Official JVC DLA-RS46 / DLA-X35 owners thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 50Likes
post #181 of 2750 Old 12-14-2012, 06:01 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
Code:
Thanks for the tips ill try them out and let you know
Holiday121 is offline
post #182 of 2750 Old 12-14-2012, 08:17 AM
craigmm's Avatar
After mounting, how can I ensure the lens is perpendicular to the screen?
craigmm is offline
post #183 of 2750 Old 12-14-2012, 08:22 AM
Kelvin1965S's Avatar
Quoted: 288 Post(s)
Liked: 189
Bring up the zoom pattern which is a series of squares (or might be shift/focus). You can then tilt or twist the protector to make sure that the pattern isn't trapezoidal (you may have to use the lens shift to put the image back onto the screen), I tend to do this with the projector zoomed small so the pattern fits inside the screen area. It's easier for me as my X35 is stood on top of a bookcase, so I just have to turn it and adjust the legs, but if it's a ceiling mount then it might be a bit more tricky to do.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #184 of 2750 Old 12-14-2012, 08:42 AM
Gig103's Avatar
Originally Posted by Dragon Reborn View Post
Originally Posted by HyperReality View Post
On the remote, quickly press UP DOWN RIGHT LEFT ENTER
What is this, a Konami projector? ;-)
Neowulf likes this.
Gig103 is offline
post #185 of 2750 Old 12-14-2012, 08:59 AM
jcorbin's Avatar
Here you go: http://f.cl.ly/items/1L012i3B1g130y0x1d2v/NEC_pattern_1.jpg
Not sure. Was this sound in 2D or 3D mode? Low or high lamp? I can't say I've heard this myself, but I can check when I fire it up next.
Great, thank you!
It was in 2D mode, low lamp.
jcorbin is offline
post #186 of 2750 Old 12-14-2012, 09:06 AM
jcorbin's Avatar
One thing to keep in mind, when projecting onto a wall, it is very hard to determine if the image is square. This is because you do not have a perfectly square frame to project against. If the image is not perfectly square, then focus can't be completely uniform edge to edge.
Thanks Mike. That makes sense. I doubt I will have it 100% completely square until it gets officially mounted.
jcorbin is offline
post #187 of 2750 Old 12-14-2012, 09:13 AM
Quoted: 288 Post(s)
Liked: 189
From all reports so far, the JVC is pretty good right out of the box already, but I'd also be interested if anybody would like to share their settings. smile.gif
It's been mentioned that Cinema or Natural modes are quite good, set color space to standard, set gamma to 2.2 (or just leave as is), and that's a pretty nice picture as is. For bat-cave movies, I set the iris to -15; for room-lighting TV, I leave it at 0. Then I used the AVS calibration tools (link in post #1) to do a basic calibration of brightness and contrast which gave me -1/+1 for contrast/brightness for bat-cave mode, and -2/+2 for TV mode. After that, I think I set the Black Level adjustment set at 1.
Hopefully, Zombie10k, Art et al. can present their own settings soon.
I set up with the User mode, which I've subsequently calibrated. I used the following settings, but found that the colour temp measured a bit too low once I got my meter out, though this will vary from example to example and also dependent on room/screen/ancillary equipment too.
User 1:
Contrast, brightness, colour and tint at zero as confirmed by the AVS HD709 basic patterns.
Colour temp 6500K
Custom gamma set to 2.3
Standard colour space
Sharpness/detail to zero
Black level to +2 (I'm going to revisit this as I think my black level is slightly raised having done some more checking last night)
Aperture at -15 (gives me 100 Lux at 16:9 setting) which equals 14fL on my 1.5 gain screen).
CMD OFF
I have User 2 set the same but the iris at -8 or -9 for use with 2.35:1 content with my A lens.
When I did my calibration I changed the colour temp to Custom colour temp and picked 6500 but then changed red gain to -10 and blue gain to -11 for 0.3 dE at 100%. In my case the Lumagen does the rest, so no need for further adjustments. Note that I left the RGB offsets at 0 to avoid raising the black level or crushing dark scenes.
