JVC DLA-RS2 Diode Identification Assistance Needed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-27-2013, 07:03 PM - Thread Starter
seraph's Avatar
Quoted: 16 Post(s)
Greetings
I just bought a busted RS2 off of a fellow forum member, and I'm attempting to repair the damage to it. I've found the likely culprit -- a fried diode on the main processor board. The diode is labeled D1 on the PCB. The JVC part number for the board is NAL0053-001. If anyone has any inside information or can otherwise assist me in identifying the part number or specifications for this diode let me know.
Any help is much appreciated.
-- Zack
Dual SI BHS-24 Ported Sub Plan & Build: http://www.avsforum.com/forum/155-di...ign-build.html
Dedicated Theater Plan & Build: http://www.avsforum.com/forum/19-ded...ing-build.html
seraph is offline
post #2 of 6 Old 01-27-2013, 07:49 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
A diode with 3 terminals is no regular diode. Do you see any others nearby that are not cooked? Can you see any markings on it?
Looks like that diode has been replaced before. Might want to consult JVC to see if they can recommend a better substitute.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3 of 6 Old 01-27-2013, 08:09 PM - Thread Starter
seraph's Avatar
Quoted: 16 Post(s)
The closest one I can find (it looks about the same size as D1) is D4. All of the others are definitely different sizes.
There is a N and what looks to be a marking that looks like a Tetris piece on it.
Not sure how to identify the part number from that.
-- Zack
seraph is offline
post #4 of 6 Old 01-28-2013, 06:29 AM
Liked: 711
I looked through all these logos but so far could not find a match. If you can look for others and find the Mgfr, that might help.
post #5 of 6 Old 01-28-2013, 06:54 PM - Thread Starter
seraph's Avatar
Quoted: 16 Post(s)
Thanks for the help. That website is especially useful for the future, even if it did not yield results here. I called JVC and the tech tried to help me identify the part but in the end he doesn't have a part number for D1 because it not considered a replaceable part -- they usually replace the entire board. I ordered the whole board for now -- but my hope is when I get it to be able to identify the diode off of the replacement and get the original working so I can return the replacement. If I can't identify it, then I will keep the replacement board.
seraph is offline
post #6 of 6 Old 03-18-2013, 02:01 PM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
If you haven't gotten this fixed PM me.
avsform1 is offline
