Home theater - ground up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-09-2013, 04:55 PM - Thread Starter
regulator911's Avatar
We just purchased a home and will be turning the basement into a theater. The basement has two sections both 9 ft trey ceilings totaling about 2200 sf. The front part we plan on making into the theater and putting a pool table in the back near the bar. The area is about 20 by 25 and would need a motorized screen to drop down in front of a fireplace.
My initial thought was 400" screen with HH contrast and 3d capable projector somewhere about $3,500 for the projector and what ever screen I need to achieve 3d hd cinema quality.
Any suggestions are appreciated.
regulator911 is offline
post #2 of 2 Old 02-11-2013, 02:07 PM
bobnegi's Avatar
400" ? Is that a typo
What is HH Contrast, never heard of it.
More info please:
Is the room 100% light controllable, what will the distance be from the projector to the screen, very important, as not all projectors can throw images less than a certain distance.
GO to projector people, the have a projector calculator which can be used to narrow down the choices
bobnegi is offline
