Is jvc hd250 bp being replaced by x35? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-12-2012, 04:06 PM - Thread Starter
yourtoys7's Avatar
Hi, I'm looking into helping buy hd250 model for a friend, but getting little confused if this model gone and not being replaced, or is the X35 the replacing model?
sorry if this is wrong place, I just wasn't sure.
EluneVision 106" Reference Studio 4K Tab-tensioned - 1.0 Gain, Benq 1070, psb T6, Rotel, OPPO, Velodine (Now),
135" AT screen, JVC-X35, 3x RF82, 3x Emotiva XPA100, Velodine, Rotel, OPPO (Sold with house).
yourtoys7 is offline
post #2 of 9 Old 12-12-2012, 05:11 PM - Thread Starter
yourtoys7's Avatar
only 2D use, 16x9 135" dark/ black room, 20ft. away.
post #3 of 9 Old 12-12-2012, 07:24 PM
Kelvin1965S's Avatar
Quoted: 283 Post(s)
Liked: 184
The X35 is the same machine as the RS46 so it's not a 2D only option as such, though I did buy mine without 3D glasses or emitter as I'm not bothered by 3D and it saved me £300 in the UK.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #4 of 9 Old 12-12-2012, 07:49 PM - Thread Starter
yourtoys7's Avatar
soo there is no 2D model, and X35 is their entry level? would 250 still a good buy or?
post #5 of 9 Old 12-12-2012, 07:51 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
It depends on what price. If it's going to cost you more than $1200 I wouldn't waste my money. Especially with newer models going for almost as cheap in the used market. I picked up a refurbished JVC DLA-X3 for $1499 last month. The X3 is a fantastic unit and a big step up overall from the 250 in my opinion. The x35 should be close to the X3's performance.
Seegs108 is offline
post #6 of 9 Old 12-12-2012, 07:56 PM - Thread Starter
yourtoys7's Avatar
yes, double that (: Maybe jvc X35 than! where did you find refurb.? is the warranty still same 2years?
post #7 of 9 Old 12-12-2012, 08:09 PM
Seegs108's Avatar
Liked: 2581
I purchased it on eBay so there wasn't a warranty. If purchasing a refurb unit you need to buy it from an authorized dealer to get the warranty. Give AVScience a call they have great prices on refurb and B-Stock units.
Seegs108 is offline
post #8 of 9 Old 12-12-2012, 08:18 PM - Thread Starter
yourtoys7's Avatar
thanks.
post #9 of 9 Old 12-13-2012, 01:54 PM
Quoted: 283 Post(s)
Liked: 184
I just upgraded to the X35 from a HD350 (same as the HD250 but with a glossy black case). While some of the improvements are down to a new lamp in the X35 compared to a half dimmed lamp in the HD350, there are enough improvements in the picture quality (sharpness/contrast/motion) to make me pleased with my upgrade. I've only bought this for 2D use (no 3D glasses or emitter to save £300 in the UK). It depends on the price difference and your budget of course.
Jvc Dla X35 3d Hd Front Projector
