SONY VPL-VW500ES SXRD 4K Projector : IFA BERLIN 2013 - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 482 Old 09-13-2013, 11:54 AM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
Official Release Date and MSRP in Canada?
See Profile
scanido is offline
post #302 of 482 Old 09-13-2013, 01:48 PM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
I have no idea maybe rickavmaniac knows ?
In the meantime, here is another opinion about the VW500ES (in English this time for mark wink.gif)
http://www.avforums.com/forums/avforums-news-notices/1812163-ifa-2013-first-look-sony-vpl-vw500-4k-ultra-hd-projector.html
kraine is offline
post #303 of 482 Old 09-13-2013, 01:57 PM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
13500. End of October. That is confirmed. Of course a better deal can be had. But u know that. smile.gif
conan48 is offline
post #304 of 482 Old 09-13-2013, 02:04 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Note the 2.83 long throw instead of the long throw much shorter I questioned above. 2.83 would be consistent with the zoom ratio of over 2.0 (I forget the official zoom ratio spec) published by Sony.
aso there are errors in the report. The contrast of the 500ES is not higher than the 1000ES. It is lower. Also reading between the lines of the report, the 500ES and 1000ES are not DCI compliant. The color space of the 1000ES with the switchable filter would be the DCI spec and the resolution at 4096 x 2160 is consistent. But the bit length is not. you can not hook up a DCI server either.
mark haflich is offline
post #305 of 482 Old 09-13-2013, 02:30 PM
RickAVManiac's Avatar
Quoted: 247 Post(s)
Liked: 214
Conan is right, end of october and 13.5k MSRP. And the price is negotiable biggrin.gif
RickAVManiac is online now
post #306 of 482 Old 09-13-2013, 04:27 PM
RapalloAV's Avatar
Quoted: 1622 Post(s)
Liked: 472
Sounds very promising from Steves review!
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #307 of 482 Old 09-14-2013, 01:31 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
kraine is offline
post #308 of 482 Old 09-14-2013, 01:36 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
And the people wich are going to visit CEDIA will exactly knows what I'm talking about. smile.gif (2 weeks left)
kraine is offline
post #309 of 482 Old 09-14-2013, 02:07 AM
Liked: 1012
Actually 12 more days. And Kraine, even I, a master of translating German and French into English, and because of the translation sometimes have no clue as to what you are talking about. smile.gif
post #310 of 482 Old 09-14-2013, 02:45 AM - Thread Starter
kraine's Avatar
Quoted: 238 Post(s)
Liked: 307
kraine is offline
post #311 of 482 Old 09-14-2013, 06:05 AM
Liked: 1012
post #312 of 482 Old 09-14-2013, 06:15 AM
Ron Jones's Avatar
Quoted: 916 Post(s)
Liked: 934
If it does sell for 13,500 in Canada then that suggests a US price of around $12,999, but I guess we won't know for certain until CEDIA (26 Sept. Sony press conference).
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #313 of 482 Old 09-14-2013, 06:19 AM
Liked: 1012
You are slowing down. I posted that conversion days ago. It will be interesting to see what Sony does pricing wise.
post #314 of 482 Old 09-14-2013, 05:44 PM
RapalloAV's Avatar
Liked: 472
Does anyone know the length of it front to back, the 1000 would not fit on my projection compartment?
Murray Thompson
X Owner RapalloAV
post #315 of 482 Old 09-14-2013, 06:05 PM
zombie10k's Avatar
Quoted: 3686 Post(s)
Liked: 3814
here you go:
zombie10k is online now
post #316 of 482 Old 09-14-2013, 06:21 PM
Liked: 1012
Divide mm by 25.4 to get inches.
post #317 of 482 Old 09-14-2013, 06:52 PM
zombie10k's Avatar
Liked: 3814
The VW500 is ~18CM (~7 inches) shorter than the VW1000.
post #318 of 482 Old 09-14-2013, 08:39 PM
RapalloAV's Avatar
Liked: 472
Do we know if the 500 takes an anamorphic lens easier than the 1000 does?
Murray Thompson
X Owner RapalloAV
post #319 of 482 Old 09-14-2013, 08:41 PM
RapalloAV's Avatar
Liked: 472
Good this model fits for me!
