EPSON 6020 Owner Thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 178 Old 11-20-2014, 09:48 AM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Originally Posted by shaggy2002 View Post
I have had my Epson 6020 for 2 years and 2 months. I have been noticing the screen flickering more and more over time ...
Shaggy, check this out.
BTW, getting Jeff to calibrate our 6020 was the best thing we ever did. Even my wife was blown away. Doing that after a lamp change would be perfect timing.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is online now
post #152 of 178 Old 11-20-2014, 08:16 PM
shaggy2002's Avatar
I guess I will attempt to replace my bulb this weekend. Where is Jeff located?
shaggy2002 is offline
post #153 of 178 Old 11-21-2014, 06:34 AM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
I think he lives somewhere out near Lake of the Ozarks, but he has a national audience, and travels to most major US cities once or twice a year. Check out the accucal.com site for details or I can just pm you his email address. He also does that blog that I sent the flickering article from. Lots of good stuff there. He gave the 6020 a best in class review after calibrating mine. I had tinkered with mine a bunch, but he just nailed it. Cheers.
post #154 of 178 Old 11-21-2014, 09:09 PM
shaggy2002's Avatar
I checked the site out. It looks like I just ask for someone and they send an available technician? If it is not too personal, can you PM the rate for the calibration and his email address?
post #155 of 178 Old 11-21-2014, 10:54 PM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Happy to send. But it is Jeff, and only Jeff. Nobody else. Big plus.
post #156 of 178 Old 11-22-2014, 01:25 PM
Yzfbossman's Avatar
Liked: 55
+1 for Jeff. I had him calibrate my 6020 and adjust my audio. Both produced noticeable improvment.
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #157 of 178 Old 11-22-2014, 10:17 PM
kingpin748's Avatar
Well I went to watch a movie tonight and nothing happened. I checked out the projector and both the temperature and lamp lights were flashing red. Manual says to unplug it and call Epson but since they aren't open until Monday I tried unplugging it for a bit, turning it on and off using the the switch at the back, and just for the hell of it I tried swapping out the bulb with the spare that came with it.
Nothing. When you turn it on the fan kicks in for about 2 seconds and then it shuts down with the 2 lights flashing red.
Any suggestions?
For what its worth I've never had an issue with this projector and I'm sure Epson will swap it out but that still means no Far Cry 4 until next weekend. I couldn't possible play games on my 55" Samsung like some kind of troglodyte.
kingpin748 is offline
post #158 of 178 Old 02-15-2015, 09:02 AM
rb47's Avatar
Any suggestions?
kingpin748, did you get the issue fixed? The same thing just happened to me. I tried leaving it unplugged for a while but I get the same red flashing temp and lamp lights.
rb47 is offline
post #159 of 178 Old 02-15-2015, 09:07 AM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
RB and Kingpin, how many run hours on your units the last time you checked that in the settings menu?
post #160 of 178 Old 02-15-2015, 09:34 AM
rb47's Avatar
I can't get into the menus but my Control4 system is showing 763 hours of lamp use. I installed the projector around July of 2013.
rb47 is offline
post #161 of 178 Old 02-15-2015, 06:34 PM
rb47's Avatar
I think the issue might have been with the motorized lens cover. I manually opened the sliding cover and then turned it on. This time no blinking lights.
My guess is if the motor senses too much resistance it give the error condition. It turned on OK twice so I am keeping my fingers crossed.
rb47 is offline
post #162 of 178 Old 02-15-2015, 09:19 PM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Sweet. Thanks for the update. Are you still on the original lamp? And if you can, go into settings and post back with how many run hours you have on your 6020. Glad you're back in business. 👍
post #163 of 178 Old 02-16-2015, 09:34 AM
rb47's Avatar
I am on the original lamp. I did go in last night and check the run time, it was around 970 hours.
rb47 is offline
post #164 of 178 Old 02-16-2015, 09:24 PM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Thanks RB, good to know.
post #165 of 178 Old 07-07-2015, 04:08 PM
Liked: 0
Sorry to resurrect and old thread can any of you owners chime in as it would help me in making my decision between a 6020 and a 6030.
1. the room its going in will have tons of ambient light. So not sure if the extra contrast ratio will make a difference.
2. It will be paired with a black diamond zero edge screen. May go for the 2:35:1 aspect ratio still on fence between 16x9
3. Stuck on the fence between split screen 6020 and picture in picture 6030. - have any owners utilized the 2 features on the models. I have an hdfury so I can convert vga and component inputs to HDMI. So then I should be able to use the split screen or pip with 2 hdmi sources.
