Help with lamp reset on Sharp XV-Z20000/21000!Anybody with a service manual? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By maina man
post #1 of 7 Old 03-18-2013, 01:29 AM - Thread Starter
maina man's Avatar
I bought a new lamp,but i can't reset the lamp timer:
1)the buttons command(enter,down,right and press on) just doesn't work:mad:
2)i entered the service menu,but no idea how to do a reset there.It is in the service manual,which i can't find on the net(for free anyway)
3)lamp reset command via RS232C-i don't have/can't find a laptop or PC with a serial port.There are USB to RS232 cables,but you need drivers,etc.
The lamp timer is down to 1%,so i have to reset it soon or risk the projector refusing to start up.Anybody with suggestions,excluding going to a service shop,repair centre,etc.
maina man is offline
post #2 of 7 Old 03-18-2013, 12:12 PM
sfm
sfm's Avatar
Quoted: 28 Post(s)
Liked: 44
instructions are in the user manual:
http://www.projectorcentral.com/pdf/projector_manual_3171.pdf
service manual not needed... resetting the lamp is done while the projector is in standby (while holding down "Enter" press "On"... not on the remote... directly on the PJ) .
I had a 20K many years ago... great projector.
sfm is offline
post #3 of 7 Old 03-19-2013, 12:06 AM - Thread Starter
maina man's Avatar
I have both the user and the service manual-the only way to reset it,apart of the command via RS232C,is to hold enter,down and right,then press on,while the timer resets.Yes,I have tried it on the projector during standby,it just doesn't seem to work.I will give it a try one more time,then probably get USB to RS232 cable.It's wont be very good for the lamp to power it up and down for short periods,while trying to reset it.
post #4 of 7 Old 03-19-2013, 05:03 PM
sfm
sfm's Avatar
Quoted: 28 Post(s)
Liked: 44
don't know where your getting the "hold enter, down and right, then press on" bit... the manual I have (still have the pdf version on my hard drive) and the one to which I referred you both state what always worked for me (changed the lamp twice while I owned it):
while in standby, press and hold "enter" then press "on" (while still holding "enter"). This always reset the lamp timer to 0H for me.
sfm is offline
post #5 of 7 Old 03-20-2013, 12:27 AM - Thread Starter
maina man's Avatar
Thanks for the advice,but that's very strange.The user manual i have in paper form,the service manual i downloaded,the leaflet in the lamp's box and another previous owner advice-it's these three buttons and on!
So you are saying to hold only ''enter'' and to press ''on'' once.I will try it after one last attempt today.
post #6 of 7 Old 03-20-2013, 12:31 AM - Thread Starter
maina man's Avatar
Success!Holding down the three buttons and pressing ''on'' just once,instead of holding it down like i did before,did the trick.
PanosVog likes this.
post #7 of 7 Old Today, 01:43 AM
PanosVog's Avatar
To confirm maina man statement, I had the exact same problem with my Sharp XV-Z21000, I could not reset the lamp hours, and I have the same problem with Sharp XV-Z10000, I own them both. I tried 2-3 times to reset the lamp hours on the 21000 mounted on the ceiling, with exact the same way, holding down the enter, down arrow, right arrow, and then press on, with no luck.
Yesterday I tried again, but this time I had the projector uninstalled from the ceiling, and standing on his feet, because I will move it from my living room to my bedroom. The first time I tried the way sfm suggested, holding down the enter button and then press on, with no luck. I turned off the projector, let it cool down, and tried again after a few hours, but this time I tried the way maina man suggested, holding enter, right arrow, down arrow, and then press on, only once, not holding it down. Finally, success!
PanosVog is online now
Sharp Vision Xvz 20000 Hd Dlp Front Projector
