Projector for a flat 138inch 235:1 screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-26-2013, 12:57 PM - Thread Starter
tuthman's Avatar
I now own a 138inch Elite Screen and need a projector with the lens memory. I am very close to getting a JVC dla X-35, but was wondering if the 4K X-55 model would make enough difference to be worth it. The room is about 20 X14.
I havent read many convincing reviews about the e-shift technology yet. And, for close to 2,000 more, it should really be something.
Thanks for any advice!
tuthman is offline
post #2 of 4 Old 02-26-2013, 02:52 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
You read the wrong report because it makes a difference. When I had the rs40 then the RS55, it was a huge difference. The RS48 is very close to the rs5$
blee0120 is offline
post #3 of 4 Old 02-28-2013, 02:58 PM
holmern's Avatar
I have the X55R and use it on a 1.0 gain, 148" 2:35 screen with a panamorph lens. I can see a clear difference between e-shift/no e-shift. If it is worth it to you or not would be more of a personal opinion, but I doubt I will ever get a a non (faux?) 4K projector again.
holmern is offline
post #4 of 4 Old 03-02-2013, 12:21 AM
Jim Cutter's Avatar
Liked: 31
SO how is the picture brightness with your 1.0 gain screen? I'm looking at getting the X55 too but I was worried that the 1.3 gain screen wouldn't be enough & I was leaning toward a 1.5 gain screen. Are you using the bulb on low power or high power?
Jim Cutter is offline
Jvc Dla X35 3d Hd Front Projector , Jvc Dla Rs4810 3d Home Theater Projector
