motion flow test scenes? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 63 Old 01-19-2013, 07:53 AM
Kris Deering's Avatar
Quoted: 2222 Post(s)
Liked: 3416
Actually based on what your saying lower contrast pjs can't do higher gammas because they can't get their Y level low enough for a linear gamma down low. The new BT1886 standard for gamma compensates a bit by using measured black of the particular display and essentially doing an S curve to achieve 2.4 at the upper end. But most displays can't do a higher gamma like the JVCs because they can't achieve the same black or near black levels.
My Home Theater
Kris Deering is online now
post #62 of 63 Old 01-19-2013, 08:21 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Your 1st sentence is basically saying the same thing as your last sentence so yes, I agree (or am I missing something?). What is your take on BT.1886 - do you use it (or like it)?
Geof
Geof is offline
post #63 of 63 Old 01-20-2013, 03:07 AM
Elix's Avatar
Quoted: 238 Post(s)
Liked: 104
Here're two best files for testing motion flow and motion resolution of the PJ or display.
For testing motion interpolation only http://yadi.sk/d/F2cVai5J1zI_O
For testing motion interpolation & motion resolution http://yadi.sk/d/5hHbKKk01zU50
Elix is offline
Jvc Dla Rs55 Bundle , Sony Vpl Hw50es 3d Projector , Optoma Hd8300 3d Projector , Optoma Hd33 3d Ready Dlp Projector
