Dual projectors - 2D and 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-27-2013, 10:52 AM - Thread Starter
Decelerate's Avatar
Quoted: 12 Post(s)
Has anyone tried to mount two projectors to their ceiling? One for 2D and one for 3D.
This seems doable, but I have not really seen any mounts being sold that are capable of holding two projectors.
Decelerate is offline
post #2 of 3 Old 02-27-2013, 11:36 AM
blee0120's Avatar
Quoted: 555 Post(s)
Liked: 278
I shelf mount mines, but I would assume you might need separate mounts
blee0120 is online now
post #3 of 3 Old 02-28-2013, 10:25 PM
Buttabean's Avatar
Liked: 29
I have mine side by side. The newest(mostly used for movies) centered and the old one is off center(tv watching). My pre pro has dual hdmi outs so i just toggle between the two. The only problem I have is... I didn't leave enough space to remove the bulb from the old projector which is used the most so... I have to take it down to replace it. Not really a big deal anyway. I tend to clean the inside and any dust accumulation at that point.
It's definitely nice having two projectors though. I've had a few hiccups with my old projector(bulb explode, odd hdmi issues) which made me switch to the new projector. Really comes in handy when you're hosting and it's your main TV. Nothings more awkward when you have guests come over for a hockey game and your projector isn't working Or the bulb poops on you. Not fun.
Joe.T
Buttabean is offline
