Best projector and screen for $3000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-15-2013, 07:13 PM - Thread Starter
renner2310's Avatar
I am new to this and need help please. I have been researching this but there is just so much info out there. I have a couple question.
1. Should I buy an Epson 5020 or Pani 8000, or the sony 50 and go with a visual apex fixed screen 120inch? Is there a better screen for the price. I can get the 5020 and 120inch screen for around $3000.
2. Or should I buy a cheaper projector say the epson 3020 $1599 and go with a better screen that cost around $1500? If you say this what screen should I get?
My room is a basement so light control isn't a big issue. I have everything wired and ready to go but the projector. My ceiling is 8ft and I will be seating back around 17 ft. The projector will be about 17ft away as well.
Thanks so much for the help!
renner2310 is offline
post #2 of 4 Old 01-15-2013, 07:57 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
I would say if its in your budget...invest your money into your PJ. The screens are cheap...120" screens can be bought around $400-500: http://www.amazon.com/Elite-Screens-R120WH1-Projection-120-Inch/dp/B000YUG02S/ref=sr_1_5?ie=UTF8&qid=1358304830&sr=8-5&keywords=elite+screens+120
I have a 150" elite screen and I love it!
Or you can even build your own screen for less. You can't go wrong with either PJ. Good Luck!!!
JoeBoy73 is offline
post #3 of 4 Old 01-15-2013, 08:55 PM
wyen78's Avatar
I don't think the sony has power zoom and memory so if you want CIH you'd have to go with the panasonic. The issue with CIH is variable aspect ratio movies like The Dark Knight are screwed.
I would put more of the budget into the projector. The counter argument would be that the screen will outlast the projector provided you aren't moving it around. But dollar for dollar investing in the pj will give you better PQ.
wyen78 is offline
post #4 of 4 Old 01-16-2013, 09:02 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
For your 17 ft. seating distance, I suggest you go with a screen size of around 130 to 135 inches (diagonal with 16 x 9 aspect ratio). The Epson 5020 can put out a lot of lumens in a fairly accurate color mode (but only moderate lumens output in the best calibrated mode) and would be good match for your case (assuming you want a 16 x 9 screen and not a 2.35:1 aspect ratio 'scope' screen). You can find a comparison of Epson to the Panasonic projectors HERE.
As for low priced fixed frame screens below are a few suggestions:
Focupix fixed frame (listed as 138" but with 130" viewable diagonal size): LINK
Elite 135" Sable fixed frame - HERE
Elite 135" EZFrame fixed frame - HERE
Visual Apex 135" fixed frame - HERE
Monoprice 133" fixed frame - HERE
I recommend you get a white screen fabric for any of the above screens and such white screen material will have an actual gain if near 1.0 (or just a little higher).
Many AVS Forum members like the Dalite screens using their "High Power" fabric that when used as intended provides high gain (i.e. 2.4) for a very bright image (especially useful for viewing 3D video). In order to get the full benefits this screen can offer you must mount the projector just a little above eye level (for the normal seated viewing position). If this would work for you then the least expensive Dalite fixed frame screen model that offers the High Power fabric as an option is the "DaSnap" series of screens. The frames for the DaSnap series do not look as nice as most of the above less expensive screens, but it is functional. The 133" DaSnap screen with the High Power fabric is listed HERE, but it does cost over $800.
Also be aware that some of the above screens are shipped in very long boxes (where the top and bottom parts of the frame are made as a single piece) and such screens must be shipped by motor freight as they are too large for regular UPS of FedEx shipping. As a result the shipping costs of these screens will be much higher. So be certain to check the final price with shipping when comparing the above screens.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
