mhollida is offline
post #2 of 3 Old 11-07-2012, 08:00 AM - Thread Starter
mhollida's Avatar
Anybody care to give opinion?
mhollida is offline
post #3 of 3 Old 11-07-2012, 08:42 AM
xb1032's Avatar
Liked: 26
From all I've heard the black levels will be a slight downgrade. I'm in a similar boat and I am wanting to replace my Rs45 with either the Sony HW50, VW95, or the RS46.
I had an RS2 just last year and I can tell you that the RS45 has better motion, is brighter, and has a sharper pic. The Epson is likely going to surpass the RS2 in these areas as well. The black levels on the RS45 are about the same as the RS2 if you clamp the manual iris down all the way with the exception being the RS45 has bright corners. Even with the iris clamped down though the pic is still brighter than the RS2. Personally I was very happy with this move. The biggest question with the change to the Epson is how much will you lose when it comes to black levels.
Plus if you don't mind frame interpolation then this alone makes a substantial upgrade for motion (if you like this sort of look which I personally like).
FYI, if you think the RS46 might be of any interest I would get on the pre-order list. Be aware that the pre-order price in the ball park of the 5020 pricing.
Check out the shoot out thread for more details.
xb1032 is offline
