Official JVC DLA-RS46 / DLA-X35 owners thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 46Likes
Old 08-03-2015, 10:35 AM
12B4A's Avatar
Quoted: 329 Post(s)
Liked: 201
I think it's just an inherent performance issue. The times I've loaded the scope position settings on mine it's usually off from where it was saved before. I imagine the method of where it tracks the motor step position is not as precise as the actual movement. I also get an axis shift whenever I switch from horizontal to vertical shifting or vice versa. It's an annoyance for sure but all things considered, at least there wasn't a lot of compromise on the optical performance.
Life is Lambertian
12B4A is offline
Old 08-03-2015, 03:08 PM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
Originally Posted by rmaddog View Post
I have a 138" 2.35 scope AT screen from Elite. Screen brightest with my RS46 is not a problem... The height of my room won't let me get bigger than the 110" 16:9 so going wife to be able to get the 138" scope screen was a great option for me that I don't regret. Most of my blus are 2.35. 2.35 content is totally immersive in my room and I love it!
Thanks for chiming in. Looking like this something around this size is going to work for me as well. Can you share the price of the Elite via PM, if you don't mind?
I'm finding that I'm smarter than I thought, but dumber than I need to be.
PSN ID: rtart, alt Ginsuyou2
rtart is offline
Old 08-03-2015, 03:25 PM
rmaddog's Avatar
What kind of pic are you looking for? I have some pics on my thread you can link to...
I don't have any problem with changing the scope via lens memory... Goes right back to where I had saved it. I have the following 5 lens memory setups saved:
2.35
16:9 (1.78)
1.85
16:9 for my HTPC (slightly different than what comes out on my 16:9 blus)
ESPN (16:9 but with the sports ticker chopped off).
rmaddog is offline
Old 08-03-2015, 05:57 PM
Dreamliner's Avatar
Quoted: 483 Post(s)
Liked: 147
Yeah. It's probably related to the lens motor.
I do prefer the Panasonic lens memory functionality. Pixel perfect every time. Plus the masking is part of the memory, which makes sense.
Dreamliner is offline
Old 08-06-2015, 01:35 PM
allupons's Avatar
Quoted: 13 Post(s)
I was wondering where you guys shop for bulb / lamp replacements. I am wanting to replace my lamp and I am unsure of the various online stores and whether or not the bulb is the actual official JVC bulb. The prices seem to range from $315 up to $400, so it would be awesome if there were some consensus answers on where to get the official OEM lamps from.
allupons is offline
Old 08-06-2015, 02:25 PM
Dreamliner's Avatar
Quoted: 483 Post(s)
Liked: 147
I'll be interested to hear the response to this. Odds are though, if your not buying from a dealer, your not getting a JVC lamp.
What I'd really like to know is if you can replace the bulb inside the lamp housing with an OE bulb to save money. That's where the real savings would be, if its possible.
Old 08-06-2015, 02:46 PM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
^^Me too. I noticed that the price of 'real OEM' bulbs dropped as the PJ aged....which I guess makes sense. I'm at the 1,600 hour point with my RS46, but brightness, even in 3D mode, doesn't seem to be an issue yet.
There is/was a lot of discussion on the RS1 thread about this topic, so you may want to read that.
rtart is offline
Old 08-07-2015, 10:38 AM
Mike Garrett's Avatar
Quoted: 6220 Post(s)
Liked: 4014
Originally Posted by PiggyChops View Post
Is the projectcentral calculator accurate ? I have a 1.1/1.2 gain 144 inch screen which i'm about to mount on a frame but the calculator is stating not to go over 140 inches in order to stay at 12FL. So should i stick to 140 inches or less or use 144 inches, i'm confused
If you are using XD fabric, then you need to use the actual gain, which is 0.98, so enter in 1.0. If using UF, then enter in 0.8.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 08-23-2015, 07:57 AM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
Just bought one for $86.00 Seller says its a real OEM JVC bulb, brand new and sealed in the box. I'll report back after I receive it. I've corresponded with a couple ebay sellers about authenticity, and have been told that they are available for less than retail price. I can share that in a recent visit to China, the ability to buy 'graymarket' electronics, etc. at or near the factory can result in big reductions in price. Maybe that is what is happening here.
As I said, I'll report back once I get the bulb.
rtart is offline
Old 08-24-2015, 06:25 AM
Liked: 4014
A US dealer can't sell an OEM lamp in an OEM housing for $315, without losing money.
