What kind of carpet/rug is best for minimizing screen reflection? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-12-2013, 08:54 PM - Thread Starter
lexlynx's Avatar
Hi, I have a Epson 6010, with a 110" screen in my somewhat small room. I am modifying the room bit-by-bit to make it more light-controlled, but putting velvet on the floor isn't exactly the most practical thing to do. Here is a pic of where I'd like it:
Is there a particular type/brand of rug or carpet that would work best? Or is anything ok so long as it's dark? I'd prefer something at least 8' by 7'...
lexlynx is offline
post #2 of 9 Old 03-12-2013, 11:19 PM
vullcan's Avatar
On a bit of a budget? I shopped around for a few rugs and was about to give in and drop $350-500 since all the quality rugs seemed to cost around that much. Shopping on overstock.com I was always hesitant to pull the trigger without being able to first see the rug in person (how black is that black?).
Happened to be in an IKEA one day and just said screw it, I didn't need a fancy rug and this one looks passable. The black is SO black and my shadow detail improved immediately. The density of the fibers leaves something to be desired (its too sparse) but on the plus side they haven't been pulled out by my vacuum cleaner and it looks just like the day I bought it. I actually got two of the largest size and sewed them together to make one huge one.
For the price I couldn't beat it, and one day when I have a dedicated theater room in a house I own I'll install dark carpet from the get-go smile.gif
As with most synthetic rugs, there is an odor (I think its the government required flame retardant) for the first few days after you unroll / unwrap it. Opening a window and just putting up with it for a few days was no big deal for me, and now it only smells if you stick your nose in the fibers.
http://www.ikea.com/us/en/catalog/products/00124152/#/30146812
lexlynx likes this.
vullcan is offline
post #3 of 9 Old 03-13-2013, 07:41 AM - Thread Starter
lexlynx's Avatar
Yeah, that looks great! I had been on IKEA.com a while back, but I didn't see that rug. And good guessingm that I'm on a bit of a budget- I guess my expertly-hidden audio cable gave it away
lexlynx is offline
post #4 of 9 Old 03-13-2013, 08:41 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
mark haflich is offline
post #5 of 9 Old 03-14-2013, 01:29 PM - Thread Starter
lexlynx's Avatar
On a related note, does anyone know of any cheap-but-effective velvet drapes I could use for the back wall, and possibly the sides?
lexlynx is offline
post #6 of 9 Old 03-14-2013, 02:37 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4146 Post(s)
Liked: 4232
Walmart has black rugs too ( on - line order only ). Amazon has black velvet curtains -
http://www.amazon.com/Maytex-Velvet-Blackout-Panel-Curtain/dp/B002E1AXV4/ref=sr_1_1?ie=UTF8&qid=1363297037&sr=8-1&keywords=velvet+curtains
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #7 of 9 Old 03-14-2013, 04:21 PM - Thread Starter
lexlynx's Avatar
I've seen a similar choice in curtains at Walmart.com: http://www.walmart.com/ip/Velvet-Blackout-Energy-Efficient-Curtain-Panel-Red/5555770 Customer reviews have indicated that the 40" width refers to the maximum width, but in its normal, billowed form, it is only about 20" across.
Is it possible to stretch curtains like this so that they are at their full 40" length? Since the lights will be off, it won't matter if they no longer hold the appealing form of normal curtains.
I think they are like these blackout drapes I have, which I do indeed stretch flat (with the help of some judiciously-applied velcro pads):
lexlynx is offline
post #8 of 9 Old 03-14-2013, 05:21 PM
timkur's Avatar
Why not?
I went to JoAnn Fabrics, bought 3 yards of black velvet, and laid it out, like a rug, underneath my screen. Works really well, and cost me ~$10.
For super-cheap curtains/draps... look into the same thing (or velveteen, it looks less ghetto), and with some well placed push-pins, you can make it look "nice".
Tim
timkur is offline
post #9 of 9 Old 03-14-2013, 06:07 PM - Thread Starter
lexlynx's Avatar
ahem...Because my home theater room is also my bedroom, and study. I just got about 12 yards of 40" velvet for $100 from syfabrics.com that I'm covering the front half of my ceiling with (but in a way that allows me to pull it to the side during the day), in addition to covering the table, center speaker, and subwoofer in the first pic. I'd have to get about 5 or 6 of those 40" wide curtains for the entire back wall which is entirely lit up, as I have posted below (the little squares on the top of the wall are pieces of duct tape from when I tried using black bedsheets on the wall, and didn't notice any difference):
Note the only light source in the room is the projected image on the wall opposite this one.
And the reason that bed post is missing is due not to dilapidation, but because unscrewing it makes my seating situation slightly less awkward.
lexlynx is offline
Epson Powerlite Pro Cinema 6010 Projector
