VPL-HW50ES : Black HT Ceiling worth it to improve percieved contrast? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 01-26-2013, 12:17 PM
SteveR1952's Avatar
My media room is semi-dedicated to HT but is also a general purpose room for music listening and as an overflow area for parties or just a place to get away (Man cave concept). The room will not be all black..I don't want to be in a real cave especially since I will have lights on for sports events and for general reading or visiting. The TV is in the Great Room so that is not a factor. My wife has agreed to a dark screen wall and dark carpet but draws the line with a dark ceiling.
Since my room is still under construction, my plan is to maybe use audio treatment panels on the ceiling and from the screen to the first reflection area and then a few panels on the rear of the room, bass traps in the four corners. This might be a good compromise. My current PJ choice is JVC or Sony...still evaluating.
The speakers will be matte black and will not be covered as music is a major point of this room too. I may look into some dark colored drapes near the screen (might use as masking for 2.40...or might just have them pulled back to past the screen edges and have the area around the screen flat black.
Thanks for all the ideas...I am a sponge right now.
SteveR1952 is offline
post #32 of 37 Old 01-27-2013, 08:23 AM
cemo62's Avatar
Quoted: 49 Post(s)
cemo62 is offline
post #33 of 37 Old 01-27-2013, 08:31 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
I will post an answer. Very simple and no explanation needed. Not.I am sure others will elaborate.
mark haflich is offline
post #34 of 37 Old 01-27-2013, 08:50 AM
cemo62's Avatar
Quoted: 49 Post(s)
Originally Posted by mark haflich View Post
I will post an answer. Vvery simple and no explanation needed. Not. i am sure others will elaborate.
why can you please give some info about it
take a look pls isnt it dark http://www.minhembio.com/Muliisha/298903#371119 confused.gif
cemo62 is offline
post #35 of 37 Old 01-27-2013, 05:34 PM
Liked: 1012
The idea is to cover the surfaces near the screen with a black non reflective material. The material you linked is not such a material.
post #36 of 37 Old 01-28-2013, 12:58 AM
cemo62's Avatar
Quoted: 49 Post(s)
Oke a question is it also same for other walls? I mean i will paint the wall behind secreen and ceiling with black paint. what about the other walls , if i use this material does it suck again?
cemo62 is offline
post #37 of 37 Old 01-28-2013, 01:12 PM
Seegs108's Avatar
Quoted: 4956 Post(s)
Liked: 2477
I you do paint it black, make sure the paint you buy is matte not glossy or some other type in between. Black cloth will work better than matte black paint for absorbing light, but if you need to use paint, get the darkest matte black you can find.
Seegs108 is offline
Sony Vpl Hw50es 3d Projector , Panasonic Tcp65 65 Inch Vt25 3d Plasma Tv