Also, just to comment that there shouldn't be any need to have different brightness and contrast setting for 'TV' or 'Bat cave' mode: The correct setting with the black not being clipped and the lowest black floor is all that is needed. Perhaps if watching with some ambient light then maybe need to raise the brightness just to avoid black crush, but otherwise one correct setting should apply for both modes IMHO.
post #188 of 2750 Old 12-14-2012, 09:48 AM - Thread Starter
Dragon Reborn's Avatar
User 1:
Colour temp 6500K
CMD OFF
Great info in this post, Kelvin, thanks!
My "TV" mode includes having 6 potlights (at half illumination) and 4 wall sconces on, but I hear what you're saying. smile.gif
Dragon Reborn is offline
post #189 of 2750 Old 12-14-2012, 10:34 AM
Quoted: 288 Post(s)
Liked: 189
Then your TV mode may well need the black floor raising a little to be able to see the lower % for shadow detail with some lights on. I don't tend to bother as if I have the projector on and a single lamp at the back of the room such as if I'm having a 'TV' dinner eek.gif then I just use my 2.35:1 setting (the one with more iris opened) to combat some of the ambient light assuming I'm watching 16:9 which most TV seems to be anyway.
I meant to say that if that's your bat cave in your avatar then it looks a really nice set up you have there. cool.gif
post #190 of 2750 Old 12-14-2012, 12:10 PM - Thread Starter
And by "bat-cave," I just meant lights off in the theatre. I know some folks have here have totally black theatres, wall-to-wall and floor-to-ceiling. tongue.gif
post #191 of 2750 Old 12-14-2012, 04:24 PM - Thread Starter
Originally Posted by jcorbin View Post
Great, thank you!
I've put my ear up to all corners of the projector and I don't hear any ringing or other odd noise. Maybe if you need to get your switcher/firmware update, you can ask JVC to investigate that noise too?
On another note, I accessed the service menu and confirmed that my unit has the problematic switcher, 2012.9.26.1
Also, there is a convergence test pattern in the service menu!
post #192 of 2750 Old 12-15-2012, 02:56 PM
Alexlego's Avatar
Hello, I would like to know if anyone tested an X35 with Darbee against an X55 to know if Eshift2 is really worth it? Kelvin maybe?
I reserved an X35 but I'm still wondering if I should leap towards the X55.
Alexlego is offline
post #193 of 2750 Old 12-16-2012, 01:58 AM
Quoted: 288 Post(s)
Liked: 189
No, I've only seen an X55 with a Darbee on and off with Eshift on and now my own X35 with a Darbee. I think I missed a trick as I could have got the dealer to demo the X55 with Eshift off and Darbee on, then compare X55 Eshift on and Darbee off. It was a little rushed so I didn't get to try everything that I would have liked. What I can say is that with the X35 installed in my room, properly set up and the Darbee on 50% HD I don't feel at all like the poor relation. For me the X35 was more of an impulse purchase compared to the X55: Initially I just wanted a white unit to better fit in with some decoration changes we are making in the room and I figured that any newer model would give some PQ improvement over my black HD350, I'm just surprised that the improvement is so noticeable.
It's a tough call which model you go for as I believe the price difference for you is much less. In the UK the X55 is £2,100 more (ie virtually twice the price of the X35 especially if it's the 2D only package that I got which means no glasses or emitter). I already had a Lumagen Mini3D, so that takes care of the CMS (and then some with the 125 point CMS and autocal cool.gif), plus I had the Darbee and my Isco II lens. I don't think I'd be any better off if I sold those 'accessories' and bought the X55 instead, especially as I like not having any overspill from using an A lens.
post #194 of 2750 Old 12-16-2012, 02:13 PM
jslaw81's Avatar
Hey Everyone, Anyone had the X30/ RS45 and upgraded to the x35/RS46? If so do you notice it being any brighter? I currently have the RS45 with a 100" SI black Diamond 1.4 gain screen and seems dim to me. I've got about 475 hours on the bulb.
