JVC Faroudia Digital Video Processor LD-HD2K - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-16-2013, 04:12 PM - Thread Starter
Clay1970's Avatar
I have this projector JVC DLA-HD2K that came with the JVC Faroudja Digital Video Processor LD-HD2K. JVC doesn't have the owners manual or IR codes anymore and are of no help, also, I don't have the remote. I tried to use a Direc TV remote to search for codes I could train into my Harmony 880 remote. I found 2 codes that give me acces to the Menu on the processor and it cycles through the Menu Headings, but I can't change anything. The Harmony remote doesnt have anything any where near what I need. I can't find a code that works for anything on the projector. Ideas?
Clay1970 is offline
post #2 of 7 Old 02-10-2013, 04:27 AM
bouchet1's Avatar
I have the same problem have you found a remote for the ld-hd2k if you have let me know . The DLA hd2k is a great projector it works with a number of scalers and processors I am running it with the vantage hd2 with great results also the pc/hd to hdmi scaler model no cp-255h is a very inexpensive unit and works quite well not as good as the vantage but does work . all the best Tony
bouchet1 is offline
post #3 of 7 Old 02-11-2013, 09:49 AM - Thread Starter
Clay1970's Avatar
I located a company that has the remote.I ordered it and I know we got it though I haven't tried it yet, it might be a couple months before I get back to check it out. If you get one let me know if it works.
Also the kit part number for the projector and the processor is DLA-HD2K-SYS. The "SYS" meaning both units. Once I figured that out it got easier to find info on both units. JVC offered a couple different processors with the projector, but they had different kit part numbers.
Clay
A replacement remote control can be purchased from for $35.00 + shipping.
Robert Kirkpatrick
Lifestyles Home Entertainment
rob@lifestyleshomeentertainment.com
530-295-0880
Faroudja Factory Authorized Service Center
Faroudja is a trademark of ST Microelecronics
Clay1970 is offline
post #4 of 7 Old 02-11-2013, 09:51 AM - Thread Starter
Clay1970's Avatar
Clay1970 is offline
post #5 of 7 Old 02-13-2013, 06:36 AM
bouchet1's Avatar
Thanks for reply contact email is service@lifestyleshomeentertainment.com did not connect with rob@ thanks for your reply
bouchet1 is offline
post #6 of 7 Old 02-13-2013, 11:59 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
I have an old HD2k that died on me last fall. I still have the processor, both remotes (projector and processor), a lamp with about 50hours on it and the projector itself (considered to be for parts only at this point).
If you are interested in any of this please send me a PM.
walterappleby is offline
post #7 of 7 Old 02-15-2013, 11:21 AM
bouchet1's Avatar
Thanks for your offer but I have been able to find the missing faroudja remote I was looking for at lifestylehomeentertainment
bouchet1 is offline
