Official JVC DLA-RS46 / DLA-X35 owners thread - Page 92 - AVS Forum | Home Theater Discussions And Reviews
 50Likes
post #2731 of 2746 Old 09-15-2017, 09:05 AM
Dreamliner's Avatar
Quoted: 783 Post(s)
Liked: 286
Originally Posted by k3nnis View Post
Do you guys think the x35 is still comparable or on par with the Sony hw45es?
I'm not certain how much the x35 your looking at is, but I'd strongly suggest getting a RS400 (a 420 would be best if you can). There is a guy on here selling his that is practically brand new. I upgraded from the RS46 to the RS400. In addition to 4K, HDR and all that jazz (which you WILL eventually get into, its just a matter of when) the RS400 is SIGNIFICANTLY better for HD. Even with eShift off, the pixels are physically closer together and its immediately noticeable. The image is definitely clearer and is the very first thing I noticed. The RS400 is also a lot brighter and the 3D is magnificent. Plus, it does 4K, HDR and all that good stuff.
Pay now or pay later, but you will buy a 4K projector...why not now?
Dreamliner is offline
post #2732 of 2746 Old 09-15-2017, 10:57 AM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 117
Originally Posted by jeahrens View Post
@kennis
I've seen the 40,45,50 and 55ES. The RS46 has better contrast and black floor than the Sony's (especially the 4x models). Plus lens memory if you want to go with a scope setup. Color wise all of them have very nice pop. The motion handing on the Sony 5x units may be a bit better than the JVC.
I believe the Sony's have a bit more firepower (lumens). But as mentioned, higher black floor and lower contrast vs the JVC.
IF one has a gigantic screen (like +140" or so), and/or like plasma TV like brightness on a big screen, and/or never have a totally dark room (so not so concerned about blacks), then it might be worthwhile to look into the Sony.
Though if I needed the firepower, I'd go with a newer B stock JVC as others have mentioned to get the best of both worlds, lumens and blacks/constast.
fleaman is online now
post #2733 of 2746 Old 09-15-2017, 12:33 PM
jeahrens's Avatar
Quoted: 637 Post(s)
Liked: 310
Depends on what you're after. With good light control the RS46 has plenty of oomph. Mine was running on a 130" scope screen (with lens memory) and I had the iris at -6. Still plenty bright. According to Projector Reviews the 45ES in low lamp would calibrate to less than 1000 lumens, so very comparable to the RS46, but with the JVC having a much better picture. The 50 and 55ES were also comparable light output wise when I saw them.
Now the Sony 4K lineup is another story.
jeahrens is online now
post #2734 of 2746 Old 09-15-2017, 12:38 PM
jeahrens's Avatar
Quoted: 637 Post(s)
Liked: 310
Even though I'm selling an RS46, I'm not gonna lie the RS400 is a big step up.
However if yoy're budget only allows for something like the Sony 45ES or one of the ~$1000 DLP's the RS46 used would offer a lot better picture in that price range.
Dreamliner likes this.
post #2735 of 2746 Old 09-15-2017, 03:15 PM
k3nnis's Avatar
Quoted: 450 Post(s)
Liked: 50
Thanks. Reason I asked is because I have a rs46 now that I haven't set up yet. I got it for $1200
k3nnis is offline
post #2736 of 2746 Old 09-15-2017, 08:54 PM
k3nnis's Avatar
Quoted: 450 Post(s)
Liked: 50
Is the black level of the rs46 as good as a Rs 400/420?
k3nnis is offline
post #2737 of 2746 Old 09-15-2017, 10:48 PM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 117
Yeah, remembering around 1,000 lumens on the Sony's in low lamp.
Don't recall an RS46 getting near that in low lamp, thought it was more in the 700 lumen range....all things being somewhat equal (hard to compare with all the zoom positions and iris on the JVC).
post #2738 of 2746 Old 09-15-2017, 11:07 PM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 117
I think it's more important to think about your screen size first.
On a small screen, say 90", I think the RS46 can clamp down to a lower black level than the RS400/420.
But on a larger screen, say 120"+, I think you should look at the RS400/420's as the larger the screen you go, the lower your black level will be, all things being equal. And at even larger sizes, your RS46 is gonna start getting dim as the lamp ages, though it might still pop well when new.
