Marantz VP4001 Not Working - repair or replace? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-14-2013, 10:33 AM - Thread Starter
patgrogan's Avatar
My VP4001 has served my well for the last 6+ years, but it has recently stopped working. I am only on my second bulb (only use it occasionally) and according to the projector, the bulb has about 35% lamp life left. I am curious to know a couple of things:
- The projector powers own, I get one solid green light and one flashing green light. After some time, the flashing green turns to a solid red light and nothing further happens. According to Marantz, this means that the bulb needs to be replaced? Is this possible? The bulb indicator shows 35% life left (got this right before it stopped working)....is it possible that need a new bulb when the indicator says I have 35% left?
- The projector is almost 7 years old....does it make sense to replace the bulb? Even if the problem is the bulb, how much life can I expect out of the color wheel or other components? Don't want to drop a couple of hunderd dollars on a new bulb if something else is likely at the end of its expeted life.
- If I did decide to upgrade from this projector....how much better have the projectors in the sub $3000 range gotten. I see lots of talk on the BenQ W1070, how would this compare to the Marantz VP4001. Also curious to compare the VP4001 vs the Panasonic PT-AE7000U & PT-AE8000U & PT-AR100U (or if there is another procector that is worthy of consideration, would love to hear about that as well)
- Where is the cheapest/reliable place to get a replacement bulb?
Thanks in advance.
patgrogan is offline
post #2 of 2 Old 01-14-2013, 02:57 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Can't answer the majority of your questions, but have a question for you. Was your original lamp still working when it was replaced and by chance do you still have it? If so put it in and see if it will light.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
