AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Digital Hi-End Projectors - $3,000+ USD MSRP (http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/)
-   -   Official JVC DLA-RS46 / DLA-X35 owners thread (http://www.avsforum.com/forum/24-digital-hi-end-projectors-3-000-usd-msrp/1442525-official-jvc-dla-rs46-dla-x35-owners-thread.html)
Dragon Reborn 11-30-2012 01:16 PM
This first post will be updated periodically.
Brochure
User manual
Projector Central setup calculator
JVC setup calculator
Setup tips
Basic calibration disc
Online reviews:
French
AVforum
HDTVtest
Art's
CNET
Pixel convergence test pattern::
Access the service menu for this test pattern. On the remote, quickly press UP DOWN RIGHT LEFT ENTER
Reported info:
2D Low lamp (calibrated/uncalibrated Natural): 717 / 631 lumens
2D High lamp (calibrated/uncalibrated Natural): 939 / 916 lumens
3D High lamp (uncalibrated 3D profile): 995 lumens
Lag (gaming): 80 ms
3D ghosting problem with initial release:
Switcher #: 2012.9.26.1 (faulty 3D)
Switcher #: 2012.12.4.1 (fixed 3D)
(Access the service menu to view the switcher #)
Compatible 3D glasses
Panasonic TY-ER3D4MU
Samsung SSG-4100GB
My JVC DLA-X35 arrived today! This is my second projector ever. My first was a 720p Optoma HD72 DLP projector from 2006.
Box
Packaging
As far as I know, there are currently no high quality photos of the back panel on the web. As a result, the right angle HDMI adapter that I pre-ordered is, naturally, the opposite of what I need. rolleyes.gif
Panel
Bigger is better
JVC vs Optoma
Sexy beast
Sexy Beast
merc10 11-30-2012 01:22 PM
Ive got one coming next week.Cant wait to read some owners reviews.
Good luck with it.
jcorbin 11-30-2012 05:38 PM
As a fellow projector newb who has preordered an RS-46, is there a 'new' projector checklist of things to check after it arrives? For example, convergence.
tigerfan33 11-30-2012 05:57 PM
Congrates on your new toy:)
Enjoy!
Dragon Reborn 11-30-2012 06:39 PM
Good luck with it.
Ditto. I would also appreciate some advice. This is my first LCOS.
Enjoy!
Thanks. Unfortunately, I might not have time to fire it up until next week. eek.gif
Dragon Reborn 11-30-2012 06:58 PM
I have a 6 year old Chief RPA ceiling mount that I used for my Optoma (a fairly small and lightweight DLP). I really like this low profile mount because of my low ceiling.
These are the parts:
These small Chief extenders need to be used for the mount to reach the JVC's holes. This is the connection that worries me:
Should I be concerned about the mount's strength to hold the JVC? confused.gif
Alternatively, there's a $100+ mounting plate (SLB281) for JVC projectors but I don't think I need it?
gopromiller 12-01-2012 06:28 AM
good thinks, i like it ,me too, I would also appreciate some advice. This is my first LCOS
freebits 12-01-2012 08:09 AM
SED <--- Rules 12-01-2012 11:19 AM
Congrats Dragon smile.gif Man, that is a HUGE difference in size compared to you old Optoma projector. eek.gif Geez. Let us know what you think of it when you do fire it up!
dragonbud0 12-01-2012 12:43 PM
For convergence checking w/o tool, I put on 007 Casino Royale BR with Bond on the Beach scene (nice and bright), then look at either the upper or lower left, where the black bar and the actual movie content line/edge for any colors, other than black or blue (sky or water color). Any extra colors indicate convergence issue.
My understanding that new JVC or Sony should NOT have this issue.
Have fun w/ your new toy.
Mike Garrett 12-01-2012 01:16 PM
You need the SLB281 plate. Give me a call and I can add it to your preorder. Also I did not see a drop tube. You need that to connect the ceiling plate and mount together. A pipe nipple also works.
Dragon Reborn 12-01-2012 04:51 PM
Thanks for your response, Mike, but I may end up using my original mount.
Because after doing a bit of searching, I found Ralph Potts' post detailing his success with the same mount on his JVC, linked here:
http://www.avsforum.com/t/1283884/ceiling-mounts-fo-jvc-rs-40-50-60/120#post_19669256
NGiovas 12-01-2012 05:52 PM
Subscribed. I just got confirmation of my order from Mike today. This will be my first projector. Unfortunately, the theater isn't quite ready for it. This will be incentive to work faster smile.gif
Dragon Reborn 12-01-2012 05:58 PM
I haven't ceiling mounted it yet so I have it on a table, level with the bottom edge of the screen, projecting from 10 feet onto a 100" SeymourAV (minimum throw). Here are my initial impressions;
Quiet. This projector is very very quiet. It's much quieter than my Optoma was. If I select the 3D mode, only then would it get as loud as my Optoma. Quieter than my PS3. High lamp mode is similar to my PS3 when the PS3 starts to run hot and its fan revs up; and only slightly louder than the Optoma when in this mode. Excellent as far as I'm concerned.
IR remote works effectively when I point it at the screen. Better than my Optoma.
It's also nice and bright enough on low lamp mode, even with moderate room lighting (side pot lights on full, and wall sconces at half power).
After applying vertical and a tiny bit of horizontal lens shift, I checked focus uniformity using a 1-pixel test pattern, courtesy of sarangiman. No problems, edge to edge, corner to corner. Excellent.
