NEW JVC DLA RS66/X95 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 139 Old 09-12-2013, 07:13 PM
Wickerman65's Avatar
Thanks for the replies everyone. JonStatt, you're pretty much spot-on with your assessment of 80 ms of latency. I've painstakingly adjusted my audio delay to 78 ms - and I did so before even seeing your post.
Wickerman65 is offline
post #122 of 139 Old 10-29-2013, 08:57 PM
drvais's Avatar
Quoted: 98 Post(s)
Liked: 58
I had my X95R ISF-calibrated last week. Below you'll find the results. Are these results pretty close to what others have seen post-calibration?
unOFFICIAL D-Box FAQ here!
unOFFICIAL D-Box HEMC FAQ here!
Hail to the King, baby!
drvais is online now
post #123 of 139 Old 11-18-2013, 04:26 PM
TK-713's Avatar
Quoted: 18 Post(s)
Just wondering is there firmware update for the jvcx95? I see that on the uk av fourms there was a firmware fix regarding 3d shift or something like that. I looked on the us website and nothing.
TK-713 is offline
post #124 of 139 Old 11-23-2013, 07:20 AM
drvais's Avatar
Quoted: 98 Post(s)
Liked: 58
Just noticed a weird white level carry-over bug in my X95. If you start by using the THX (which uses the Super White mode), then select one of the unmodified User modes (using the Standard white level), the Super White mode's attributes briefly carry over. I determined this using the Spears & Munsil 2nd Edition disc's contrast pattern.
Along with the discovery, I've learned that contrary to what some reviewers and posters have said, it seems the projector is most accurate on the contrast front when the Super White HDMI mode is engaged.
Using the S&M 2nd Edition contrast pattern, you will be able to clearly see the projector clips the contrast bars in the Standard HDMI mode. It pretty much looks like this:
However, with Super White HDMI mode engaged, the bars display properly as seen below:
post #125 of 139 Old 11-23-2013, 06:07 PM
MikeyD360's Avatar
Liked: 26
I think it depends on the other eqipment in your chain.
The X-95R has three settings; standard, enhanced, or Super White.
In my room when I select super white I get the clipped levels that you show in the contrast pattern, but when I select 'enhanced' then it displays as it should.
MikeyD360 is offline
post #126 of 139 Old 11-23-2013, 06:31 PM
drvais's Avatar
Quoted: 98 Post(s)
Liked: 58
Interesting.
post #127 of 139 Old 11-25-2013, 12:33 AM - Thread Starter
RapalloAV's Avatar
Quoted: 1302 Post(s)
Liked: 292
I have no clipping if I use Enhanced, and that's what I do.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #128 of 139 Old 12-04-2013, 05:15 AM
tvolle's Avatar
Liked: 34
Just one more: I use Enhanced to prevent the clipping.
tvolle is offline
post #129 of 139 Old 01-02-2014, 02:57 AM
About a week ago, my projector lamp started making a 'rattling' type noise and nothing I've tried has caused it to subside. Has anyone else experienced the same problem with the DLA-RS66U? The projector used to be so quiet and now it's very distracting to hear this noise, especially during dialogue scenes or quieter moments. And, no, I don't have the projector mistakenly set to 3D for brighter (and louder) lamp mode. My projector is only a couple of months old. Thanks.
post #130 of 139 Old 01-03-2014, 12:09 PM
crtguy's Avatar
Sounds like it may be the fan. Better contact your dealer or JVC support.
crtguy is offline
post #131 of 139 Old 01-22-2014, 02:51 PM
mntwister's Avatar
Here is my situation:
I bought the new RS 4910. I had it calibrated. It measures 630 lumens low lamp and 880 with high lamp. This is on my 159" 2.4 gain screen. Low lamp measured 13 fl and high lamp 19 fl.
I have a chance to pick up an RS-66 at an incredible price, I could sell my 4910. But the 66 specs say 1200 lumens and this year's models (4910) states 1300 lumens.
Do you think the one I have is brighter or will the RS-66 be brighter. I am not be any means an expert at rating brightness. I know since the RS-66 parts are all matched and hand picked, quite possibly it could still be brighter than the 4910.
Any opinions?
mntwister is offline
post #132 of 139 Old 01-22-2014, 03:06 PM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
Any opinions?
Did you see the email I sent you this morning or get the phone message I left you?
To answer your question, the 4910 is brighter than than the 66.
mjgarrett100@gmail.com
Mike Garrett is online now
post #133 of 139 Old 01-22-2014, 03:08 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
You are not going to notice any brightness difference. They both use the same lamp. Unfortunately your screen is too big for a JVC unless you get a smaller HP or use low lamp until you drop below a brightness level you require then switch to high lamp.
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is offline
post #134 of 139 Old 01-22-2014, 04:54 PM
mntwister's Avatar
No Mike, I temporarily lost my cell phone and have been on an all day search, and I didn't check my mail lol. I will get right on it. Thank you.
post #135 of 139 Old 01-22-2014, 05:14 PM
mntwister's Avatar
Mike, I just sent you an email with the information. I was talking to someone I know in California and their good friend had bought an RS-66 and only used it 100 hours, so I was just curious about it as it's lower in price than the RS-57 pre-order price, he just wants to sell it off. I figured I could sell my replacement for the 4910, but I am not sure how much better the RS-66 would look.
post #136 of 139 Old 01-22-2014, 05:16 PM
mntwister's Avatar
Mike
My last projector was the RS-50 which I had for three years, and on the 159" screen it seems nice and bright, but also I do have a 2.4 gain DaLite screen.
post #137 of 139 Old 01-22-2014, 05:58 PM
Liked: 3554
The email did not come through. Could you send it again?
post #138 of 139 Old 01-22-2014, 05:59 PM
Liked: 3554
An RS66 is brighter than the RS50.
post #139 of 139 Old 05-20-2016, 03:02 PM
Unclejeff's Avatar
The warning about replacing lamp had been showing for about 10 days when the projector shut down as lamp had exceeded allowed hours.
I installed a new lamp and experienced serious improvement in picture quality.
Lesson learned: don't hesitate to replace lamp as quality was degrading even before alert comes on.
Unclejeff is offline
Jvc Dla Rs66
