JVC projectors and dust blobs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-10-2012, 05:50 PM - Thread Starter
caperguy33's Avatar
Hello everyone, I was wondering if dust blobs were an issue with jvc projectors? I understand that the lightpath is sealed. Does this mean there is no chance of dust? I am on the fence with the jvcx35 . I am coming from an Epson 1080ub which is 2 years old. (bought is refurb). Dust can be an issue with the epsons in the past. Also with the jvc x35 I am concerned with it needing a firmware update for 3d out of the box. If there was an issue do you think suppliers stock would be affected or would the new firmware already be flashed? I am from Canada and I have until Dec 12, to make the preorder on the jvc.x 35. Thanks for your help.
caperguy33 is offline
post #2 of 3 Old 12-11-2012, 02:58 PM
kkpro's Avatar
Quoted: 135 Post(s)
Liked: 73
JVC's have a sealed light path. No dust blobs. Typically, that seems to be an issue with lcd projectors (although DILA is kind of a hybrid of lcd.)
kkpro is offline
post #3 of 3 Old 12-11-2012, 04:43 PM - Thread Starter
caperguy33's Avatar
Thank you for your response.
Jvc Dla X35 3d Hd Front Projector
