Lens Zoom VS. Throw Distance question - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2012, 01:22 PM - Thread Starter
tothjm's Avatar
Hey guys,
I am thinking about pulling the trigger on the HW50ES Sony Projector and this will be my first projector and I just have a question:
I know that the more you zoom in, the bigger but dimmer the picture gets as less light can shine through from what i understand, so my question is... is it btter to have 1.0x zoom ALL the time, and just put the projector at the correct distance for what screen size you want, or is it better to find a middle ground of each... projector closer, with some zoom,
I am just trying to understand what produces the brighter better picture when using both zoom and projector throw distance... and which is the way you always want to go... less zoom and more throw vs more zoom and less throw
Hope this makes sense.
tothjm is offline
Old 12-21-2012, 01:39 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Usually most projectors don't have a throw ratio of 1.0. Going from memorary the Sony has a minimum throw, the closest one can place the projector and still fill the screen of 1.37 times the screen width (1.78 aspect screen) or so and a max throw of 2.23 times the screen width. I didn't look them up but they are posted in the threads. I am probably slightly off. The closest throw maximizes brightness and minimizes on off while the longest throw minimizes brightness but increases on off. Generally, if one has sufficient brightness and this depends on screen size and screen gain, long throw is preferable because optically that is where the lens performs best, the image occupy an area the is or is close to the sweet spot. The area of the lens which is flat instead of curved or less curved. Also screens with gain work better at long throws which has to do with the angle the light hits the reflective layer of the screen. With a specic throw distance, there is only one correct zoom setting and visa versa. They go hand in and hand, and picking one mandates the other.. Hope this helps and if you don't understand this just give me a call and I would be glad to explain further.
BTW Always stay at least a few inches away from the closest or the farthest throw to allow ffor a little measurement mounting area and the fact that manufacturers tend to push the lens throw numbers to a little beyond where the lens for other factors might perform better.
timescape7 likes this.
mark haflich is offline
Old 12-21-2012, 04:39 PM - Thread Starter
tothjm's Avatar
Hey thanks for taking the time to write back
I think being my first projector some of that was missed by me. perhaps i was looking for a less technical answer smile.gif
my max throw for my current apartment would only allow around 11-11.5 feet max, so i think having it around 10 - 11.5 would be fine for the small screen size i will be doing ( i still need to measure but it will be maybe 96 in or so, i will have to test it out once i order the projector.
mainly i was just trying to see how to get max brightness and if going with the rule of sticking as close to 1.0x zoom was the answer to that or not. it seems the answer is much more technical than that.
what did you mean when you said the " on off " ? Not sure i follow that one ?
I will have to check on viewing distances and such for the Sony HW50ES to try to figure what kind of a screen i can manage well at the 11 foot range or if i even need to go back that far. I really want to keep as many of the lumens as i can.
tothjm is offline
Old 12-21-2012, 05:03 PM
Liked: 1010
Te brightest will be at short throw. Throw distances depend on the width of the screen and can be any number between the long and short tyhrow range time the screen width. Suppose your screen is 7 ft wide. The closest throw would be 1.37 (or whartever the actual number is) times 7ft. That will give you the brightest picture but not the best. For a small screen you will not need the extra brightness. The dimnest but perhaps the best picture would be at mounting at long thrw, 2.2 or whatever times the screen width. The trade off between maximum brightness and maximum contrast is not linear between the two extremes. It is a log function. Rather than make me type, please just call and I will walk you through it all and answer the questions that will arise you being a newbie.
Old 12-21-2012, 08:44 PM
timescape7's Avatar
Mark, can you explain the on off part? Are you referring to contrast?
Tothjm, good choice with the hw50es!
timescape7 is offline
Old 12-21-2012, 08:54 PM
Liked: 1010
The on/off contrast, one of the holy grails of projector performane goes up as one zooms the picture smaller. depending on the zoom ratio, the long throw multiplier divided bt the short throw multiplier the more the contrast will increase. conversely the more the light amount transmitted through the lens will decrease. The black reference level, more black as that level decreases, will also lessen because there is less leaking light at black because just like any light at long throw, less light can get through, the screen area of course remains the same, less light, same area, better blacks. With a small screen, just set it up at long throw, everything except maximum light out will be better and at small screen size you don't need the extra light.
Old 12-22-2012, 08:22 AM
kal
kal's Avatar
Quoted: 16 Post(s)
Liked: 70
The on/off is called "Contrast Ratio". It's the ratio of darkest to lightest and generally describes the "dynamic range" of the image.
The higher the contrast ratio, the more depth or realism the image has. High contrast ratio can almost appear 3D sometimes. Low contrast ratio looks washed out. Until recently CRT projectors were the holy grail of display devices that could give nearly infinite contrast ratio (due to the technology employed).
Low contrast ratio on the left, high on the right:
Not the best of examples but it gives a rough idea.
So normally what people want to do with digital projectors is to install as FAR BACK as possible (to increase contrast ratio) while maintaining an adequate level of light on the screen. For front projectors 14 foot lamberts of light is recommended (measured with a meter) though this can go lower and still appear ok if your room has very dark walls (bat cave). Digital projector bulbs dim over time so this has to be taken into consideration too.
Kal
kal is offline
Old 12-22-2012, 08:39 AM
Liked: 1010
Thanks for jumping in. I think your and my consecutive posts are the only two posts in the entire history of AVS to use the term holy grail without quoting each other.
Sony Vpl Hw50es 3d Projector