4. Is the picture really that much different between the 2 series.
5. Will be using 3d and 2d features. preferably 3d blurays if I go with split screen then watching cable tv.
6. AV unit does multi zones. so getting a signal to it wont be a problem
nigwhyritos is online now
post #166 of 178 Old 07-08-2015, 04:31 PM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Originally Posted by nigwhyritos View Post
... can any of you owners chime in as it would help me in making my decision between a 6020 and a 6030 ... it will be paired with a black diamond zero edge screen. May go for the 2:35:1 aspect ratio still on fence between 16x9 ...
Can't help much, but ordinarily wouldn't you prefer going with the newer model? If they're at roughly the same price point, that's what I'd do. Or spend a little extra for one of the new Epson laser models. :-O
Our 6020 is paired with a Black Diamond 1.4 gain screen and it works. Are you buying the screen, or do you already have it? The only issue that distracts me with the Black Diamond are the sparkles on the white sections of a bright shot, but obviously gain is always a trade-off, and you already know all about that.
On the split versus PIP, I've always found PIP more useful for my limited needs, but you probably know how you'll use that specific feature, and which would fit you best. In the room where our Epson is installed, we use it exclusively to watch things in a pretty focused way, so splitting the screen is something we really don't do in there.
Good luck and post back with impressions once you buy.
post #167 of 178 Old 07-08-2015, 08:44 PM
Liked: 0
[Can't help much, but ordinarily wouldn't you prefer going with the newer model? ---> only if the newer model makes a real noticeable difference. look at how many peole buy used cars lol.
If they're at roughly the same price point, that's what I'd do - laser projector -- lol might as well get the sony if I was going to spend that much with true 4k panels.
6020 I can get for under $2,000 | 6030 is almost 3,500 |
The only issue that distracts me with the Black Diamond are the sparkles on the white sections of a bright shot, but obviously gain is always a trade-off, and you already know all about that.-
Worried the 6030 will make more noticeable sparkles on the screen as its brighter and has higher contrast ratio.
I was thinking of splitting it for sports and tv. wife can watch what she wants. I could use headphones. or 2 different movies at the same time.
mad at epson for removing that feature on the newer model.
they both do anamorphic stretch. Besides the sparkles are you satisfied with the 6020 or have you seen the 6030 demoed. I cant find no one in my area to demo either. Also worried since 6020 is discontinued why they took it out of service.
post #168 of 178 Old 07-13-2015, 08:59 AM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
... only prefer if the newer model makes a real noticeable difference ... 6020 I can get for under $2,000 ... 6030 is almost 3,500 ... they both do anamorphic stretch.
Besides the sparkles are you satisfied with the 6020 or have you seen the 6030 demoed ... Also worried since 6020 is discontinued why they took it out of service.
Sorry late reply. At those price points, I hear you on leaning toward the 6020. I have not seen the 6030 in service, but the products are very similar. At those price points, it would be an easy choice for me.
We love our 6020UB. It's been in flawless service for 2+ years now. Very bright, very color accurate, great blacks, and sneaky sharp for it's price class. Couldn't be more pleased with it. We will keep it for at least a couple more years, with a 4K pj as it's long term replacement some day.
And I don't blame the 6020 for the sparkles. The screen gain is the cause, but I don't blame the screen either. It was a trade-off, and I knew that going into it. Plus I'm the only one that notices em anyway. :-O
The one thing I would recommend, especially since you're saving a nice chunk of cash by going with the 6020, is to get somebody really, really good to do the calibration for you. Jeff Meier calibrated our new 6020 after we'd watched it (very happily) for a couple months. I had done some good tweaking, but in 3 hours Jeff turned that 6020 into a complete bad a**. (He's got a huge passion for the work, and owns a ton of expensive tools that I could never rationalize buying.) Most folks that watch a Blu-Ray play in our room since then say its head and shoulders the best image they've ever seen.
BTW, if you're on the fence, here is Jeff's review of the 6020, which he wrote immediately after calibrating our machine.
There are a bunch of good machines out there, so good luck with whatever you do!
post #169 of 178 Old 07-15-2015, 09:02 AM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 2130 Post(s)
Liked: 1142
You going to m anually adjust, at the projector, lens shift and zoom, everytime you switch back and forth from 16:9 to 2.35? That will become a pain, real fast. The 6020 does not have lens memory, neither does the 6030, so 2.35 is not a good choice, unless you are getting an A-lens and or a Lumagen video processor. If you want to go 2.35, and not buy anything extra, then you need a projector with lens memory, like the JVC's
AV Geek for life. :) Call for advice and help.