jslaw81 is offline
post #195 of 2750 Old 12-16-2012, 05:45 PM
yourtoys7's Avatar
Is RS46 an overkill just for 2D use? I have Panasonic 4000 now so memory zoom is awesome, but I don't/ won't watch any 3D at all,
EluneVision 106" Reference Studio 4K Tab-tensioned - 1.0 Gain, Benq 1070, psb T6, Rotel, OPPO, Velodine (Now),
135" AT screen, JVC-X35, 3x RF82, 3x Emotiva XPA100, Velodine, Rotel, OPPO (Sold with house).
yourtoys7 is offline
post #196 of 2750 Old 12-16-2012, 06:03 PM
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
Do you mean is it too expensive to use for only 2D? Because there are many projectors that are more that doesn't do 3D and cheaper projectors that do 2D. If you want the 2D quality, its the JVC
blee0120 is online now
post #197 of 2750 Old 12-16-2012, 06:15 PM
yourtoys7's Avatar
No, maybe the 2D is not best as 3D focus is shifting, so I'm paying for 3D (not sure how much), but essentially waisting money on 3D side of it. I'm only looking for 2D and besides old 250 model they don't make 2D only.
Anyone came from Panasonic 4000 model or others to JVC?, how big of a change was it?...
post #198 of 2750 Old 12-16-2012, 07:14 PM
Alexlego's Avatar
Thanks for your input Kelvin. Over here in Canada, as you were saying, the difference is around a 1200$ between X35 and X55, so not as steep as in your neck of the woods. You seem like a happy camper with the X35. I have only seen the X30 and Sony's w50 and the Panasonic 8000, because X35 and X55 are not yet up for demo in stores around here. I liked the X30 better than the Sony, even if the Reality Creation bit is nice. The guy at the store had the Panny against the Sony and he switched from one to the other while playing the Dark Knight opening scenes and the Sony was clearly one step ahead in most aspects. I noticed that the opening traveling scene with the buildings, the X30's weakness was some clipping in rendering the building windows. Hope this is cared for in the newer projectors, while not a real game changer for me. I'll wait for a real demo of the X55 soon and make my decision after. The w50 is between the two JVC price wise but with no lens memory shift and has a less film like look for me. It's still a serious contender. I'm starting with the custom Wall-of-Sound that's going to be behind the acoustic screen to give me time.
Cheers,
Alexlego is offline
post #199 of 2750 Old 12-16-2012, 10:02 PM
bytebuster's Avatar
Quoted: 89 Post(s)
Liked: 27
I'm also using near-max vertical lens shift (with about 3" to spare on a 100" screen), and no horizontal shift ---> good uniform focus. And prior to ceiling installation, I had tested focus with no lens shift just to be sure, and it was good, edge to edge to edge. smile.gif
Folks,
How much vertical lens shift is available i.e. how far above the top of the screen can the center of the lens be located?
Also, does the lens have an automatica cover (like the epson 5010s)
bytebuster is offline
post #200 of 2750 Old 12-16-2012, 11:17 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
The JVC R46 does not have automatic lens cover. You have to take it out and put it in yourself
post #201 of 2750 Old 12-17-2012, 04:22 AM - Thread Starter
Originally Posted by bytebuster View Post
Folks,
For maximum vertical lens shift (with no horizontal shift), the lens can be placed 80% of the screen height above the screen centre. See post #1 for setup/placement tips. With any horizontal shift, vertical lens shift is reduced.
post #202 of 2750 Old 12-17-2012, 05:32 AM
Neowulf's Avatar
There is a lens cover for the RS46? Mine came with the plastic clear one for shipping, but I have found no lens cap in the box to put on/off the projector.
Neowulf is offline
post #203 of 2750 Old 12-17-2012, 06:03 AM
Alan Ross's Avatar
Got my RS66 a few days ago. Will not be able to ceiling mount it for a few days but just in a temporary setup the results so far are excellent. Pixel alignment is spot on. Corner to corner seems very uniform and this is with plenty of vertical lens shift.
