Home theater - ground up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-09-2013, 05:43 PM - Thread Starter
regulator911's Avatar
We just purchased a home and will be turning the basement into a theater. The basement has two sections both 9 ft trey ceilings totaling about 2200 sf. The front part we plan on making into the theater and putting a pool table in the back near the bar. The area is about 15 by 20 and would need a motorized screen to drop down in front of a fireplace.
My initial thought was 400" screen with HH contrast and 3d capable projector somewhere about $3,500 for the projector and what ever screen I need to achieve 3d hd cinema quality.
Any suggestions are appreciated.
regulator911 is offline
post #2 of 15 Old 02-09-2013, 05:44 PM - Thread Starter
One other note is the basement is fully open but the ceiling is separated only by the trey sections so placement of the projector would need to be in the divide where the ceiling drops down.
post #3 of 15 Old 02-09-2013, 05:56 PM
Seegs108's Avatar
Quoted: 4206 Post(s)
Liked: 2090
I think either 400" is a typo or you seriously need to reconsider the size of your screen. There's no way you could fit a 400" screen in a space with only 9' ceilings. Also you aren't going to find a projector anywhere near $3500 that will be bright enough to fill a screen that size. You would need a projector outputting 8000+ lumens for something that large.
Some other things to consider before anything projector or screen related can be talked about are the intentions of this room. Is this 15x20 space a dedicated space that you will have full light control and walls/ceilings/carpet all will be dark? Are there any windows or ambient light that we should know about? Is there anything specific you want the projector to do other than 3D? Also, what is "HH contrast"?
I would highly suggest reading the first bunch of pages of this thread as all of the projectors there are going to be within your budget and are considered the best of whats available in that price range currently:
http://www.avsforum.com/t/1434826/sony-hw50-benq-w7000-epson-5020-jvc-rs55-jvc-rs-46-jvc-rs4810-jvc-rs56-mini-shootout-2012-2013/0_50
As for the screen size, at this price point, the largest screen you'd want to be looking at is something near 135" diagonal (1.78:1), otherwise you run the risk of 3D being too dim to be enjoyable.
Seegs108 is offline
post #4 of 15 Old 02-09-2013, 06:30 PM - Thread Starter
Sorry the iPad auto corrects wrong sometimes. I meant HD image and was guessing 140" would be good. Can a $3,500 projector light up 130-140 for 3d decently or do I have to step up into $4-5k range.
post #5 of 15 Old 02-09-2013, 06:33 PM - Thread Starter
Also the room is mostly dedicated to the screen. It's a basement with large plantation shutters going down one wall and the carpet is cream color.
post #6 of 15 Old 02-09-2013, 06:43 PM
Seegs108's Avatar
Liked: 2090
At that size your best bet for a decently bright 3D image would be the Epson 5020 or if you decide on a higher gain screen most of the other projectors in that thread should suffice.
Seegs108 is offline
post #7 of 15 Old 02-09-2013, 06:59 PM - Thread Starter
Thanks that looks like a great deal for a projector. What's the largest diagonal you should run that at 2400L?
post #8 of 15 Old 02-09-2013, 07:13 PM
dfp84's Avatar
Try looking at the panasonic pt ae 8000u as well. I watch 3d on a 130 diag and it looks great
dfp84 is offline
post #9 of 15 Old 02-09-2013, 07:29 PM
Seegs108's Avatar
Liked: 2090
While the Pannasonic PT-AE8000 is a nice unit the Epson basically outperforms the Pannasonic in all areas. For the price the Epson is a much better value over the Pannasonic.
Seegs108 is offline
post #10 of 15 Old 02-10-2013, 06:05 AM - Thread Starter
It appears epson also has wireless HD 3d also which could pay for itself in long hdmi runs. I was hoping to go wireless audio also so I could play with speaker arrangement.
post #11 of 15 Old 02-10-2013, 10:00 PM
dfp84's Avatar
My priorities were for a CIH setup so I went for the motorized lens shift and memory. And also as a gamer the panny was a bit better. But it was an agonizing decision. The epson is a fantastic projector and from what ive read the wireless HDMI performs very well. And the warranty and customer support are far better than what you get almost anywhere else.
dfp84 is offline
post #12 of 15 Old 02-11-2013, 11:35 AM - Thread Starter
Ok so Im sold on the Epson after talking to a dealer at a local home theater company for the 6020 and a 120 motorized. I thought I wanted a 140 but he made a good argument that it might be more than the projector is capable of handling in a room with ambient light.
The next step is audio. They only sold one type of sound system there so I'd like to hear what others recommend. I was thinking about just going with one of the packaged systems from Bose or similar?
post #13 of 15 Old 02-11-2013, 03:27 PM
Seegs108's Avatar
Liked: 2090
For audio you should take the discussion to the audio subforums. But I will tell you this, for $2500 you can do WORLDS better than that Bose system.
Seegs108 is offline
post #14 of 15 Old 02-11-2013, 05:02 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
An Epson 5020 along with a 130 to 140 inch screen (diagonal size in a 16x9 format) should work OK, but I would look for a screen with some moderate gain, such as the Stewart StudioTek 130 with an actual gain of 1.3 (but its expensive). There are lower priced alternatives but many that the manufacturer's rate as having a gain of 1.3 to 1.4 are really closer to 1.0. So before you settle on the screen do your research in the Screens section of this forum (HERE). Also ceiling mounting the projector close to the shortest possible projector to screen throw distance compatible with the spcific size screen you select will provide the brightest image on the screen. With an Epson projector the shortest throw distance allowed for a screen of the size your are considering is in the 13 to 14 tt. range.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #15 of 15 Old 02-12-2013, 04:13 PM - Thread Starter
Thanks for the info. I'll definitely check out some audio options. Also the distance sounds perfect since that puts the projector into the main part of the ceiling height outside of th tray.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Panasonic Ptae8000u Hd Projector