I was in the market for a JVC earlier this year. I have a very small screen, like 80" diagonal (small room). I was hoping for a B-stock X500/RS4910/RS49, but they were all gone. AVS was offering the RS400, but IMO that would be overkill for my 80" screen and unnecessarily raise my black level over my previous JVC choices (according to AVS member black level measures at the fully closed iris setting).
So I kept an eye on ebay for an X500/RS4910/RS49 and even RS46 (though I really wanted a dynamic iris). I was coming from a 7 year old Mits HC3800 DLP, so any of those JVC's would have been an upgrade. I even saved an ebay search for an RS57, which has the dual dynamic iris. I bid on a low hrs one and unexpectedly won it at the price point I set for the X500/RS4910 models.
The RS57 apparently has an even lower (slightly) black floor than the X500/Rs4910/RS49 and RS46 and I'm super stoked I got it. The RS57 doesn't have the firepower of an RS400, but for my 80" screen it was a perfect fit.
Just sharing my thoughts. Your mileage may vary.
post #2739 of 2746 Old 09-15-2017, 11:09 PM
k3nnis's Avatar
Quoted: 450 Post(s)
Liked: 50
Thanks. I'm aiming for a 110" screen max.
k3nnis is offline
post #2740 of 2746 Old 09-16-2017, 12:38 AM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 117
Hmmm....right at the hand off point between those 2 projectors!
I dunno. It might come down to how bright you like it....more on the plasma bright side (in that case, RS400), or more on the commercial theater side, which the RS46 would do nicely on that size.
But that is purely talking blacks and brights. The RS400 might have worse blacks than the RS46 on that screen, though do everything else better than the RS46's better blacks.
Tough call.
Let's see what others might say...
post #2741 of 2746 Old 09-16-2017, 12:42 AM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 117
I can tell you that with my RS57, it gets very dark. I had to cover all my LED lights on gear, as they were way too bright on black out scenes. I have my manual iris at -11 and on Auto 2 dynamic.
That's right, I just remembered the RS46 doesn't have a dynamic iris. So now that I think about it, I dunno if clamping the RS46 manual iris all the way down for the best blacks is far enough on it's own. And even if so, the overall image on bright scenes is gonna be too dim for that 110" screen.
I'm leaning to the RS400 now...
post #2742 of 2746 Old 09-16-2017, 04:43 AM
k3nnis's Avatar
Quoted: 450 Post(s)
Liked: 50
Thanks for the input.
k3nnis is offline
post #2743 of 2746 Old 09-23-2017, 06:41 PM
1Myke's Avatar
Haven't been too active for a couple yrs but thinking of some changes and starting with lowering my screen about 5-6", the projector is ceiling mounted and hangs as low as 11" from ceiling to bottom of projector. Worried about the throw and angle, don't want to lose pic quality. Pictures are below, forgive the mess. Any advise or thoughts are appreciated.
RTi A7's, CSI A6, FXi A4's | Emotive XPA-5 | JVC DLA RS46 | Panamax M5300 PM | Pioneer Elite | Seymour Screen
1Myke is offline
post #2744 of 2746 Old 09-23-2017, 08:30 PM
Dreamliner's Avatar
Quoted: 783 Post(s)
Liked: 286
I wanted to mount my 2.35:1 screen that high but I was worried about it looking especially terrible when I was zoomed in and it displayed 16x9 content that would spill onto the ceiling instead of just the walls. Does that bother you at all or how does that work?
post #2745 of 2746 Old Yesterday, 07:53 PM
DavidHir's Avatar
Quoted: 2005 Post(s)
Liked: 1650
Not sure what kind of ceiling mount you have, but my Chief RPMA mounts allow for an extension tube to have the projector drop down lower. However, I think the lens shift should be fine in your case.
My scope screen was mounted a bit higher initially, but I didn't like the feeling of looking up so lowered it at least 5-6 inches. I like my eyes to be closer to bottom 1/3 to middle of screen. Feels more immersive and comfortable.
DavidHir is online now
post #2746 of 2746 Old Today, 11:21 AM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 117
When people are first setting up their screen height, they should also consider their head angle. If you watch in a reclined position, with your head/eyes angled upward, then of course you'd have to position the screen higher than if in the sitting upright position.
Many forget this
Jvc Dla Rs46 Projector , Jvc Dla X35 3d Hd Front Projector , Optoma Hd72 720p Dlp Home Theater Projector , Panasonic Viera Ty Er3d4mu Active Shutter 3d Eyewear , Samsung Ssg 4100gb 3d Active Glasses 2012 Model
