failing ir and push buttons on projector not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-24-2012, 10:52 PM - Thread Starter
larryep's Avatar
hello forum members
I have an 11 year old sanyo plv70 projector. the ir commands don't work very good any more and the push buttons on projector are also working on and off. i tried the reset button on the back of projector but still have the problem. could it be a bad ir board.
i would love to upgrade to a new projector but that might be in 2013.
any suggestion would be very much appreciaeted.
thank you
larry
larryep is offline
post #2 of 3 Old 11-28-2012, 05:23 PM - Thread Starter
larryep's Avatar
AN UPDATE TO MY PROBLEM;
what is strange is when the projector is off it always acccepts the ir command to turn on but once the projector is on the ir commands become unresponsive.
larryep is offline
post #3 of 3 Old 12-31-2012, 09:47 PM - Thread Starter
larryep's Avatar
new update
I put a older bulb in that is not new and dimmed out. Th ir commands seem to work better. It makes me wonder if a new bulb can draw to much power, taken away from other components in projector. hmm
larryep is offline
