Should I buy Sony VPL-VW95ES - AVS Forum | Home Theater Discussions And Reviews
post #1 of 74 Old 11-20-2012, 03:58 PM - Thread Starter
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Hello guys,
I have been planning to buy Sony-VPL95ES. I did my research around but got confused. You guys are experts and I'm very sure that you'd know the answer. Thanks in advance.
So I have room that can hold 130" screen. It is completely dark. Even the walls (including ceiling) are painted with dark color. After reading a lot of reviews VPL95ES seems to be the right option to go for in terms of picture quality. I'm sure there are othre projectors as well but based on reviews, this pj gives awesome quality picture with good 3D.
So my concerns are
1 - Can I display on 130" using this projector?
2 - Can I display 3D on 130" using this projector (considering lumin goes way low after calibration and in 3D)?
3 - If not then what's max I can go in 3D mode?
4 - What screen should I buy in my situation.
About the screen. Considering this pj has very high quality image, using a low quality screen will bring quality down. I know there is SudionTek 130 (130" screeen) but it costs around $2,800 which is very expensive (imho). Then there is Da-Lite which costs around 1,650 (130" screen). That i can afford but am I loosing noticeable image quality????
Thanks so much.
SherazNJ is offline
post #2 of 74 Old 11-20-2012, 07:05 PM
xb1032's Avatar
Liked: 26
If 3D is very important to you I would consider a Dalite HP 2.4 gain screen if it's at all possible to shelf mount your screen. It
s brightest at eye level but you can have it higher. I have my projector behind my 2nd row seating about 14" over the back row seating (but very close the the seats) and the screen gives a very nice gain which is much appreciated for 3D.
Personally I would consider the HW50 as well. From all I've read the VW95 has better blacks (some say slight, others say noticeable but it's hard to make a judgement call as many people's opinion differs) and it should be optically sharper as well. However, the HW50 has Reality Creation which sharpens the picture but could give a more digital look tot the pic but the projector is much brighter and should have slightly less ghosting over the VW95. If you don't have a set expectation on black levels I might go for the HW50. I have a 119" Dalite HP screen and I presently have an RS45 and I'm considering an upgrade between the HW50 and the RS46 (not out yet). I had considered the VW95 but I like a bright pic and what I've read was it has to be in high lamp mode to reach the brightness of the HW30 (last years HW50) which it's brightness is on par with the JVC RS45 that I have now.
Good luck!!!
xb1032 is offline
post #3 of 74 Old 11-20-2012, 08:25 PM - Thread Starter
SherazNJ's Avatar
Liked: 144
xb thanks for your reply.
I have never owned a projector before so i don't know what it means to have a great black expectation (since I have nothing to compare). But like anybody else, I'd love to have a great quality picture.
Considering the fact that HW is much higher in lumins, why should I go with Dalite HP 2.4 gain screen?? Sholdn't I rather consider getting Dalite High contrast screen?
Those of you who have seem both HW50 and VW95ES side by side, what do you guys think of image quality loss?
SherazNJ is offline
post #4 of 74 Old 11-20-2012, 08:58 PM
geeji's Avatar
I saw the VPL-VW95 and the VPL-VW50 side by side, but none were calibrated. What I would say is that the differences were subtle, and on some aspects like brightness I may have liked the VPL-VW50 better... which may entirely be due to different lamp hours on both projectors.
They are some rumors on this forum that the successor of the VPL-VW95 may arrive in April 2013.
In the meantime, the VPL-VW50 has a much better quality/price ratio (VPL-VW95 is 1 year older than VPL-VW50).
geeji is offline
post #5 of 74 Old 11-20-2012, 09:15 PM
zombie10k's Avatar
Quoted: 3700 Post(s)
Liked: 3830
how important is 3D? The HW50 has better / brighter 3D than the VW95.
regarding the 2.4HP screen - do you like the 'bright plasma on the wall' look? That's the overall effect. For some, brightness is addicting even in a light controlled room. (especially in 3D).
The caveat of the HP is that the projector needs to be mounted as close to eye level as possible for the brightest image. A rear shelf or table mount is usually the setup. If you can only mount the projector above the top of the screen, the gain will be much less and not worth going with the HP.
