3d question with projectors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-23-2013, 11:10 AM - Thread Starter
natas777's Avatar
I was wondering if there was a recommended FL value for 3D? I know most people state for 2d in a darkened room that value is 16-22fl. Is this number the same for 3d? If not what do most people recommend?
natas777 is offline
post #2 of 3 Old 01-23-2013, 11:18 AM
Elix's Avatar
Quoted: 216 Post(s)
Liked: 100
For 2D the standard is 12-16 ftL. Ideally this should be the same for 3D.
Elix is offline
post #3 of 3 Old 01-23-2013, 02:55 PM
Seegs108's Avatar
Quoted: 4296 Post(s)
Liked: 2148
It depends on a couple things. I think the most important this isn't to look at the projector, but at the 3D glasses you're using. Each pair lets a certain percentage of light through them. So take that percetage to see how much light you should be getting. I think anything above 9 ftL behind the glasses is actually pretty bright. Another thing to look at is how bright (if it's actually brighter) is the 3D mode. Typically, 3D projectors will try and put out more light in the 3D mode. So if reading a review make sure to read how many lumens it's putting out in it's 3D mode.
Seegs108 is offline
