JVC X75R and X90R - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-02-2013, 05:49 PM - Thread Starter
michaeldip's Avatar
Hi i in the process of upgrading projector now.
I can get the 75R and X90 for roughy around the same price, i know the 90 is the older series but top of the range.
Comparing the 2 which one to go for and both brand new
michaeldip is offline
post #2 of 21 Old 03-02-2013, 06:14 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
Very tough, I might go with the 90
blee0120 is offline
post #3 of 21 Old 03-02-2013, 06:19 PM - Thread Starter
michaeldip's Avatar
also with the projector now i am running a prismasonic hc5000r with a annamorphic screen. Am i better keeping it with the new projector eg x75,x90.
or using the zoom feature, I had people tell me they said the zoom on the jvc you wont tell the difference in picture quality
post #4 of 21 Old 03-02-2013, 07:06 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
It should help, but I'm not sure. I know you get the full 1920x1080p with the a-lens but the eshift has more pixels.
blee0120 is offline
post #5 of 21 Old 03-02-2013, 07:22 PM - Thread Starter
michaeldip's Avatar
not sure just to see if people have tried it and what there results where
post #6 of 21 Old 03-02-2013, 08:57 PM
turtletrax's Avatar
The main reason I would consider the X75 is the new bulb and power supply. Seems the bulbs are maintaining brightness quite well and are rated for 4000 hours on low lamp mode, 3000 in high, also have much better warranty. If the warranty has increased, bulb blow-outs must have been reduced as well.
I know that most of these claims are probably as bloated as ever, but I bet they do last allot longer than the previous gen. People seemed to be less than impressed with bulb issues on the X30/X70/X90 line-up.
turtletrax is offline
post #7 of 21 Old 03-02-2013, 09:08 PM - Thread Starter
michaeldip's Avatar
Would you keep lens
post #8 of 21 Old 03-02-2013, 10:12 PM
turtletrax's Avatar
I would try it and see. You can always get rid of a good lens, better to keep it and see then sell if you find it unnecessary.
post #9 of 21 Old 03-03-2013, 12:05 AM - Thread Starter
michaeldip's Avatar
ok thanks so the x75 good unit is the x55 a good unit
post #10 of 21 Old 03-03-2013, 12:35 AM
turtletrax's Avatar
I was offered an X55 as a replacement for my dead HD-950, and after serious consideration I decided to pay the difference and get the X75. ISF and THX certification, motorized lens cover, higher contrast, more in depth auto- calibration options and a few others where the deciding factors. That all being said, if my HD-950 did not die, I would have not even considered upgrading until the new HDMI spec and 4k/UHD was all sorted and content was available. Perhaps the lower price tag on the X55 is a good thing, and will tide you over until the new gear hits and content for them. All questions only you can answer for yourself.
Cheers!
post #11 of 21 Old 03-03-2013, 12:41 AM - Thread Starter
michaeldip's Avatar
looks like the x75 the with the lens
post #12 of 21 Old 03-03-2013, 03:28 AM
Kelvin1965S's Avatar
Quoted: 260 Post(s)
Liked: 160
Seeing how well the lamp is holding out on my X35 I would take the X75 too if it was up to me. I've barely lost any output after 150 hours so I'm still able to run at -15 aperture for 16:9 content and still achieve 15-16fL The extra contrast of the X90 could be lost if the iris has to be opened up more than the X75 in the same installation, plus the lamp is slightly brighter to start with anyway IIUIC.
I'll be interested to hear if you stick with using the lens: I debated selling my Isco II and getting the X55 rather than the X35 plus my lens (I already have a Lumagen for CMS and a Darbee), but the three (zoomed) X55s I've seen don't seem as sharp as my long throw X35 plus lens.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
post #13 of 21 Old 03-03-2013, 05:45 PM - Thread Starter
michaeldip's Avatar
so the zoom wasnt as clear with the lens
post #14 of 21 Old 03-03-2013, 06:02 PM - Thread Starter
michaeldip's Avatar
is 95 a huge step up from 75
post #15 of 21 Old 03-03-2013, 08:01 PM
turtletrax's Avatar
Not really. The increased contrast could be completely unnoticed if not in the perfect room. As far as the hand picked components go, I am not sure if the lens is better. So you could still easily end up with CA and uniformity issues. I don't see the extra couple grand being worth it. I would rather spend the cash on a lumagen, Darbee and or some calibration equipment.
post #16 of 21 Old 03-03-2013, 08:10 PM - Thread Starter
michaeldip's Avatar
does the lumagen and darbee work together or one or the other.
Does that mean you bypass the marantz 7005
post #17 of 21 Old 03-03-2013, 11:55 PM
turtletrax's Avatar
The lumagen is a video processor that allows for many interesting calibration techniques and the darbee is another processor that adds depth info to the image. Both are inline HDMI devices, so are added to the chain. Not sure about your setup, but if you have a lumagen it has two HDMI outputs so you could run one HDMI to your amp and one to your X75.
Some links to product.
http://darbeevision.com/
http://www.lumagen.com/
post #18 of 21 Old 03-04-2013, 02:05 AM - Thread Starter
michaeldip's Avatar
can you go from 7005 to lumagen to darbee then to projector?
Just because i got 3 sources i use Blu ray, HD DVD and HD sat
if i start with the darbee just put between the amp and the projector
post #19 of 21 Old 03-04-2013, 03:00 AM
Quoted: 260 Post(s)
Liked: 160
Seemed to be the case for my set up anyway compared to zoomed X55s I've seen (3 now).
I use a Lumagen>HDMI splitter>Darbee>Projector.
This way I get to use the calibration controls on my TVs and projector (via the splitter) and the projector benefits from the Darbee effect (since I can't see any difference on my TV as it's a 40" screen from a long way back).
Having recently tried to do a quick calibration of an X55, personally I'd rate X35 plus Lumagen Mini3D plus Darbee as a better buy than an X55, in the UK you could even add an i1 Display Pro sensor and Chromapure (autocal) and still have spent less than an X55. I know that in the US the price difference between RS46 and RS48/4810 wouldn't allow this so it's a different scenario.
post #20 of 21 Old 03-04-2013, 03:37 AM - Thread Starter
michaeldip's Avatar
so where your pre amp in this Lumagen>HDMI splitter>Darbee>Projector.
post #21 of 21 Old 03-04-2013, 04:34 AM
Quoted: 260 Post(s)
Liked: 160
Completely separate since I run an older Arcam AV9 that I use the analogue inputs from my Oppo optical input from my PVR. No HDMI touches my pre amp (processor).
Jvc Dla X75r , Jvc Dla X95r