A quick joke about the HP. A neighbor came over and saw my screen, but didn't see the projector. He said 'I didn't know they made TV's this big? (he was quite serious). It was hard not to laugh since my screen is over 11 FEET wide and dwarfs even 80" LCD's. I had to show him the projector for it to make sense what he was seeing.
zombie10k is online now
post #6 of 74 Old 11-20-2012, 09:19 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 312
I get this all the time
blee0120 is online now
post #7 of 74 Old 11-21-2012, 07:40 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
LOL. I watch my bright plasma on the wall (a 64 or 65 inch Panasonic) and complain that it doesn't look real. I am always aware that I am watching a TV. There is no reality. It really sucks. Sort of like background radio. I am spoiled.
My screen and projector don't look like a bright plasma on the wall. Thank god. I would ditch the sport if that was my end result. Abject failure. But no, I have an image that looks like reality. I am fooled into thinking I am there. My screen is invisable. It just disappears (both when the projector is off and the room is dark, just like you HP boys can do, at least you have part of it right, but ta da, it disappears when the projector is on).
What did I do to get tha?. A very nice 4K projector with great optics and a screen with a gain of 1.0, very very important if you want make the screen disappear andto make your viewing area on the screen transform into a window with no glass.
Is not that the ultimate objective of what we are trying to accomplish?
Unfortunately, this is no longer the objective for most. That's OK. Go for making your HT end result the same as a large plasma on the wall. Yep. The goal is having a really big plasma TV and you know what, a HP will get you there. Congratulations. You have met your goal. And that is what your guests will judge you by. They know TV. They know what a goof plasma looks like. TV. By George, you have made it really big. A big big plasma.
mark haflich is offline
post #8 of 74 Old 11-21-2012, 07:57 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
What did I do to get that. A very nice 4K projector with great optics and a screen with a gain of 1.0, very very important if you want make the screen disappear and your viewing area on the screen transform into a window with no glass.
do you mind sharing what screen are you using?
That's definitely not my goal and thanks for pointing this out. I also want the realistic expericne but unfortunately can't afford 4k projector. I believe they go for $25,000 minimun.
SherazNJ is offline
post #9 of 74 Old 11-21-2012, 08:05 AM
zombie10k's Avatar
Liked: 3830
He is using an expensive screen with a VERY expensive $25,000 projector...
let's come back down to earth since we're discussing $3k projectors here.
also, some VW1000 owners admit that they could use an HP screen for 3D since it only puts out ~1000 lumens in 3D, the same amount as the typical 3K projector today.
post #10 of 74 Old 11-21-2012, 08:17 AM
zombie10k's Avatar
Liked: 3830
every screen choice has their limitation. A high quality 1.0 screen that looks excellent in 2D isn't necessarily the best choice for 3D. You have to strike a balance between size and screen gain.
~1000 lumens in 3D on a 130" low gain screen is not my idea of 3D, it's far too dim for my preferences.
This is a sample of the HP material (the older 2.8 vs. current 2.4) on a 1.0 gain screen. If you search the HP thread in the screen forum, you'll find it's one of the preferred screens for 3D. Mine is the 2.8HP @ 142" 16:9 and 3D looks excellent with ~ 1000 lumens in 3D.
post #11 of 74 Old 11-21-2012, 08:51 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4006 Post(s)
Liked: 4065
Thats why sometimes 2 screens makes sense. You can use a lower gain / unity gain screen for movies, and a pull down High Power screen for 3D. Heck, Mark, you might even go for that !wink.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #12 of 74 Old 11-21-2012, 09:08 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
That's exactly what I wanted to do but I came to know that I can't utilize HP screens because the projector needs to be mounted on ceiling (ceiling is 8 feet high) and for HP to work, it has to be at sitting height. (Am I correct??)
I think StudioTek 130 is a good option for 2D. It usually comes with 1.3 gain. There is one with 1.5 gain as well but don't know how much of a difference that would make. Ideas guys??
Another option I have is to use StudioTek 130 for 2D and reduce image size to 100" for 3D???? What do you guys think???
Another option is to use HW50ES instead of VW95ES. Anybody done side by side comparison on these two to see image quality difference?
