SONY VPL-VW500ES SXRD 4K Projector : IFA BERLIN 2013 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 482 Old 09-18-2013, 11:06 AM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 33
Originally Posted by mark haflich View Post
What is the screen gain?
All things being equal you will get the brightest picture at short throw and the greatest on/off contrast at long throw. The lens will perform best optically at long throw. The exit image is smallest at long throw and one uses more of the sweet spot of the lens. So if you have enough brightness which is a function of your screen gain. the curves of fallmoff in brightness as you migrate from short throw and fall off in on/off as you migrate from long throw are log curves and are not straight lines , so deciding to mount a midthrow is not a good choice because you lose much of the brightness and much of the on/off. Say about 30%. Pick your poison.
Thx for that informative response; so I'll try to mount the projector as far back as possible which is approx 19ft from the 120" screen from the sounds of it.
Still haven't figured out the screen material, but thinking of either of these ones:
- Stewart StudioTek 130
- JKP Affinity HD Progressive 1.1
To provide background on where the screen will be going, the Theare room will be dedicated with one small window (2' x 3' covered w/ shutters) adjacent to the back row seats. Ceiling will be painted black, Carpet will be a midnight blue, and walls a dark grey. Any preference on which screen would work best with the VPL500ES?
THanks in advance!
See Profile
scanido is offline
post #362 of 482 Old 09-18-2013, 11:35 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Originally Posted by darinp2 View Post
Hi Mark,
Hope you are feeling well.
The above seems to be the prevailing wisdom, but I wonder whether that is accurate. A while back somebody asked me about seeing higher MTF at short throw and whether I thought that made any sense. I thought about it a little bit and decided that there could be some logic in it.
If the exit image is smallest then it has the highest density of pixels per inch of lens cross section. No lens is perfect, so let's consider an exit image that takes up 1" horizontally at lens exit and a lens imperfection with exactly 1 pixel width under those conditions. If you change the zoom so that the exit image uses 2" of lens horizontally at exit then that same lens imperfection is only 1/2 of 1 pixel width.
I know there are multiple lens elements, this could be much more complicated, and a smaller image may use a better part of the lens (depending on lens shift), but I think using less of the lens could cause worse images instead of better.
Consider a more extreme example of a 10" wide lens. Now if you shoot a 1920x1080 image through that lens at full width the anomolies at full width will be much smaller compared to the image than if you tried to shoot that same image through just the center 1" of that lens.
Seems like the same kind of principle as it being more difficult to make a small lens of the same pixel resolution as a large lens.
What do you think?
Darin
I think thar discussion ignores where the lens is sharpest considering the use of vertical lens shift. As one puts more of the image towards the glass extremities, the image tends to get less sharp at those points.
mark haflich is offline
post #363 of 482 Old 09-18-2013, 11:40 AM
Liked: 1010
I would choose between the Stewart snomatt 100 (gain of one) and the JKP Affinity 1.1 gain. Given your screen size, you could use some gain and I would choose the JKP 1.1. You could use the 130 for the extra gain considering your long throw mount but to me the 100 is a better fabric than the 130 making the screen disappear when lit up. But I don't know about how happy you would be with the brightness.
post #364 of 482 Old 09-18-2013, 04:54 PM
rcohen's Avatar
Quoted: 1215 Post(s)
Liked: 519
I am unsure of screen gain, screen size, or projector placement. So, I ordered the projector first, and got a bunch of different free screen samples I can tape on the wall. Once I can experiment with the projector, it should help with all these decisions.
rcohen is offline
post #365 of 482 Old 09-18-2013, 05:03 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 262
Great strategy! Just projecting onto the wall will definitely help you decide on the screen size that is best for you, and the samples are also very helpful to decide on the screen material.
millerwill is online now
post #366 of 482 Old 09-18-2013, 05:43 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3044 Post(s)
Liked: 2977
+1. That is a good way to finalize your screen size / choice.
Add the new JKP HD Pro 1.3 and the Stewart Cima Neve 1.1 materials to the list Mark posted there, to check out.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #367 of 482 Old 09-19-2013, 11:08 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Visit the new pjhc.fr forum here : http://www.projection-homecinema.fr/forum/
kraine is offline
post #368 of 482 Old 09-19-2013, 11:14 AM
darinp2's Avatar
Quoted: 1129 Post(s)
Liked: 1765
Originally Posted by Geof View Post
To clarify, the horizontal axis on charts below go from 0-22...however, the edge of the image occurs at 18mm - the reason the chart goes to 22 (or thereabouts) is to show corner performance (half the diagonal is roughly 22mm).
Thanks Geof. Given those charts I wonder what they would look like with an infinite zoom range (like we essentially get) and the zoom setup so the edge of the image is at 15 mm. I see the MTF getting better for the middle there (even as it gets worse for the edges) going to wide zoom. I wonder if that is related to the factor I brought up.
Where I said anomolies it may have been more clear if I had said lens imperfections, which every one of these lenses will have down at the microscopic level.
