No Power to JVC RS1 - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2012, 04:38 PM - Thread Starter
jlenz's Avatar
I was watching my JVC RS1 projector this evening and the power went out. When it came on 3-5 minutes later there is no power to the unit. I checked the plug and power is not a problem. There are no lights on the unit at all and I suspect there might have been a surge. There is no surge protector on this as it is plugged into my ceiling. Power has gone out 30-40 times over the years I have owned this and no issue before.
Is there any reset on the unit or something else I can do to test it? Thanks for your assistance.
Jim
jlenz is offline
Old 04-15-2014, 06:41 PM
shodoug's Avatar
I know this is an old thread, but it is new to me. Anyone know if there is a fuse or if the power supplies are still available?
Thanks to Shawn Fogg who posted a link to order parts. smile.gif If it needs it, it looks like I can get a power supply.
Now if I just had a service manual, I would be in business.
Doug
shodoug is offline
Old 04-16-2014, 06:26 AM
Angus.Young's Avatar
I don't need one at the moment.. but would you happen to have that link.. I don't seem to see it so I presume It was in another thread...
Angus.Young is offline
Old 04-16-2014, 03:23 PM
shodoug's Avatar
shodoug is offline
Old 05-05-2014, 07:45 PM
shodoug's Avatar
In case anyone is interested, I took it apart to check the fuse, which worked with both a meter and 120 VAC. Everything looked ok otherwise as well, so I put it all back together and it has worked fine for a week now...
I never found a service manual.
Doug
shodoug is offline
Old 11-10-2014, 10:53 AM
boontok's Avatar
Quoted: 13 Post(s)
Liked: 0
Waiting On Service Manual
I have a different issue with my RS1... no video input works except the composite. I called JVC service directly and am waiting on them to send me the service manual. I'll let you know what I find.
In the mean time, does anyone have a broken RS1 they would be willing to sell me?
boontok is offline
Old 11-10-2014, 11:51 AM
jlh304's Avatar
Originally Posted by shodoug View Post
In case anyone is interested, I took it apart to check the fuse, which worked with both a meter and 120 VAC. Everything looked ok otherwise as well, so I put it all back together and it has worked fine for a week now...<br><br>
I never found a service manual.<br><br>
Doug
Sometimes my RS1 stops working in a similar manner. I just unplug it from wall and in the morning plug it back in and it works again. I have tried shorter time periods like 30 mins and it didn't see to work. Just something for you to try. Might be similar in time that it took you to take apart and then put back together.
jlh304 is offline
Jvc Dla Rs1 Projector