Old 08-24-2015, 06:42 AM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
Maybe, maybe not.....'graymarket' Ipods, notebooks, etc., can be bought in Shenzhen for a fraction of the USA price. Perhaps this is the case here. An item that is not shipped and distributed through the 'normal' JVC distribution network CAN come from the same factory and be built to the exact same specs. China is not renowned for respecting intellectual property rights, after all.
Is this the case here? Once again, I'll report back after I receive the bulb.
For those who wish to espouse the benefits of buying from the manufacturer only, I'm not engaging. Over $300 for a bulb? Really? Is it made of "unobtanium?"
rtart is offline
Old 08-24-2015, 07:51 AM
stanger89's Avatar
Quoted: 2976 Post(s)
Liked: 1556
I'm all for saving money on lamps, but I've read enough reports here from people who bought 3rd party lamps and had significant problems, I don't think it's worth the chance. If you have to replace the 3rd party lamp 4 times as often it's not a bargain. Same if it's not as bright. The current JVC lamps last a long time, even if we assume only 2000 hours, that's only $0.15/hr. Not bad considering a new Blu-ray is over $10/hr, and a trip to the theater is even worse than that.
stanger89 is offline
Old 08-24-2015, 07:53 AM
Liked: 4014
I was just letting you know that a US dealer can't sell at that price point. There is not much profit in a lamp for a dealer.
Old 08-24-2015, 03:37 PM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
I understand.....I used to work for an electronics manufacturer, and the markups on replacement parts were astronomical.
We had a captive audience, and the prices reflected it.
rtart is offline
Old 08-26-2015, 07:13 AM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
As promised, I'm reporting back after receiving the bulb.
The outer box looked just like the one I paid full price for from an authorized dealer. It was sealed, and as I opened it, the packaging was the same as the OEM bulb. Same for the inner bag, etc. The bulb cage has all of the same markings molded in as the OEM bulb. Stickers, etc. all appear to be the same. Markings, etc. on the bulb itself seem to be nearly identical to the OEM bulb. Same placement , font, etc. from what I can tell.
I installed it, and the PQ and brightness looks as good as the one that I pulled out, which is a "real" JVC bulb installed a couple hundred hours ago.
If I had purchased it from an authorized dealer I would have been convinced I got the 'real deal.' As it is, all looks OK to me so far.
Now it might die quickly or otherwise fail early. I'll post an update as I use it so others can benefit or learn from my experience.
Surfdrifter likes this.
rtart is offline
Old 08-26-2015, 08:56 AM
Dreamliner's Avatar
Quoted: 483 Post(s)
Liked: 147
Thank you for posting, I'm at ~2200 hours and looking at lamps, just in case...
Couple of quick questions:
1) You say OEM, do you really mean OE? (OEM refers to Original Equipment Manufacturer, so it could be something you purchased from a company that makes parts for JVC; whereas OE is Original Equipment, and refers to only the original or genuine JVC parts.) Not beating you up, just asking for clarity.
2) Did you get just the bulb, or the whole lamp assembly? (I haven't taken my lamp out, so I have no idea if the bulb is easily separated.)
3) Can you post pics of your original lamp that shipped with your projector and the one you just got?
Old 08-26-2015, 11:26 AM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
Hi Dreamliner,
It's in a box that says "JVC" and the lamp assembly says that, too. I would assume that JVC does not make its own bulbs, but this one looks just like the one I paid a lot more for and just took out of the PJ, including the box, packaging, bulb assembly, etc.
Might be a 'fake', but it seems to be a pretty good fake if it is.....As I stated previously, there are situations where at the end of the assembly line in China 'real' merchandise goes out the left door to the USA, and 'graymarket' merchandise goes out the right door. So far, this seems to be the case with this bulb.
Time will tell, I guess.
rtart is offline
Old 09-01-2015, 09:46 AM
Quoted: 13 Post(s)
Liked: 0
Hi, Im very much interested in JVC. Looks like the only choice i have is to go with X500r but my price point is near 3k. Do you guys know if i can get new X35 from anywhere? I know its not made anymore.
Harish Gangidi is offline
Old 09-01-2015, 10:32 AM
erkq's Avatar
Quoted: 646 Post(s)
Liked: 460
Isn't that the model year JVC had frustrating bulb problems that were corrected in later models?
erkq is offline
Old 09-01-2015, 10:38 AM
stanger89's Avatar
Liked: 1556
Old 09-01-2015, 10:44 AM
Liked: 4014
The X35 uses the current lamp. No problems with that lamp. He could look for used X35, used RS46 or one of the B-stock JVC's. All of those should be around his budget or lower.