One thing to keep in mind is that the image is not focused as it passes through the front of the lens, so center pixels on the screen don't just use their corresponding spot as they exit the front of the lens. What I wrote earlier may have given a different impression, but I still think that the factor of lens imperfection size to average pixel size may be relevant here, with that factor possibly getting worse as we use less of the lens surface (use longest throw).
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #369 of 482 Old 09-19-2013, 11:20 AM
darinp2's Avatar
Liked: 1765
I think thar discussion ignores where the lens is sharpest considering the use of vertical lens shift. As one puts more of the imge towards the glass extremities, the image tends to get less sharp at those points.
Such as that those of us who use a retro-reflective screen and put the projector a little overhead and behind may be using a sharper part of the lens than those who mount their projector high up on the ceiling. smile.gif
We know that the edges of the lens may not be as good as the center (and generally won't be), but that does not automatically lead to the longest throw giving the best images. There can be multiple factors at work that have to be weighted against each other.
This could get especially complicated if one place in the throw range gives the sharpest images for the center pixels but not the sharpest toward the edges of the image, since pixels near the center of the screen tend to be more important than edge pixels for normal viewing.
BTW: I'm not saying I know where the best throw positions are, but I think it may be more complicated and not quite match the general wisdom around here.
--Darin
darinp2 is offline
post #370 of 482 Old 09-19-2013, 01:45 PM
mbw23air's Avatar
Quoted: 158 Post(s)
Liked: 149
Originally Posted by kraine View Post
Kraine,
Are you getting to play around with one of these today? If so, what are your impressions? I'm especially interested in how 1080p blu-rays look up scaled.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is offline
post #371 of 482 Old 09-19-2013, 01:58 PM
whitetrash66's Avatar
Quoted: 66 Post(s)
Liked: 42
Also, if you get one kraine,
1: does it compare to the vw1000 or vw95 for contrast?
2: how is lens sharpness compared to the vw1000?
3: 3d impressions? Does it have the lamp pulsing 3d mode that the 1000 lacked?
Sweet looking projector though. Def looks bigger than my 95
whitetrash66 is offline
post #372 of 482 Old 09-19-2013, 02:00 PM
d.j.'s Avatar
Quoted: 166 Post(s)
Liked: 73
Originally Posted by hifiaudio2 View Post
255 I believe. Been quite a while since I tested (and I don't have it anymore).
Hifiaudio2 ( and SOWK )
You are correct, with contrast at 88 ( iris off ) , its is just arround to begin to clip at 250-255. ( with auto iris on, the clip will occur with contrast at 96 - max. typical )
If you want it to clip arround 235 ( with iris off ) , you can turn contrast up to about max.
dj
d.j. is online now
post #373 of 482 Old 09-20-2013, 05:28 AM
BakeApples's Avatar
Quoted: 246 Post(s)
Liked: 140
Nice! Looking forward reading your first impressions.
Sony VPL-VW550 | DNP Supernova 08-85 116" 2.35:1 | Lumagen Radiance Pro 4440 | Pioneer SC-LX89 | Oppo UDP-203 | Zappiti One 4k HDR | PS4 | Audio Pro/Pioneer 5.1.4 Atmos | SVS SB-1000
BakeApples is online now
post #374 of 482 Old 09-20-2013, 09:40 AM
Quoted: 66 Post(s)
Liked: 42
It will be REALLY interesting to see how the VW500ES compares to the VW1000ES. Really, if the contrast and sharpness are even close, i don't see the point of getting the VW1000ES. That's an extra $10,000 at least.
From the hands on reports so far (including Cine4homes detailed report), the brightness calibrated is almost the exact same. The native contrast is 20% less, BUT you can adjust how far the iris opens and closes in a new menu, so really, i would just clamp it down that extra bit and be good. The only thing that concerns me is the lens sharpness. But that's a large premium to pay, if its $10,000 MORE than the VW500. The VW1000 has a wider color space, and a sharper lens. but the VW500 has many cool features that are not on the VW1000 YET (mastered in 4K, autocalibration, new motionflow modes, previously mentioned iris tuning, possibly it has brighter 3D than the VW1000 if Sony implements its lamp pulsing tech, and probably cheaper lamps). Maybe some will come with the update? hopefully it does for VW1000 users.
If the VW1000 is still 25K, i would have a hard time justifying that purchase over the VW500 unless the lens and contrast are REALLY crappy. I can't see the contrast on the VW500 being much worse than my VW95, which i'm happy with.
post #375 of 482 Old 09-20-2013, 10:09 AM
Seegs108's Avatar
Quoted: 4218 Post(s)
Liked: 2093
With the cheaper lens I'd make a wager that the ANSI contrast is going to take a huge hit too.
