decision time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-04-2013, 01:36 PM - Thread Starter
domingos38's Avatar
Quoted: 22 Post(s)
Liked: 37
i am trying to decide between the Epson 5020 and the Panasonic 8000.
I will have almost total light control in my HT
My screen is 130" but thinking of going down to 120"
will be used for 100% blurays and some very minor gaming.
which one should i go with?
and why?
Thanks for your help
domingos38 is offline
post #2 of 10 Old 01-05-2013, 10:04 AM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
Epson, it's brighter for 3D has less ghosting and better blacks. It's often sometimes a tad sharper (since no smoothscreen).
Longer warranty as well I believe.
Access HERE from this thread
coderguy is offline
post #3 of 10 Old 01-05-2013, 11:04 PM
tothjm's Avatar
of those 2, go with Epson,
Keep in mind you can also get the sony HW50ES for 2999, which makes it a strong contender as well.
tothjm is offline
post #4 of 10 Old 01-06-2013, 12:58 AM
Frosteh's Avatar
If you're set on those, get the 5020. I saw one and it looks great.
And now for the point you'll likely hear from most people in this forum: consider a JVC, even a previous model. If you're not interested in best-in-class 3D, you can have the RS40 or RS45 for between $1750 and $2500. 3D is still good, but 2D is where these projectors trump all else. My RS20 still puts out a better picture than most new stuff, save for a bit of motion blur due to slower panels. Just something to chew on!
Frosteh is offline
post #5 of 10 Old 03-04-2013, 10:11 PM
blg11's Avatar
Where can I get the hw50es for 2999?
blg11 is offline
post #6 of 10 Old 03-04-2013, 10:53 PM
Xank's Avatar
I bought both and returned one.
- Epson has more pronounced screendoor effect. If you don't like that, Panny's better.
- Epson was a lot louder. If you're sitting near the projector and care about noise, Panny's better.
- Epson had crap lens shift controls, but that doesn't matter after you've set it up.
- Epson (at least the unit I had) had a serious firmware bug with HDMI CEC that basically bricked the projector when HDMI-Link was turned on.
If none of the above are issues for you, I'd call it a toss up, slight edge to Epson for blacks.
As for me, I returned the Epson and kept the Panny. Loving it.
Don't go for a dirt cheap retailer. Use a good one, authorized. 2 out of 3 specimens I received were defective in some way or another and had to be returned.
Xank is offline
post #7 of 10 Old 03-05-2013, 02:22 AM
opv
opv's Avatar
The lens memory feature is an advantage for the Panasonic if you want to use a CIH setup.
opv is offline
post #8 of 10 Old 03-05-2013, 10:38 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
"Don't go for a dirt cheap retailer. Use a good one, authorized. 2 out of 3 specimens I received were defective in some way or another and had to be returned.ReplyQuote Multi 0 "
All the more reason to make AVS your first stop and likely last stop when purchasing your projector! wink.gif
Great service and nice pricing to boot!
Glenn Baumann is offline
post #9 of 10 Old 03-05-2013, 12:31 PM
Mike Garrett's Avatar
Quoted: 5563 Post(s)
Liked: 3542
mjgarrett100@gmail.com
Mike Garrett is offline
post #10 of 10 Old 03-05-2013, 02:05 PM
Quoted: 112 Post(s)
Liked: 125
Talk to Mike at AVS, I think you might be surprised at what you hear. Also there is rumor of a price increase or the free bulb promotion going away, so act fast. smile.gif
HT - JVC RS520 - Anthem AVM 60 - XPA-7 - XPA-5 - GE Triton 2 - GE Supercenter XXL - GE Invisa 650 x 8 - Xbox One - PS4 Pro - Oppo BDP-203 - Dual Rythmik FV15HP's - Lumagen Radiance Pro
My Media Room
kaotikr1 is offline
