JVC RS40 fading -- but it's not the lamp! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-07-2013, 05:11 PM - Thread Starter
clarkjohnsen's Avatar
I installed a new lamp, but no change. For the first half hour or so the unit operates at reduced light level with very reddish tones. After sufficient warmup the spectrum becomes white (6500 degrees setting), although it doesn't seem as bright as formerly. I've written JVC, but no reply.
Anyone?
Clark
clarkjohnsen is offline
post #2 of 6 Old 02-07-2013, 08:21 PM
3dmaven's Avatar
Could it be a problem with the ballast for the lamp? I don't really know much about such things, but there could be a problem with the power being supplied to the lamp. Good luck with JVS customer service, they can be hard to get a hold of these days.
3dmaven is offline
post #3 of 6 Old 02-10-2013, 10:40 PM
spdntckt's Avatar
Have you tried cleaning the filters? may also try running on high altitude mode to see if it is heat related (could also point to bad component if it does improve)
spdntckt is offline
post #4 of 6 Old 02-13-2013, 02:05 PM
mry110's Avatar
Quoted: 133 Post(s)
Liked: 52
My new bulb overheats my projector (RS50). I'm absolutely done with JVC this thing has been nothing but trouble.
stevenjw likes this.
mry110 is offline
post #5 of 6 Old 09-05-2013, 04:21 PM
cmharcou's Avatar
Our bulb did that as well. Went real dark and I thought it was the movie. However, it wasn't. An hour later or so there she blew! Thats the 3rd bulb we've gone through. Only 300 hours on projector. Were working with JVC now for a replacement.
cmharcou is offline
post #6 of 6 Old 09-06-2013, 07:20 AM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
Did you get the Rev3 lamp that is suppose to solve the issues.
avsform1 is offline
Jvc Dla Rs40u
