Can I put the Epson 5020UB in a cofee table??? - AVS Forum | Home Theater Discussions And Reviews
Old 01-02-2013, 01:44 PM - Thread Starter
adisonjim36's Avatar
So I am new to the Projector game and I am in a rental for about a year so I am limited by my options but I was wondering if I could put my projector in something like this? I would just open one (or two if needed because of heat) doors to hide the projector. Would this work? Also, I was just going to by an inexpensive pull down screen on ebay but was curious if you had any recommendations under $200 in the 100 inch range? Thanks guys. Based on my research this seems like a great all around projector. The top also lifts up on this table.
Jim
adisonjim36 is offline
Old 01-02-2013, 09:45 PM
domingos38's Avatar
Quoted: 22 Post(s)
Liked: 37
u mean inside ?
never put the projector inside anything .
it gets very hot and it needs air circulation
domingos38 is offline
Old 01-03-2013, 07:22 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
As long as your projector has lens shift you should have no problem at all. With non lens shift projectors the height of the table must be just right but when you have lens shift this is not a problem
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Epson 5020ub Powerlite Home Cinema 3d Front Projector