Murray Thompson
X Owner RapalloAV
post #320 of 482 Old 09-14-2013, 09:12 PM
Seegs108's Avatar
Quoted: 5165 Post(s)
Liked: 2571
As long as you don't scale the image to the full resolution of the panel you should be fine.
FS: Panamorph UH480 Anamorphic Lens - $1095
Seegs108 is online now
post #321 of 482 Old 09-15-2013, 12:11 AM
RapalloAV's Avatar
Liked: 472
Is the lens recessed as far back into the body of the proj as it is with the 1000?
Murray Thompson
X Owner RapalloAV
post #322 of 482 Old 09-15-2013, 04:49 AM
Liked: 1012
What difference here between UHD width and 4K width? The thing you need to do is to be at close to long throw where the size of the exit image is smallest. I doubt UHD or 4K width would make any difference in A lens/projector system performance,
post #323 of 482 Old 09-16-2013, 01:12 AM
Seegs108's Avatar
Liked: 2571
Well, the 1.9:1 aspect ratio of the full panel with a 1.33x anamorphic lens would yield you an image over 2.5:1. So I'm assuming there's a mode to keep aspect ratio of the content on the Sony, no?
post #324 of 482 Old 09-16-2013, 05:48 PM
Liked: 1012
The present 1000ES has vertical stretch modes of 1.33 and 1.24 or 1.25, I don't remember which. However, they won't work with a UHD or 4K input signal. Not enough number crunching power. The 500 or upgraded 100ES might rectify this but I don't know. The 1.33 anamorphics are 2K lenses and should not be used. Of course they can be, and they don't look that bad, but why bother even if you already own one.
If you must use an anamorphic lens, you need a 1.24w one rated for 4K. Will set you back $15K. Why bother?
BTW The Sony panel is 1.89 not 1.90.
I do see your point that if you use a 1.33w lens you will hit close to the ideal of about 2.37 if you limit the image width to normal on the Sony which is 3840 x 2160 or 1.78 rounded.
post #325 of 482 Old 09-16-2013, 06:04 PM
Seegs108's Avatar
Liked: 2571
I rounded up. Even with the .01 difference still yields you an image over 2.5:1 if one were to use a Schneider M lens like he was asking about. You'd definitely need to do 3840 x 2160 like you said. I suppose if one were to use an HTPC you do the appropriate image scaling with 4K content to send the 1000ES and use that lens.
I agree with you though. why spend another $15000 when you could zoom.
post #326 of 482 Old 09-16-2013, 06:44 PM
rcohen's Avatar
Quoted: 1386 Post(s)
Liked: 628
Brightness?
Anyone tried it (2k lens on 4k proj)? How bad is the quality loss? Can it be digitally corrected?
rcohen is offline
post #327 of 482 Old 09-16-2013, 06:47 PM
Mike Garrett's Avatar
Quoted: 6930 Post(s)
Liked: 4615
I remember one poster in the VW1000ES thread that I believe used an ISCO with his VW1000ES. If I get this projector, I will be using it with a lens. The projector can't throw a large enough image from my throw distance to fill my screen by zooming.
mjgarrett100@gmail.com
Mike Garrett is online now
post #328 of 482 Old 09-16-2013, 06:54 PM
rcohen's Avatar
Liked: 628
Hopefully, the hw500s and upgraded hw1000s and can fix chromatic aberration and aspect on 4k.
rcohen is offline
post #329 of 482 Old 09-16-2013, 07:00 PM
Seegs108's Avatar
Liked: 2571
Would AVScience allow you to buy one at cost? Lucky dog!
post #330 of 482 Old 09-16-2013, 07:18 PM
millerwill's Avatar
Quoted: 505 Post(s)
Liked: 303
Sounds like you need to cut a hole in your back wall, Mike. Fortunately I have a closet in the back of mine, and the back of the 1000 has to just protrude into it a few inches to allow me to zoom to 144" W for 2.35 pics. It's a near thing; thank goodness for the very short min throw of the 1000.
millerwill is online now
Sony Vpl Hw50es 3d Projector , Darbeevision Darblet Hdmi Video Processor , Sony Vpl Vw1000es Projector , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