Zombie10,
Sorry got a little confusded. These images you have with a small (brighter)square in the middle: is it showing difference in between HP 2.8 vs HP 2.4 or HP vs non HP?
VW95ES is 1000 Lumens but after calibration it goes down and with 3D is goes way down. When u say ~1000, do you mean after calibration or in general a projector that has 1000 lumens.
SherazNJ is offline
post #13 of 74 Old 11-21-2012, 10:30 AM
zombie10k's Avatar
Liked: 3830
The sample was the 2.8 on the 1.0 screen. If you have to go with a ceiling mount, the advantages of the gain on the HP are greatly reduced and picking a difference screen makes more sense.
Your original post stated a 130" screen. This is a relatively large sized screen, especially for 3D. I've calibrated VW95's and HW50's and would prefer the HW50's 3D brightness in this scenario. IMO, it's still too dim for a 1.0 gain screen @ 130" but that is subjective and some might be OK with it. The 1.5 might work well, you'll have to find others in the screen forum using that screen material.
The HW50 measures ~1064 lumens in 3D mode before I corrected the colors behind the glasses. Nearly 80% of the light is lost with the 3D glasses which is why the HP is such a good match for today's ~1000 lumen 3D projectors.
post #14 of 74 Old 11-21-2012, 10:43 AM
Liked: 1012
I have a piece of HP 2.4. And you know what. When I stick it on my 1.0 gain screen, that square of HP really looks much brighter than the rest of the image which looks very non bright in comparison. Take a camera shot and to expose that bright square correctly the picture of the rest will darken further. Also you eyes will when presented with that bright square also darken up the rest. The picture is so biased though I kmow not intemtionally. m. A gain of 2.8 compared to a 1.0 fabric will be 2.8 times brighter, but to your eyes won't even look twice as bright. the gain would have to be 4 to look twice as bright. Moreover, if you want the brightest sample, just go with th2 2.4 and don't even bother looking at other lower gains, duh, they won't be as bright and just like speaker loundness, duh I like the one that is playing the loudest, choose the brightest fabric. Nothing else matters. And truthfully, the rest isn't bad with the HP it just will never ever look real .
The problem is the people want large screens, they want to light them with relatively inexpensive projectors, and they also want 3D to be bright. This can not be done without very very serious t o PQ compromises. When I move to Florida, I will employ a two screen solution using a HP for 3D presentations only. And i will only do that if more 3D films etc are released that I want to watch. I have seen multiple times the 3Ds that I want to see.
Everything else I will watch on my 1.0 limiting the screen size to something my projector can adequately light.
Re the thread originator, with the screen size wanted, I think the HW50 is the best choice right now. I suspect the replacement for the 95 that will be shown at CES would be a greater choice, even better and just as bright I suspect.
A screen gain of 1.0 just won't work, the screen is just too big. I would probably go with the Studeotech 150 but remember you need a minimum throw of 1.5 for that to acoid hotspotting.
post #15 of 74 Old 11-21-2012, 10:46 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
130" diagonal (just to be clear). I have 11 ft wide and 8 ft high wall space with 29 ft depth area. I agree that HWE50 would be a better choice for 3D. Since I'll be watching 80% 2D and 20% 3D, I woudln't want to compromize 2D over 3D. So StudioTek 130 would be the choice for 2D which will give me a 1.3 gain. For 3D I'm thinking to reduce size to 100" which should give me enough brightness ( I hope).
SherazNJ is offline
post #16 of 74 Old 11-21-2012, 11:26 AM
zombie10k's Avatar
Liked: 3830
that sounds like a good plan. The HW50 is a nice all around 2D / 3D projector.
post #17 of 74 Old 11-22-2012, 08:57 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
Ok now that I have decided to get 95ES and also StudioTek 130 screen, next step is to install and calibrate. I think I can find some sites to show the installation but I have my doubts about calibration. Zombie can you please share your knowledge on calibration??? I know that there is a separate category here on calibration but the stuff was flying off my head when I tried to understand it. Here in USA, NJ, it costs around $400.00 to calibrate projector. I'm a software developer. So if I know the steps, I don't think it will be hard for me to familiarize myself with the software.
Also seems like there are many options to go with when it comes to software. Which one is good and does the job????
