Question about my New Sony ES50 and Black Diamond zero Edge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-26-2013, 07:53 PM - Thread Starter
ttexxan1's Avatar
I had my new Sony ES50 installed today along with Black Diamond Zero Edge Screen with LED kit. The screen size is 100 inch. My room size is 13 by 17. My first row is 12 feet away from screen and second row around 14. I am noticing while watching older style movies such as Jurasic park and matrix to be "artifacts" I also noticed while watching TV source from dish network. Its hard to explain but looks kinda fuzzy at times in certain places. 3D blue ray looks fantastic, but notice also some with blue ray non 3d movies. Not sure what to call the artifacts I am seeing or if doing something wrong or in need of higher end projector. I was hoping to watch some older DVD's with better playback. In a total dark room as well.
Any suggestions
ttexxan1 is offline
post #2 of 9 Old 02-26-2013, 07:55 PM - Thread Starter
ttexxan1's Avatar
As a side note as you get closer to the screen the picture looks kinda fuzzy. Never had a projector before so not sure if this is normal or what
ttexxan1 is offline
post #3 of 9 Old 02-27-2013, 08:32 AM
Seegs108's Avatar
Quoted: 4199 Post(s)
Liked: 2088
Is there any way to take a video of what you're seeing?
Seegs108 is online now
post #4 of 9 Old 02-27-2013, 08:47 AM - Thread Starter
ttexxan1's Avatar
At work now but will try later.
ttexxan1 is offline
post #5 of 9 Old 02-27-2013, 08:51 AM - Thread Starter
ttexxan1's Avatar
However I notice when the RC is off it kinda smooth things out and not as noticeable. Just seems like on certain parts of screens will see some artifact. Kinda hard to explain. For example last night when watching Leno when his head would be over certain part of screen would see, but switch to another network would not be noticeable when person over that area?? First time with projector so not sure if have lots of settings right.
ttexxan1 is offline
post #6 of 9 Old 02-27-2013, 10:29 AM
jason4vu's Avatar
Quoted: 26 Post(s)
Liked: 92
Maybe reality creation set too high. I hear it brings out grain on some source material.
Race to the finish home theater buildhttp://www.avsforum.com/forum/19-ded...ter-build.html
jason4vu is offline
post #7 of 9 Old 02-27-2013, 12:57 PM
func's Avatar
What gain does the Zero Edge have, is it 0.8 or 1.4 ?
Are you sure you're not seeing the shimmer from the screen, both versions have som sparkle, but the 1.4 more so. Sparkle is more noticable in bright areas. When the sparcle is subtle i guess i can almost look like grain. Ofc if might just be the RC on your Sony, that will make grain stand out, if there is a bit of grain in the movie the RC enhances this aswell as sharpening the image.
func is offline
post #8 of 9 Old 02-27-2013, 01:29 PM - Thread Starter
ttexxan1's Avatar
It is a 1.4 gain and was wondering if it wasnt the screen. It almost looks to occur in the same area at times. I do notice more on light subject matter. I know that sounds crazy. I have no real ambient lite in the room unless turing on sconces or opening the doors. Screen inovations recommended the 1.4 gain. Was that incorrect?? I did notice that the RC does have some dramatic effect and does lesson some of the issues, but that looks more like Noise reduction stuff that blurrs the photo.
ttexxan1 is offline
post #9 of 9 Old 03-02-2013, 11:22 AM
func's Avatar
I think what you're seeing is sparkle from the screen. Dont think there's any way to get rid of it, lowering light output from the projector might help abit, maybe have the pj further back also to eliminate hotspotting.
func is offline
