Is a conversion lens a bad idea? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 02-07-2013, 02:48 PM - Thread Starter
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
My Benq 7000 can't fill my screens 96" width because my room is only 13' deep. Would a conversion lens work well? The Benq is the only 3D DLP that will work for me since I can only put it on a rear shelf within the screen vertically. It is only being used for 3D. I only want DLP for 3D due to it's ZERO crosstalk. I use a ceiling mounted JVC for 2d. The JVC can't be shelf mounted because it's depth would block my rear wall speakers.
Tom
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #2 of 19 Old 02-07-2013, 02:55 PM
Seegs108's Avatar
Quoted: 4202 Post(s)
Liked: 2089
The issue is cost. A good conversion lens such as the Navitar Screenstar HDSSW065 costs almost as much as the BenQ W7000 does.
Seegs108 is online now
post #3 of 19 Old 02-07-2013, 03:01 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
I would be willing to spend the cash if I knew it would not degrade the picture and accomplish my goal.
post #4 of 19 Old 02-07-2013, 03:35 PM
Seegs108's Avatar
Liked: 2089
The lens I mentioned will get the job done as you need it.
post #5 of 19 Old 02-07-2013, 03:59 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
Would their 0.8x lens also work in my setup? I see it's a little cheaper than the 0.65.
The W7000 zoomed all the way out gives an image around 85" wide. I would need 96" wide plus a little spillover just to be safe.
Tom
post #6 of 19 Old 02-07-2013, 04:08 PM
Seegs108's Avatar
Liked: 2089
Yeah it should still work. All you need to do is figure out the closest throw distance possible for your screen size and multiply by .8 and that's how much closer you can put your projector.
post #7 of 19 Old 02-07-2013, 04:19 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
Graig Peer had the .65 in the classifieds for around $1K. I just spoke with him and he said that it recently sold. Every single time I try to buy a projector on this form I'm always too late. I feel like crying.frown.gif
Tom
post #8 of 19 Old 02-07-2013, 05:15 PM
GoCaboNow's Avatar
Quoted: 864 Post(s)
Liked: 758
Tom
No way to poke a hole in the back wall to get the Benq back a bit?
My Dedicated Home Theater Room
GoCaboNow is offline
post #9 of 19 Old 02-07-2013, 05:35 PM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
Tom
Yes the 0.8 will work for you Thomas. I sent you an email.
mjgarrett100@gmail.com
Mike Garrett is online now
post #10 of 19 Old 02-07-2013, 06:23 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
Another possibility is to fire the pj sideways and reflect it off of a first-surface mirror.
The image would be about 12" wide at a point that would add the requisite throw distance, so the mirror would need to 1.414 x 12 = 17" wide, and 7" tall.
I might have one close to that size from a RP project I bailed on; PM me if interested and I'll see if I can find it.
Noah
noah katz is online now
post #11 of 19 Old 02-08-2013, 11:10 AM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
E-mail received. If I can get my w7000 ringing issue solved, I'll call you and order that 0.8 conversion lens. Thanks as always for the help.smile.gif
Tom
post #12 of 19 Old 02-08-2013, 11:13 AM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
No.
The back wall is shared with my living room. If I were single I would do it.
Tom
post #13 of 19 Old 02-08-2013, 11:20 AM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
Thanks, but WAY over my head.
Tom
post #14 of 19 Old 02-09-2013, 02:00 AM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 36
Tom
He's just talking about putting the projector off to one side and pointing it at a mirror.
Here's a super-crude drawing that I whipped up in 30 seconds to illustrate.
http://img824.imageshack.us/img824/4571/frontmirror.png
This approach is probably about 10x cheaper than going with a lens and much less likely to have distortion since a flat mirror is a lot easier to make than a distortion-free lens.
Copyright is not property, it is merely a temporary loan from the public domain.
JerryW is offline
post #15 of 19 Old 02-09-2013, 02:59 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
Very cool. Thanks for taking out the time to do that. Unfortunately, it wouldn't wok in my room.
Tom
post #16 of 19 Old 02-09-2013, 03:12 PM
Seegs108's Avatar
Liked: 2089
Where could one obtain a mountable mirror at 45 degrees (like depicted)? Do people get their protractor out and measure for themselves and glue one piece of mirror at the appropriate angle to the wall?
post #17 of 19 Old 02-11-2013, 12:24 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
The mirror would require stable mounting to the wall or a stand, same as the pj.
Mysteries such as where to procure such an arcane device can be solved by targeted application of internet search technologies
Noah
post #18 of 19 Old 03-03-2013, 04:17 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
It was expensive, but boy that .8 Navitar is a heck of a lens. I see zero reduction in any picture category with it in place. Now I can have the 7000 fill my entire scope screen for 3D and animation 2D. Probably the best thing about it is ease of placement. I can easily switch it to use on my 2D JVC projector. I use constant height zoom with a 2.4:1 screen. Now with the Navitar, I can zoom the JVC out enough to move to a 2.77 ish scope screen for films like Ben Hur. Even 2.81 for How the West Was Won could work. This would eliminate all horizontal black bars leaving just side bars to mask..
I order from Mike and he was willing to ship Priority so I could get it yesterday.
By the way, the size and weight of this thing was shocking. If ever a lens looked like it is worth over 1k, this is it.
If AVS sells what I'm looking for, I will always buy from them. Mike Garrett is one one of the finest people I have dealt with in my 48 years of life. ORDER FROM HIM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
585-671-2968
Tom
post #19 of 19 Old 03-07-2013, 03:35 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3039 Post(s)
Liked: 2971
Ya, the Navitar lenses are impressive items - you got a nice piece of glass !! biggrin.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Benq W7000 Home Projection System