SherazNJ is offline
post #18 of 74 Old 11-22-2012, 09:02 AM
zombie10k's Avatar
Liked: 3830
If you want to calibrate yourself, your looking at ~ $570 for a calibrated meter + software.
http://www.curtpalme.com/ChromaPure_EyeOneDisplay3.shtm
This is what I use. it's a Display 3 meter (Calibrated by Tom Huffman who is considered one of the best color experts around) and includes a license for Chromapure which is easy to learn after some practice.
The VW95 does have a full CMS and it's possible to achieve an excellent calibration with the built in controls and the right meter/software.
post #19 of 74 Old 11-22-2012, 09:12 AM
rpconrad's Avatar
Do you recommend the standard Chomapure or the standard version plus auto-calibrate
rpconrad is offline
post #20 of 74 Old 11-22-2012, 09:51 AM
Liked: 1012
You need an external processor to auto calibrate with the Sony. Something like a Lumagen mini which are on big time sale this weekend. Call Mike Garret at AV Science. he will fix you you up with an entire package, screen, prijector, calibration stuff, processor, mount etc etc.t
post #21 of 74 Old 11-22-2012, 10:12 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
Already have. Mike is taking care of my order including everything you mentioned besides calibration.
SherazNJ is offline
post #22 of 74 Old 11-22-2012, 10:20 AM
zombie10k's Avatar
Liked: 3830
Standard is recommended for the manual calibration. You can always add the auto-cal license on if you decide to go with an external VP like the mini-3D in the future.
That link includes everything you need to get started.
post #23 of 74 Old 11-22-2012, 10:21 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
Zombie,
What about this http://www.projectorreviews.com/sony/vpl-vw95es/calibration.php
Can we achieve this calibration with built in features from pj? Also if yes then how is it different from using calibrated meter + software.
SherazNJ is offline
post #24 of 74 Old 11-22-2012, 01:19 PM
zombie10k's Avatar
Liked: 3830
Zombie,
Those #'s are only relevant to that specific projector. Each projector requires it's own unique calibration due to a number of factors, but the lamp is the main reason. Lamps can change quickly over time and a calibration at 100 hours could look quite different at 400 hours.
Having the meter and equipment allows you to refresh the calibration every so often for maximum PQ.
post #25 of 74 Old 11-22-2012, 01:33 PM - Thread Starter
SherazNJ's Avatar
Liked: 144
Oh wooowwww. I was under the impression that calibration is required only once (on a new projector). But now it seems like calibration is required after every 300-400 hours.
SherazNJ is offline
post #26 of 74 Old 11-22-2012, 04:56 PM - Thread Starter
SherazNJ's Avatar
Liked: 144
To make sure I understand correctly, you are saying that one should calibrate a pj after every say 400-500 hours of usage? And the settings on the link that I provided is only applicable to new condition? or I can reset the settings after 400-500 hours of usage?
SherazNJ is offline
post #27 of 74 Old 11-22-2012, 05:42 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 312
I calibrate my projector every 75hrs on average
post #28 of 74 Old 11-22-2012, 09:33 PM
Liked: 1012
I hope that means every 75 hours of viewing rather thanevery three days. smile.gif
post #29 of 74 Old 11-22-2012, 09:37 PM
Liked: 1012
calibration is required more often in the early stages of bulb life. I would not even bother to calibrate a projector new out of the box. i would wait at least 100 hours. Then I would doit again at 200 and then again at 400.
These aren't absolute. But if you buy a meter and a calibration program it becomes very easy after a short learning curve. of course I am spoiled, having a Lumagen and auto cal.
post #30 of 74 Old 11-23-2012, 07:41 AM - Thread Starter
SherazNJ's Avatar
Liked: 144
Zimbie10K already mentined about the meter to use
Mark: can you please provide link t Autocal program? I think Lumagen is expensive meter.
Also does meter and calibration takes care of everything? I mean including color calibration as well?
Sorry I'm new to this but very much leaning towards buying it than calling a calibrator. I spent decent amount on high end projector and screen (Sony VPL-VW95ES, StudioTek 130 130" screen), I'd want to make sure that I'm getting the best out of my projector and screen.
SherazNJ is offline
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
