ProjectionDesign Cineo 1080 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-25-2013, 08:19 AM - Thread Starter
Tifstorey's Avatar
Hi all,
Apologies if this is in the wrong forum - but i'm in need of some assistance with a projection set up i use at work.
We run a ProjectionDesign Cineo 1080, hooked up via a Kramer VP-437 running anything from laptops, to BluRays for cinema screenings.
The problem i'm having is the picture just isn't what it should be. The resolution is there but the colours and brightness just lack completely. The best example is sunny scenes - it just doesn't look 'sunny', instead it's just 'bright'.. if that makes any sense.
I've looked into the settings and played about, tried resetting to factory default, changed contrast/brightness etc. I've bypassed the Kramer, going direct via HDMI which makes little difference. I also changed both lamps just a few weeks ago so can count that out.
Does anyone have any idea on what i can try? Sorry for the vague information, i'm not really clued up on the advanced settings..
Any help is very much appreciated,
Thanks, -Tif
Tifstorey is offline
