INFOCUS 7205 - Horozontal Bar across screen (SEE PICTURE) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-26-2013, 11:42 PM - Thread Starter
studiousjr's Avatar
There's a black bar running horizontally across the screen cutting out part of the image. It's as if something is out of alignment and blocking part of the image. I don't know what happened... just happened one day.
Anybody know what might cause this and if I can fix myself or what part I might need to replace. Or what in the projector has gone out of alignment to cause this problem.
If it's ceiling mounted the bar is on the bottom 1/4 of the screen. If it's table mounted it's on the top quarter of the screen. This BLACK BAR is also at start up during the BLUE INFOCUS LOGO. Not a connection issue.
Thanks for your help!!!
studiousjr is offline
post #2 of 2 Old 02-27-2013, 07:15 PM
Alphacowboy's Avatar
Alphacowboy is offline
Infocus Sp 7205 Dlp Projector
