Official JVC DLA-RS46 / DLA-X35 owners thread - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 47Likes
post #2701 of 2722 Old 08-08-2017, 05:04 AM
menrad's Avatar
It was easier to calibrate out of the box (I'm not equipped with a Souder), and I had better results overall, more homogeneous in terms of color and grey tones.
I was surprised, I expected to have lower picture quality.
Envoyé de mon LG-H990 en utilisant Tapatalk
menrad is offline
post #2702 of 2722 Old 08-08-2017, 05:08 AM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Ok thanks. Good to know. What calibration tools do you recommend?
k3nnis is offline
post #2703 of 2722 Old 08-08-2017, 05:56 AM
menrad's Avatar
I used mostly digital video essentials, and Disney Wow, and a bit of Spears and Mundial discs.
These are far from being the best calibration method (because I did with my eyes), but you can achieve something you will be satisfied with. And it's a great start.
menrad is offline
post #2704 of 2722 Old 08-08-2017, 06:00 AM
Franin's Avatar
Quoted: 2378 Post(s)
Liked: 1475
Calman
_________________________
Franin is online now
post #2705 of 2722 Old 08-08-2017, 06:03 AM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Thx guys. Does jvc provide any calibration software? Also where can I download latest firmware for the x35?
k3nnis is offline
post #2706 of 2722 Old 08-08-2017, 10:55 AM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
Not for the RS46/X35.
JVC does have their free autocal software for the X500, though you have to buy a Spyder meter to use it.
fleaman is offline
post #2707 of 2722 Old 08-08-2017, 01:43 PM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Thanks. How about firmware updates? I heard there was an update to fix 3D crosstalk issues?
k3nnis is offline
post #2708 of 2722 Old 08-08-2017, 05:56 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
Not sure about firmware updates on the RS46/X35. I actually have the RS57 (X700).
I just knew that there was no JVC auto calibration software/ability on the RS46/X35's...
fleaman is offline
post #2709 of 2722 Old 08-08-2017, 06:01 PM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Ok thanks.
k3nnis is offline
post #2710 of 2722 Old 08-10-2017, 07:27 PM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
If I need to buy a blu ray player today which one would be best value for the X35?
k3nnis is offline
post #2711 of 2722 Old 08-10-2017, 09:16 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
When playing blu ray discs only, through hdmi, the picture quality is essentially the same amongst blu ray players.
The difference gap widens when you play a DVD disc and the blu player upconverts to a 1080p signal to the X35. In that case I would look at an older used Oppo player for the best 'value'.
Though the blu player doesn't have to do the upconversion. JVC projectors supposedly have a pretty good scaler internally that can handle a 480p DVD signal. I've never compared though.
fleaman is offline
post #2712 of 2722 Old 08-10-2017, 09:33 PM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Ok thanks. I'm thinking should I bother with a Panasonic ub900 or get a 1080p Sony BD. oppo is still quite pricey. I won't be playing back DVD's. Mainly Streaming and BD's.
k3nnis is offline
post #2713 of 2722 Old 08-11-2017, 01:15 AM
menrad's Avatar
I've fallen in love with Sony bdp-s790, who has great picture enhancement filters. I guess the Sony bdp-s7200 has the same.
menrad is offline
post #2714 of 2722 Old 08-11-2017, 03:51 AM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
ok thanks. Just need BD and 3d
k3nnis is offline
post #2715 of 2722 Old 08-11-2017, 03:53 AM
menrad's Avatar
And if you need a good companion for picture enhancement, look for a Dvdo iscan mini
k3nnis likes this.
menrad is offline
post #2716 of 2722 Old 08-11-2017, 03:55 AM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Ok thanks. Is oppo darbee a picture enhancement? Some people don't like darbee and prefer the original oppo?
k3nnis is offline
post #2717 of 2722 Old 08-11-2017, 12:08 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
Note that the X35 won't accept a 4K signal with the Panny, so not sure if that is a great 'value' player considering it's quite expensive.
fleaman is offline
post #2718 of 2722 Old 08-11-2017, 12:21 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
I have an Oppo 83SE and a separate Darbee unit.
Darbee is a very noticeable picture enhancement for the good. Makes the JVC look a little sharper (or a lot....it's a bit subjective). I would highly recommend it. It had also made my previous Mits HC3800 DLP projector look sharper and my current and past TV. I'm using 1 Darbee unit connected to a single hdmi out on my receiver, then i split the Darbie hdmi out into 2 outs with an active hdmi splitter from monoprice. So I only have to use 1 Darbee feed both my PJ and TV at the same time. Therefore my 1 Darbee is working on all the signals I'm feeding them....blu ray, HD cable, etc.
If you get a Oppo with Darbee internally, you'll only have Darbee coming from that player. But if you only do blu rays and streaming, then maybe the Oppo 103D would be the one for you (I assuming the internal Darbee works on the streaming too). The Oppo 103D's go for about $300-$400'ish on ebay. It can't play UHD 4K discs though....but as mentioned, with a UHS 4K player you'd have to downconvert and send a 1080p signal to the X35 as it won't accept a 4K signal.
fleaman is offline
post #2719 of 2722 Old 08-11-2017, 12:24 PM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Thanks. Do the oppo 103d have Netflix app?
k3nnis is offline
post #2720 of 2722 Old 08-11-2017, 12:27 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
Yes.
But it won't accept Netflix 4k.
fleaman is offline
post #2721 of 2722 Old 08-11-2017, 12:28 PM
k3nnis's Avatar
Quoted: 445 Post(s)
Liked: 50
Ok no probs. I will watch Netflix 4k on my 65" 4ktv. But will look small lol
k3nnis is offline
post #2722 of 2722 Old Yesterday, 10:17 AM
AceMT's Avatar
Hi All,
I have had an X35 for several years now and still very happy with it. Recently, a friend of mine, during a crazy night of VR hit my screen and scratched it. It is a Da-Lite high power screen which has since been discontinued.
I was starting to look at a replacement and wondered if you all could chime in with what screens are working with you with the current and previous JVC models. I mostly watch movies in a mostly to completely dark room.
I have heard great things about the Seymour Ambient Vision Black 1.2 and wondered if anyone has been using this...
Thanks in advance.
Mark
AceMT is online now
Jvc Dla Rs46 Projector , Jvc Dla X35 3d Hd Front Projector , Optoma Hd72 720p Dlp Home Theater Projector , Panasonic Viera Ty Er3d4mu Active Shutter 3d Eyewear , Samsung Ssg 4100gb 3d Active Glasses 2012 Model
