Deep Color and Lip Sync. Really Needed in a Pre/pro or Receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-14-2013, 03:11 PM - Thread Starter
SteveR1952's Avatar
I am looking at a receiver that does not have lip sync or support for Deep Color.
My current choice of projector is either a Sony 50ES or a JCV RS4810.
My other option is to go with a sister product of the receiver; a pre/pro that does have these features. My question is do I need them or not?
Edited to correct True Color to Deep Color.
SteveR1952 is offline
post #2 of 3 Old 02-19-2013, 05:23 PM
PBonn's Avatar
Quoted: 17 Post(s)
I would recommend lip sync, especially important for concerts.
PBonn is offline
post #3 of 3 Old 02-20-2013, 08:31 AM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 159
HDMI v1.3 brought auto lip-sync to the the table.  If you're using HDMI with equipment that is HDMI v1.3 compliant or higher, lip-sync on the receiver or pre-pro would be redundant and not used.
There are no Deep Color sources except for some camcorders AFAIK.  Blu-ray disc's do not support Deep Color nor do broadcast TV or DVD.  So the need for it is dubious, it's more/less marketing blather at this point.
b curry is offline