Other than checking focus, I haven't checked convergence or anything else. I havent touched ANY settings. Basically, i just put it in Cinema mode for now so I can enjoy a movie this evening. Going to initiate it with The Dark Knight Rises. It should be a good premiere movie, I'm thinking. smile.gif
wildcard011 12-01-2012 06:09 PM
Enjoy and let us know your thoughts after the movie. I just confirmed my order with Mike for the 4810 today smile.gif
tigerfan33 12-01-2012 06:13 PM
How is sharpness, brightness compared to your DLP? How many hours was on the Optoma lamp?
What is your aperture setting on?
You are right Dark Knight will make your 46 shine:)
Dragon Reborn 12-01-2012 09:25 PM
I had about 900 hours on the Optoma bulb. With the JVC still on low lamp mode, the JVC brightness was definitely better, and more importantly, brighter while still maintaining good contrast and colour accuracy. Definitely better brightness with room lighting on.
I didn't do any pixel-level A-B testing between the (720p) Optoma and JVC, but sharpness at 1.5X seating distance was plenty sharp for me (at least equal to the DLP).
Watching TDKR with the lights off, I started the movie with the aperture at 0. Ended up settling on -10 which felt quite comfortable for viewing. I watched it on low lamp mode, but would probably open up the iris for ambient lighting.
hskang7 12-02-2012 12:00 AM
wow, 100 inch kuro!
I wonder if you checked out the 3d?
is it bright enough?
also, i wonder if the fan noise in high lamp setting is too loud.
TwisTz 12-02-2012 01:37 AM
How accurate is the color on the X35? Does not having CMS mean that we won't be able to get accurate color?
Dragon Reborn 12-02-2012 06:47 AM
Originally Posted by hskang7 View Post
wow, 100 inch kuro!
I do not have the 3D emitter or glasses yet. They are on the way. So I can't say if it's bright enough yet. But even when I get it, I will only have one 3D Blu-ray to view: Prometheus.
The fan noise in high lamp was slightly louder than my Optoma HD72. If I were to guess, I would put it in the high 20s db. With the projector directly above my head, I don't think it would bother me.
First off, you need to understand who I am: I have no calibration equipment, I have never had my projector (or Kuro) calibrated in the past, and I probably won't. My experience is purely that of an untrained noobish eye. To put that into perspective, I am the kind of person who bought a Kuro instead of a Kuro Elite.
Having said that, right out of the box, by simply setting it to Cinema mode and adjusting the lens aperture to -10, at no point during TDKR did I feel the colour was off. If I were to adjust any other settings, I'm sure it can be even better, but at this point, I haven't a clue of what to try first. For me, not having CMS is ok for the $1200+ that I saved vs the RS48. But I know for purists and more experienced users, CMS would be a necessary feature. So what I'm saying is that the colour was enjoyable ... this is purely subjective. For a more objective review, I would wait for the true reviewers (e.g. Zombie10k) to share their opinions.
But if anyone would care to share any tips or calibration settings, then I would be happy to report the differences to the forum. Thanks for looking.
Dragon Reborn 12-02-2012 07:37 AM
Originally Posted by freebits View Post
Having a little fun ... and a nice shoutout to this helpful forum. smile.gif
Originally Posted by SED <--- Rules View Post
Congrats Dragon Man, that is a HUGE difference in size compared to you old Optoma projector. Geez. Let us know what you think of it when you do fire it up!
Huge difference indeed! You can read all the specs you want, but once you get it in front of you, and try lifting it, only then do you realize the size you're dealing with. As a result, I will need to re-evaluate my ceiling mounting construction. I was going to use a 9"x18" piece of 3/4" ply on top of 5/8" ceiling drywall, directly connected to 2 floor joists at each end of the ply. But now ... I may cut out some of the ceiling drywall so I can fit a 2"x8" cross beam between the joists. Then I can have a central point of attachment for the plywood and Chief mount.
Unfortunately, I don't have that movie and will have to ask around for it.
hskang7 12-02-2012 11:14 AM
I thought they include the glasses and emitter with the projector.
guess not.
i just ebayed the glasses and emitter and no one's selling.
projector is out but no glasses available??
hskang7 12-02-2012 11:15 AM
guess not.
Dragon Reborn 12-02-2012 11:21 AM
guess not.
Yes, they are definitely not included in the box. I'm not sure when my glasses and emitter will ship.
Tacklebary 12-02-2012 11:52 AM
Wow...that is high praise for this unit so far! I am also a kuro owner and hoping that I won't be disappointed in going from an elite plasma to a 100 inch screen with the x35 or x55.
Mike Garrett 12-02-2012 01:29 PM
Much easier to just place two layers of 3/4" plywood on the ceiling. Place some trim around the plywood to make it a nice raised panel. Two layers of 3/4" will hold up way more that you need.
Projofan 12-02-2012 02:39 PM
First measures (by a professional) : http://www.homecinema-fr.com/forum/post177326667.html#p177326667
Dragon Reborn 12-02-2012 03:15 PM
Well, maybe I was exaggerating a little, but not by much I think. Before, there was always a marked difference between watching the Kuro and the Optoma. Now, much much much less so.
Great idea, thanks. It will be a lot less invasive on the ceiling that way too. I'll just have to re-work the current 9"x18" piece that I already finished (trim and painted).
zombie10k 12-02-2012 03:22 PM
there is some good info in that post, thanks for posting it here.
rmaddog 12-02-2012 08:24 PM
Ditto. I got my RS46 pre-order confirmed yesterday as well. Wonder when it will actually get here? Sometime soon but regardless I have slacked and my room isn't near ready so I need to get my tail into high gear! This is my first projector and I am pretty excited.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
