New JVC after refusal to repair pink stripe? - AVS Forum | Home Theater Discussions And Reviews
Old 02-08-2013, 07:13 AM - Thread Starter
jake51's Avatar
Quoted: 62 Post(s)
Hi
I have been offered a new JVC at half price after my old JVC developed the pink stripe
JVC refused to repair it as it was a bit out of warranty, and the cost would be about the same as a new projector
But I just don't know: I watched Taken 2 and it looked as good as always
My thinking is that maybe I can go back to a 16:9 screen (I have a 21:9 screen) and zoom out a bit
It's too good to be used for parts or whatever they want to do with it (I have to return it)
Would you buy a new JVC at half price?
Jakob
jake51 is offline
Old 02-08-2013, 07:17 AM
Drexler's Avatar
Quoted: 92 Post(s)
Liked: 64
What model is your current JVC?
I think I would if I had the money.
Drexler is offline
Old 02-08-2013, 07:18 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Originally Posted by jake51 View Post
Hi
Jakob
I would seriously consider it. If you sold your projector the way it is, you would get very little money for it, so your over all cost for a new projector would be much higher. This way, you are getting rid of the defective projector and getting some value for it. Now if you do not have the money available, then that is a different matter.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 02-08-2013, 09:57 AM - Thread Starter
jake51's Avatar
Quoted: 62 Post(s)
I have the HD550 (RS15) and have been offered the X35 (RS46)
Guess I'm mostly pissed that JVC refused to repair it: How can the cost be the same as a new projector?
I have the money for a new projector... but the HD550 is still very good, I think
jake51 is offline
Old 02-08-2013, 10:09 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3067 Post(s)
Liked: 2990
I'd go for the new RS46. As for "How can the cost be the same as a new projector?", my first Blu Ray player died 2 months beyond the regular factory warranty. Since I bought it with an AMEX card, it was covered for an additional year. But I was required to send it in to an authorized repair center for a repair estimate. The estimate to fix it was $ 550.00. It cost $ 525.00 new. American Express sent me a check for the original cost ( and I bought an Oppo BD83 which is still working ). Get the RS46 !! smile.gif
DrZaus likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
Old 02-08-2013, 10:15 AM
Drexler's Avatar
Quoted: 92 Post(s)
Liked: 64
The problem is you have a faulty optical block which is the most expensive part of the projector. Including work the cost of exchanging it is somewhere around $3-4000 if I remember correctly.
The X35 should be a very considerable upgrade. Sharper, better motion, higher contrast, better colors, brighter, 3D plus you would get something completely new versus a used unit which will eventually break down again. I would jump on the deal!
Drexler is offline
Old 02-09-2013, 03:08 PM
dragonbud0's Avatar
Quoted: 106 Post(s)
Liked: 49
Go for it if you have the money; it's a no-brainer to me to get the RS46 at 1/2 price.
dragonbud0 is offline
Old 02-09-2013, 06:11 PM
mbw23air's Avatar
Quoted: 159 Post(s)
Liked: 151
I agree with everyone as a used RS15 is not bringing that much for a perfect condition one and I'm sure with the RS46 you will get a 2 year warranty.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is online now
Old 02-10-2013, 01:07 PM - Thread Starter
jake51's Avatar
Quoted: 62 Post(s)
I was never thinking of selling my JVC, in fact I was going to buy a new bulb at some time
I could have been happy with it for several more years
Now it just gets used for parts, makes me a bit sad...
jake51 is offline
Old 02-10-2013, 09:23 PM
blankdaxi's Avatar
right.Go for it if you have the money; it's a no-brainer to me to get the RS46 at 1/2 price. thanks 10.gif
blankdaxi is offline
Old 02-11-2013, 06:01 AM - Thread Starter
jake51's Avatar
Quoted: 62 Post(s)
I've taken the deal, I get it maybe next week
Now I need a new wall mount: The HD550 had the connections on the side (just space enough), but the X35 has connections on the back
It never stops, huh
jake51 is offline
Old 02-11-2013, 06:46 AM
turtletrax's Avatar
It never stops, huh
I am in the exact same boat. I had a HD-950 that went bad and getting an X55r and now have to move my roof mount because of the change in connection locations. Hope I have some paint left for touch ups rolleyes.gif
turtletrax is offline
Old 02-11-2013, 09:01 AM - Thread Starter
jake51's Avatar
Quoted: 62 Post(s)
I dunno about a ceiling mount... don't you need to be two to get the projector down and up again?
One to hold the PJ in place and one to loose/tighten the screws
jake51 is offline
Old 02-11-2013, 11:30 AM
Kelvin1965S's Avatar
Quoted: 260 Post(s)
Liked: 160
It never stops, huh
Well apart from the pain of the installation, I think you will be pleased with the end result: I went from a HD350 (with full 125 point calibration by Lumagen and a Darbee) to an X35 with the same accessories. I've found that the image is brighter, which allows me to close the iris right down and still measure 15fL, better blacks, sharper and improved motion. I only really bought the X35 as a stop gap since I know I'll end up with a true 4K projector at some point and I wanted a white chassis to better blend in with my room (it's not a dedicated room unfortunately), but it's going to be a great stopgap. cool.gif I've also been measuring the light output and after 120 hours I've barely dropped 5-7% output which is much less than my old HD350 did over the same time with a new lamp.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
Old 02-11-2013, 11:48 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2990
I don't know what kind of mount you are using, but I am easily able to remove and re-install my projector using a Chief mount with quick release thumb screws all by myself.
Jvc Rs 15 , Jvc Dla Rs46 Projector