Seegs108 is offline
post #376 of 482 Old 09-20-2013, 12:52 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 262
If I hadn't had a 1000 for almost 2 yrs now, and were looking for a new pj this year, I think I would go the route you describe. The main choice, I would think, is between the VW500 (or 600--don't yet know what its US label is) and the top of the line JVC's. I'll bet they both look very, very good. (Still happy, though, that I did bite for the 1000!)
post #377 of 482 Old 09-20-2013, 12:55 PM
Andreas21's Avatar
Quoted: 1035 Post(s)
Liked: 671
+1
Regards
Andreas
My Homecinema
Calibration software: Lightspace and Calman. TPG: Murideo Fresco SIX-G
Meters: Klein K-10 A and Jeti 1501. THX II certified.
Andreas21 is offline
post #378 of 482 Old 09-20-2013, 01:00 PM
zombie10k's Avatar
Quoted: 2826 Post(s)
Liked: 2783
those are good questions. We really need Cine4home's deep dive to get to some of the specific details you are referring to. I bet he's already working on it.
i'm interested in hearing about the auto-cal and the new iris functions. Also if 3D is brighter than the VW1000. I can't imagine why they wouldn't put the lamp pulsing into the new model.
zombie10k is offline
post #379 of 482 Old 09-20-2013, 01:02 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 262
Originally Posted by Andreas21 View Post
+1
Yes, this will be my 'new projector' for this year (and maybe the next, too)!
post #380 of 482 Old 09-21-2013, 08:36 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Sadly I'm not this french lucky guy. M'y review will come but only early November.
kraine is offline
post #381 of 482 Old 09-21-2013, 10:31 AM
Liked: 1010
French Lucky Guy would be a great name for a race horse or for a posting name on AVS.
armstrr likes this.
post #382 of 482 Old 09-21-2013, 10:52 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Well this guy isn't on avs for the moment, but I will give him your advice Mark wink.gif
kraine is offline
post #383 of 482 Old 09-21-2013, 11:29 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
--Darin
Hi Darin,
Whew, there sure are a lot of variables involved here....While optical performance degrades as you move from the center of the lens the questions of how fast, and at what point, and just how the MTF curves vary are certainly dependent on the optical design. And as you mention lens imperfections could play a part in projector MTF figures but I'd hope those are minimized (when I look at images made with my 36 MP camera and very decent prime lenses I can see sharpness fall off towards the edges but I haven't been able to spot any IQ issues due to lens imperfections and those pixels are very very tiny....a dust spot of the sensor can be barely visible to the unaided eye yet it can cover hundreds of pixels (I absolutely hate cleaning the sensor).. I wonder if this is not accounted for by the overall MTF performance of the lens (for example, I strongly suspect a lens imperfection would affect contrast as light hitting it would be refracted).
I hope you'll be looking at the Sony's and JVC's during your Cedia visit and posting your impressions....
Geof
Geof is offline
post #384 of 482 Old 09-21-2013, 02:00 PM
Liked: 1010
Its almost next to impossible to do evaluative comparisons at a show even between two models from the same manufacturer.
Knowing Darin, he will ask several manufacturers and guys like Joe Kane a bunch of tough questions and get wrong answers bordering on nonsense. This will piss him off no end and provide fodder for many posts over the next year. Contrast related questions are almost guaranteed to do it.
post #385 of 482 Old 09-21-2013, 03:07 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
No doubt about that. But a lot of folks will be posting impressions and I'd like to hear Darin's thoughts....(and yours too if you were going this year).
Nonsense answers tend to piss me off too....if they don't know they should say they don't know and don't try to baffle with bull*****. Oh, and I'm not trying to kiss ass or anything but I think Darin's contrast paper should be required reading for projector owners....
Geof
Geof is offline
post #386 of 482 Old 09-21-2013, 06:48 PM
zombie10k's Avatar
Liked: 2783
Here's the link to the contrast discussion, I haven't seen it posted here in a while.
http://www.hometheaterhifi.com/volume_13_2/feature-article-contrast-ratio-5-2006-part-1.html
post #387 of 482 Old 09-21-2013, 07:04 PM
Liked: 1010
It would be great if you had to pass a test before you could buy a projector or at least if your dealer/installer had to pass the test.
post #388 of 482 Old 09-21-2013, 07:18 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
They should have held this year's expo at 14,000 feet in elevation, that way we'd finally know which projector really has the best lamps.
Access HERE from this thread
coderguy is online now
post #389 of 482 Old 09-21-2013, 10:10 PM
Liked: 1010
At 14,000 you would pass out standing in line to get into the Sony theater. You can spend time at that elevation but one moves real slow and one really needs to spend several days a little lower to get acclimated.
post #390 of 482 Old 09-21-2013, 10:33 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
I've been to the top of those mountains just outside Denver before (Mt Evans Drive).
There are people walking around and I've never seen anyone pass out, but I've definitely heard people breathing heavy (there is your opener).
I wouldn't recommend it for asthma suffers, but a cigar at 14k feet will give a better buzz...
An airplane cabin is pressurized up to 8,000 feet so that is all the acclimation you need.
Sony Vpl Hw50es 3d Projector , Darbeevision Darblet Hdmi Video Processor , Sony Vpl Vw1000es Projector , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
