Epson 9500UB Worth the Price? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-07-2013, 05:44 PM - Thread Starter
dogbox46's Avatar
Quoted: 23 Post(s)
Hey folks, my 3 year old Epson 6500UB is showing convergence and banding issues so I've started the search for a replacement unit.(No warranty)
I received an additional bulb when I purchased the 6500 and it's still in the box and I'd like to be able to use it on a replacement.
So I found a fellow selling his 9500UB with this description...
"Like new the amazing Epson 9500ub projector. 200000:1 contrast ratio. If you're looking for this projector then you already know how good it is. Comes with brand new extra bulb from Epson($299 Value) The current bulb has 680 hours on it.(4000 hour bulb) Comes with original box, packaging and remote control. Upgrading to a 3D projector." Also, the projector was ISF calibrated. The seller reports the unit as 2 years old without warranty.
The seller is asking $1,800 for the unit.
Seems to me that's high but I really don't know if the 9500 is that much better than the 6500. Did/does the 9500 have the same issues with the light engine as the 6500?
Is this good value or would a new 2D/3D Epson or the Panasonic 8000 be better choices?
Thanks for all your opinions.
dogbox46 is offline
post #2 of 11 Old 03-07-2013, 06:18 PM
zombie10k's Avatar
Quoted: 2802 Post(s)
Liked: 2734
That is too much $$ for an outdated model, you can easily find an Epson 5010 for that price and get the 3D as well.
zombie10k is online now
post #3 of 11 Old 03-07-2013, 06:51 PM
jnabq's Avatar
Liked: 39
Or the Benq 1070 for about $1k if you can't swing the price for the 5010. Either would be a better choice as your buying new vs a used unit, and getting 3D as zombie said.
jnabq is offline
post #4 of 11 Old 03-12-2013, 04:32 PM
inspector's Avatar
Quoted: 36 Post(s)
I have a 9500 and it's great PJ! It did get replaced with a new one within the first year because of very slight pink and green. This was only visible on a pure white sceen..the replacement is perfect in all regards.
Mine has been ISFed and has 700 hrs. on a new blub, I still have a new spare. I would only go for a 6010/20 if I had the money.
If you're really into 3-D, I guess the 5010/20 would be the way to go, but don't they have a white housing? It sure wouldn't look good in my black HT.
Mine cost $3400 back in 2010 and now it's not made anymore. Since you won't be able to see in action, I'd try to get him down in price. $1000 to $1500 would probably be a better price. If it has that pink/green, I'd ask to give it back for a refund.
Tough decisions to make and good luck with whatever you do.
...finally retired and spending time in my HT!!!
Equipment consists of: Epson 9500 UB Projector(Avical ISFd);110" 16x9 JKP Affinity Screen;Panny BD30 Player,Tosh HDA1 Player;Definitive Speakers (Center, Towers, Rears);Earthquake P12 sub;Onkyo 608 A/V Receiver;Nevo Q50 Remote;TWC-HD Cable Box;5 Bello chairs;Coaire Mini-split A/C.
inspector is offline
post #5 of 11 Old 04-04-2013, 12:09 PM
redcom1975's Avatar
That seems too much. I just bought and received a refurbished 9500ub from Epson Store for $299 few days ago. I opened the box and powered up to see how it look. The unit is awesome so far but time will tell, but anyway I still have 3 years warranty if some problem arises. When I have time I'll playing around with calibration. Besides I have an Acer H5360 720P projector that I like.
redcom1975 is offline
post #6 of 11 Old 04-05-2013, 09:09 AM
femi's Avatar
Quoted: 66 Post(s)
Liked: 51
did u say you bought a refurbished 9500ub for $299?
WOW
femi is online now
post #7 of 11 Old 04-05-2013, 11:50 AM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 140
Did you mean you bought a lamp for the 9500ub from the epson store for $299? The current price on the out of stock refurbished 9500ub is $1899 and their cheaper 8350 refurbished projector sells for $899 on their site.
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is offline
post #8 of 11 Old 04-05-2013, 02:34 PM
redcom1975's Avatar
Yes. It was $299 then. Attached's my invoice.
. DSC_0516.JPG 464k .JPG file
post #9 of 11 Old 04-05-2013, 03:15 PM
Ranger's Avatar
Goodness...what an awesome deal !
Ranger is offline
post #10 of 11 Old 04-05-2013, 04:40 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 140
Wow!! Awesome deal indeed!! I thought there was no way you could've gotten it for that price. I stand corrected. Did I say Wow? smile.gif
Mike
mbw23air is offline
post #11 of 11 Old 04-05-2013, 06:38 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
Probably an error in their system, someone entered something wrong and then fixed the price later, but they honored it.
Access HERE from this thread
coderguy is offline
Lamp Powerlite Hc 6100 Hc6500ub , Panasonic Ptae8000u Hd Projector , Epson 5010 E Powerlite Home Cinema 3d Front Projector With Wirelesshd , Acer H5360 3d Dlp Projector