Mike Garrett is online now
post #170 of 178 Old 07-25-2015, 02:55 PM
Liked: 0
Thanks for all the input but I ended up going with the 6020 for 1,900 with 377 on the original bulb and a new sealed spare bulb with chief mount and 4 pair of the Epson 3d glasses.
The main reason I decided against the 6030 was the pip vs split screen. Right now I use a hdfury connected to the component input so I can run hdmi from my TiVo for the wife
and the main hdmi goes to the mutli zone SONY av unit. I also use wireless hdmi. We don't have to fight over the tv with the split screen.
I just wish I could have seen the 6030 in action with the frame interpolation in 3d. I read the 6020 doesn't do that or super resolution in 3d.
My 3d collection is at 150 movies. I ts a huge step up from my 2 ) 24 inch sony ps3 3d tvs
post #171 of 178 Old 07-28-2015, 11:05 AM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Thanks for all the input ... I ended up going with the 6020 for 1,900 with 377 on the original bulb and a new sealed spare bulb with chief mount and 4 pair of the Epson 3d glasses ... My 3d collection is at 150 movies.
Sounds like a good deal. You will be very happy with the 6020's 3D performance. Urge you to plow some of the money you saved into an excellent ISF calibration. BTW, I like 3D, but at 150 movies you're lapping me several times over. Post your titles somewhere for us to see. Cheers!
post #172 of 178 Old 08-04-2015, 06:28 PM
rb47's Avatar
So I am having the issue with the red lamp and bulb lights flashing. I have left the PJ unplugged for days and it still happens. I also tried manually opening the lens door which seemed to work for me before but nothing.
So I called Epson support. They asked a few quick troubleshooting questions and said the flashing red lights on startup means there is an internal issue and it probably needs to go in for repair. I have him the serial number of my unit. He checked and he said that it is showing up as an international unit. So it is not covered by the US warranty service.
I told him I purchased it from Echo and Optics. He said I should contact them and see if I can get it straightened out.
I have been calling Echo and Optics for two days but always get a recording to leave a message. I left a message but have not heard back. I also sent them an email.
Has anyone else purchased from Echo and Optics? Or has anyone had an issue with Epson saying it was an "international" unit?
rb47 is offline
post #173 of 178 Old 08-05-2015, 12:02 PM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
... Has anyone else purchased from Echo and Optics? Or has anyone had an issue with Epson saying it was an "international" unit?
My answers won't help, since they're no and no. How many hours on your 6020?
post #174 of 178 Old 08-05-2015, 05:29 PM
DTI
DTI's Avatar
you might want to check this thread out and post in there for help I think it might be the same issue Epson 5010/6010 'Cinema filter Error', grinding noise, red light fix with pics
DIY dust box / hush box / ceiling light... http://imageshack.com/a/img538/4072/C9XDR7.jpg
DTI is offline
post #175 of 178 Old 08-08-2015, 03:44 PM
HDLife's Avatar
Quoted: 18 Post(s)
So MoGrub, are you projecting our 6020 onto a 152in screen at 2.35:1 dimension? How is it exactly?
HDLife is offline
post #176 of 178 Old 08-10-2015, 10:04 AM
mogrub's Avatar
Quoted: 203 Post(s)
Liked: 173
Nope! I'm projecting the 6020 on a 110" screen at 16 x 9 (1.77:1), so I'm not gonna be able to give you much insight on the screen you describe. Sounds cool though.
post #177 of 178 Old 08-10-2015, 11:37 AM
Chucklesmcgee's Avatar
I have had a 6020 since April of 2013. I have noticed there is a spot on the left portion of my screen that seems out of focus. I would like to use the menu to calibrate and align my projector but am not very tech savvy. Can anyone post a link on how to the use the LCD alignment tool on the 6020? Many thanks in advance.
Chucklesmcgee is offline
post #178 of 178 Unread Today, 06:54 AM
Liked: 0
I have my new to me 6020ub firmware 1.03 now for about a month. Thank you all for the tips on the green dust blobs/dirt. I Took a vacuum cleaner to mine and it fixed my issue. New question now.. not sure if this is meant for the CIH forum or here.
I have the hdfury 4 or 3d fury. It says can used as a scaler. Could I use this with the anamorphic setting on the 6020 to achieve the look of no black bars in the wide Blu-ray format - 2:40 AR. I'm still trying to understand all this. Or would a external lense like panamorph still be required for that 2:40 native not stretched look.
I attached a link to the manual- i'm looking at page 17 specialized functions - http://www.hdfury.com/docs/HDfury4Smanual.pdf