Old 09-01-2015, 12:53 PM
Seegs108's Avatar
Quoted: 4506 Post(s)
Liked: 2249
I have one for sale right at your price point. If you're interested let me know. Check my signature for more details.
Seegs108 is offline
Old 09-01-2015, 08:18 PM
AVfile's Avatar
Quoted: 271 Post(s)
Liked: 137
You can also get one from Canada. The X35B is still a current model here.
http://www.jvc.ca/www/Consumer/model.aspx?m=DLA-X35B
http://www.hd.ca/bargains/dlax30.php
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
Old 09-13-2015, 08:03 AM
rtart's Avatar
Quoted: 36 Post(s)
Liked: 64
Looking for a set of feet for my RS46.
Decided to go from a ceiling mount to a shelf mount, so I need a set of feet for my PJ. Apparently mine were lost somewhere along the line.
Anyone have a set they are not using in their ceiling mount setup?
rtart is offline
Old 09-22-2015, 09:29 AM
NXPlasmid's Avatar
Hey everyone,
I bought my RS46 from AV Science back in 2012 and it has been a champ! However it just developed a strange image distortion. I notice the image had shrunk about an inch or two from the boarders of my screen (~95 inch diag). No problem, as I can change the zoom right? Wrong, the projected image is no longer square at the corners, well it's most pronounced at the upper right and left and the lower left hand corners, strangely the righthand lower corner doesn't seem to be effected (Ceiling mounted). Here are a couple pics showing the drooping of the projected image. Anyone have an idea of what is going on, and/or what I can do about it. It's clearly off warranty...
ID:	956450   Click image for larger version
NXPlasmid is offline
Old 09-22-2015, 11:41 AM
nezil's Avatar
Liked: 43
That's really strange... I hope I never run into that problem.
Are you 100% sure that your screen is totally flat?
The images you posted are so low resolution that It's difficult to see if the distortion is being applied digitally or not. Are the green lines perfectly straight with no jaggies? Keystone would result in that I think.
The only other thing I can think of is melting of something in the light path due to overheating?!?
nezil is offline
Old 09-22-2015, 12:19 PM
NXPlasmid's Avatar
The lines are straight no jaggies. It seems to me like an optics issue, the thought that it might be heat related has occurred to me and makes me a little worried... Mike thinks it may have been bumped which, based on the location, seems unlikely, but I'm sending a pic of the full screen to him so he can assess things better. I run in low power mode so I don't know if that makes heat issues less worrisome...
Old 09-22-2015, 12:33 PM
Liked: 4014
Originally Posted by NXPlasmid View Post
Hey everyone,
As talked about in the email you sent me. Projector has been moved. If the bottom left corner matches the top right corner, then projector has been rotated clockwise (looking from above. You need to rotate projector counter clockwise (looking from above) and then lens shift back.
Added
Another thing that could cause this. Left side of screen pulled out from the wall. This would decrease the distance from lens to left side, not allowing the image to spread out as much. That should be easy to check.
Old 09-23-2015, 09:09 AM
NXPlasmid's Avatar
Well the story continues. I mailed Mike the full screen image but later when I was fiddling with things I noticed something (from the email I sent him)
... when I was adjusting the image size later, I noticed that the rounded corners had wavy lines not absolutely straight ones like the rest of the pattern. I took a close up and you can clearly see that the line is getting pixel shifted if you start at the bottom left hand side of the top left box, you'll notice the line starts off clean and clear, then shifts a bit to the right, and gets fuzzy, I think it's in between pixels, then shifts again and is on pixel and it repeats once more before the getting to the top of the box. I don't think this can be caused by projector angle. Also, perhaps unrelated, there is a definite image brightness flicker happening now. Mark
Old 09-25-2015, 06:23 AM
dreamtheatre's Avatar
Quoted: 58 Post(s)
Liked: 37
Guys, I own an RS25. In your opinions, would I see a major upgrade moving up to an X35?
LG 65EF9500 OLED Display
Oppo BDP-203,Schiit Bifrost Multibit DAC, MF V-LINK 192
Parasound P5, Marantz SR-6010, EAD PM 1000 and PM 500 amps
NHT 2.5i (2), NHT AC-1 (1), NHT 1.5 (2), PSB XA (4)
Outlaw Ultra X12 and LFM-1 EX subwoofers
dreamtheatre is offline
Jvc Dla Rs46 Projector , Jvc Dla X35 3d Hd Front Projector , Optoma Hd72 720p Dlp Home Theater Projector , Panasonic Viera Ty Er3d4mu Active Shutter 3d Eyewear , Samsung Ssg 4100gb 3d Active Glasses 2012 Model