Lots of flexibility with User modes. Settings I made for sports worked exceedingly well over yesterday's NFL games. When switching back to HBO I immediately knew it was time for the switch to one of the Cinema modes. BluRay presentation looks amazing so far.
Using the Darbee at about 50 setting for added detail in all modes.
I still like the high lamp mode on my 100 inch screen but I notice less difference than with previous JVC projectors.
If you like to tweak colors and gamma the menu allows for all kinds of experimentation.
Alan Ross is offline
post #204 of 2750 Old 12-17-2012, 06:09 AM
Mike Garrett's Avatar
Quoted: 7066 Post(s)
Liked: 4772
That is the only lens cover that the RS46 has. Remember the lens is coated with an anti static coating. Dust is usually not a problem. The cover is good, if you have a low mounted projector and have little ones that might want to touch the lens. One of my projectors has been shelf mounted for 6 years and it does not have a lens cover. I have never had to clean the lens.
mjgarrett100@gmail.com
Mike Garrett is online now
post #205 of 2750 Old 12-17-2012, 11:43 AM
Neowulf's Avatar
Thanks Mike.
LOVING the projector btw. I don't have a digital camera, all I have is this crappy IPhone to take pictures, and it doesn't do justice to the quality of this projector and the screen. But here is a shot at 11 feet away:
And Here is 4 feet away off right
All "blur" and "noise" is the phone. You don't see it on the screen.
Absolutely happy with my purchase.
14 ft throw to a Monoprice 120" screen.
Neowulf is offline
post #206 of 2750 Old 12-17-2012, 02:45 PM
caperguy33's Avatar
Would you be so kind as to post some photos of dark content with the black bars ? Also could you give your impression of how dark the bars appear ? Thanks and take care.
caperguy33 is offline
post #207 of 2750 Old 12-17-2012, 03:18 PM
Gig103's Avatar
Last night I threw in a DVD (Pirates of the Caribbean 1 - Curse of the Black Pearl) and it was an awful transfer. Other movies didn't seem so bad so it could be that particular movie but I'm worried that I never noticed it on 720p. Yes I know the resolution just about doubles again from 720 to 1080
My Panasonic is upconverting to 1080p but any thoughts on trying to output in native DVD res (480p) and letting the JVC upconvert? Does it have that capability?
Gig103 is offline
post #208 of 2750 Old 12-17-2012, 03:37 PM - Thread Starter
Absolutely.
480i, 480p, 576i, 576p, 720p/50 Hz, 720p/60 Hz, 1080i/50 Hz, 1080i/60 Hz, 1080p/24 Hz, 1080p/50 Hz, 1080p/60 Hz are all upconverted by the JVC.
post #209 of 2750 Old 12-17-2012, 03:52 PM
Quoted: 288 Post(s)
Liked: 189
Or...buy a Lumagen Mini3D biggrin.gif : I compared the upscaling of my JVC, my Oppo '93 and the Lumagen and the result was in that order worst to best. It's not that the JVC is unwatchable, but if you have an alternative to try then why not? It doesn't take long to try out whatever alternatives you have, so if you find the JVC is better at upscaling than your player, then use that option. Equally, if you're looking for an excuse to upgrade, then try the Oppo or go to the Lumagen (though it's better to have a player that can be set to 'source direct' if you go the Lumagen route, which in my case means the Oppo rolleyes.gif) as IMHO they are better than the JVC.
post #210 of 2750 Old 12-17-2012, 04:11 PM
Neowulf's Avatar
I'll see what I can do. Can't really say how it is as I have a masking system that covers the black bars, but Ill try to get a photo with masking down.
Neowulf is offline
Jvc Dla Rs46 Projector , Jvc Dla X35 3d Hd Front Projector , Optoma Hd72 720p Dlp Home Theater Projector , Panasonic Viera Ty Er3d4mu Active Shutter 3d Eyewear , Samsung Ssg 4100gb 3d Active Glasses 2012 Model
