is there a big different between JVC RS50 and JVC RS20 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-30-2013, 04:21 AM - Thread Starter
femi's Avatar
Quoted: 138 Post(s)
Liked: 156
which is better the JVC RS50 or JVC RS20? Thanks for any info.
(2)JTR Cap 4000---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---Darbee Darblet DVP-5000---Harmony 1100 remote
femi is offline
post #2 of 7 Old 01-30-2013, 05:09 AM
henrich3's Avatar
Quoted: 585 Post(s)
Liked: 502
I owned the RS20 and RS60. The biggest difference was the 3D functionality in the '60. The black level on the '60 was slightly better than the '20, but any improvement in that area between the 20 & 50 is likely to be miniscule. If all you care about is 2D then the picture quality of both should be very close. If you care about 3D then you only have one option.
henrich3 is offline
post #3 of 7 Old 01-30-2013, 09:41 AM
gonzalc3's Avatar
Quoted: 183 Post(s)
Liked: 154
If I were in your case I will try to get one of the newer models...Either the 45,46,4810...besides the improvements in contrast there is the introduction of e-shift, and in these year's models lamps dim slower than previous generations..
Chris. My DVD UHD Blu Ray and Blu Ray collection
JVC DLA-X750R (calibrated with calman 5 and c6 hdr meter), ST 130 (144") cinemascope screen, Carada Masquerade CIH masking system,B&W 803D2s mains, B&W HTM2D2 center channel, B&W 805D2 surrounds, B&W CCMM682s in-ceiling speakers (4), B&W DB1 subwoofer, Anthem AVM 60 processor, Parasound Halo A51+(2xA21)+(2xA23) amps, Oppo UDP 203 player, Roku Ultra and Harmony Elite remote.
gonzalc3 is offline
post #4 of 7 Old 01-30-2013, 11:21 AM
KBMAN's Avatar
Quoted: 329 Post(s)
Liked: 168
I own the RS20, and I have no need to upgrade for a while. And there is no bulb 'issue' with the RS10/20/25/35 that I know of. It was the RS 40/50/60 that had the issue of premature dimming....
KBMAN is offline
post #5 of 7 Old 01-30-2013, 12:23 PM
deandob's Avatar
Quoted: 40 Post(s)
Liked: 24
Note a number of the earlier JVC projectors including the RS20 suffer from optical block degredation after 1000+ hours, search for 'pink band' on this forum and you will see a lot of complaints, and its expensive to fix (typically failing after the warranty expires). Personally I would not buy an older JVC model because of it. My RS20 suffered this fate which forced me to upgrade as otherwise I was quite happy with it. I now have a RS56 and the picture is better but only incrementally (a bit brighter, blacks a bit better etc.). 3D is the main difference.
deandob is offline
post #6 of 7 Old 01-30-2013, 02:13 PM
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
Originally Posted by femi View Post
Sorry for all this questions but how about JVC RS2 vs JVC RS45? I think I can get them for the same price. Thanks for any input.
I have an RS2 but the color is cartoonish. The 45 may have the lamp issue, but I'm sure the pq is far better. I would go with the 45 at the same price no queation.
Tom
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #7 of 7 Old 01-30-2013, 03:44 PM - Thread Starter
femi's Avatar
Quoted: 138 Post(s)
Liked: 156
Thanks guys u have help me out alot.
femi is offline
Jvc Rs50u
