Sony HW 50 ES vs 95 ES - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-30-2012, 02:03 PM - Thread Starter
Sean Mckenzie's Avatar
Hi, I am a long time lurker looking for some advice. We are currently constructing a home theater and are trying to decide between the 50es and 95es.
The screen will be approximately '135 feet and the projector is going to be placed towards the back of the room approximately 14 feet.
The projector will be used for movies, gaming and very occasionally, sports.
My questions are, will there be an update to the 95es soon? What set it apart from the 50es and are there any benefits to buying the 95es over the 50es?
Sean Mckenzie is offline
post #2 of 7 Old 11-30-2012, 05:24 PM
xb1032's Avatar
Liked: 26
Neither of those projectors is going to fill a 135 feet screen and definitely not from a 14 ft throw either.
On a 1.0 gain screen from 14' and a 135' diagonal screen according to ProjectorCentral you will get 9FL from the 95ES and 14FL from the HW50.
From my research the HW50 is a bit brighter, may have slightly less ghosting, if using FI in 3D the HW50's FI is more aggressive giving more of a video look, the lens is not as optically sharp as the VW95ES and therefore needs Reality Creation(RC)to make up the difference. RC seems to be liked my many in the lower settings and does work in 3D and gives the overall picture a sharper image but noise and artifacts can be apparent in lower quality video. The first HW50ES do have a slight whine when being viewed in 3D. From what I've read in the US, Sony will presently provide an external emitter free of charge.
The VW95 has slightly better black levels (not sure how much), has a powered lens with lens memory, and as mentioned has better optical sharpness. The VW95 does not have the RC feature.
xb1032 is offline
post #3 of 7 Old 01-07-2013, 06:42 AM
timatraw's Avatar
Quoted: 24 Post(s)
Im looking at a 50ES.
Will a throw distance of 18' be okay with a 123" screen?
timatraw is offline
post #4 of 7 Old 01-07-2013, 07:11 AM
fingersdlp's Avatar
Quoted: 105 Post(s)
Liked: 66
Yes. Take the screen width and multiply by 2.13 to get the farthest back you can put the projector. With 16:9 screen that would be around 107 wide so about 19 feet. My measured max throw was actually 2.16 so you can probably go even further back.
fingersdlp is offline
post #5 of 7 Old 01-20-2013, 07:35 PM
SteveR1952's Avatar
Is there really enough difference between the two units to justify the higher cost?
SteveR1952 is offline
post #6 of 7 Old 01-20-2013, 07:40 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
Yes. You get a much better lens in the 90ES. I think that alone warrants the difference of cost, especially considering the street cost difference on this is less than $1000. You'll also get better black levels, motorized zoom, shift, and focus, along with a lens memory system if you want to do an anamorphic screen setup. If you want an RC type system just buy a Darblet. The only advatage the 50ES has over the 95ES is the 3D performance is better and it's a little brighter.
Seegs108 is offline
post #7 of 7 Old 01-20-2013, 07:51 PM
Browninggold's Avatar
Liked: 37
I would pick the 95 over the 50. For the reasons mentioned above. Sharper image and motorized zoom/shift/focus.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
Sony Vpl Hw50es 3d Projector , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
