4k Simulation Tech for Sitting Close - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-22-2013, 03:08 PM - Thread Starter
n8dgr84's Avatar
I read that typical seating is 1.5x screen width.
I will be sitting more like 1x SW.
At this distance, I assume the image may look a bit pixelated.
Is there a better panel tech such as DLP, LCOS, or picture enhancement such as Sony SRXD, JVC eShift, Darbee etc. to reduce pixelation at this distance assuming 4k compatible screen?
n8dgr84 is offline
post #2 of 17 Old 03-22-2013, 06:37 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4132 Post(s)
Liked: 4220
You might consider the JVC 4810 with E shift if you can't afford the Sony VW 1000 ! Give Mike or myself a call.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #3 of 17 Old 03-22-2013, 09:35 PM
zombie10k's Avatar
Quoted: 3874 Post(s)
Liked: 3954
The JVC e-shift looks very good at close seating distances. I sit 1.25 from a 142" 16:9 and it definitely makes a noticeable difference when it's on.
Click on the link in my signature for a close up look at what it does to the image.
zombie10k is offline
post #4 of 17 Old 03-23-2013, 01:52 AM
timescape7's Avatar
Should be 1.5x of screen height. Not sw.
Sent from my Nexus 7 using Tapatalk 2
timescape7 is offline
post #5 of 17 Old 03-23-2013, 03:57 AM
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
I always thought it was SW
blee0120 is online now
post #6 of 17 Old 03-23-2013, 05:15 PM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
20/20 vision 55pixels per degree VA for best image quality
1920x1080
1.59:1 SW or 35Deg Horizontal approx
or
2.9:1 SH or 20Deg Vertical approx
3840 x 2160
0.69:1 SW or 70Deg Horizontal approx
or
1.23:1 SH or 40Deg Vertical approx
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is online now
post #7 of 17 Old 03-23-2013, 08:26 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4220
Ya, I always use SW ( screen width ).
post #8 of 17 Old 03-26-2013, 10:45 AM
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
1920x1080
or
3840 x 2160
or
.69:1 SW is really close. 1SW is close
post #9 of 17 Old 03-26-2013, 03:19 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
The best place to sit is behind the screen. You will never see any artifacts that way.
mark haflich is offline
post #10 of 17 Old 03-26-2013, 03:50 PM
blee0120's Avatar
Quoted: 647 Post(s)
Liked: 327
I should try that, too bad there is a wall in the way
post #11 of 17 Old 03-26-2013, 05:11 PM
Mike Garrett's Avatar
Quoted: 7076 Post(s)
Liked: 4780
1.5 viewing height from my screen means I would be viewing my 9' wide screen from 5'-7". 1.5 screen heights is pretty close even if using a 16:9 screen, but it is doable, for some people. For a 110" diagonal 16:9 screen, you would be viewing from 9'. If you are talking about a 16:9screen, then1.5 screen widths is pretty standard. If using a scope screen, then you usually are talking 2.0 to 4.0 screen heights. I view my 9' wide screen from 9', 2.4 screen heights.
mjgarrett100@gmail.com
Mike Garrett is offline
post #12 of 17 Old 03-26-2013, 07:22 PM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
3840 x 2160 supports .69SW
1920 x 1080 supports 1.59SW
For optimum image quality 20/20 etc.......sitiing closer and the image may be watchable but not optimal.
If one eye sight is better than 20/20 eg 20/15 then one needs to further away again..
Real life supports......as close you can get as long as one can focus!!! wink.gif
post #13 of 17 Old 03-27-2013, 06:53 AM
timescape7's Avatar
http://m.youtube.com/index?&desktop_uri=%2F
1.5x screen height explained. This was recommended by NHK research.
post #14 of 17 Old 03-27-2013, 06:56 AM
timescape7's Avatar
http://m.youtube.com/?reload=14&rdm=mk0win3vv#/watch?feature=relmfu&v=kLEIoidVrqA
Sent from my Nexus 7 using Tapatalk 2[/quote]
post #15 of 17 Old 03-27-2013, 07:26 PM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
That would be for 4k not 2k........?
post #16 of 17 Old 03-28-2013, 06:40 AM
timescape7's Avatar
That would be for 4k not 2k........?[/quote]
2k will be 3x picture height.
post #17 of 17 Old 03-29-2013, 02:46 PM
Highjinx's Avatar
Quoted: 643 Post(s)
Liked: 275
2k will be 3x picture height.[/quote]
Good thnaks.
These figures concur:
SW = Screen Width
SH = Screen Height
20/20 vision 55pixels per degree Visual Acuity for best image quality
1920x1080
1.59 SW or 35Deg Horizontal approx
or
2.9 SH or 20Deg Vertical approx
3840 x 2160
0.69 SW or 70Deg Horizontal approx
or
1.23 SH or 40Deg Vertical approx
Jvc Dla Rs4810 3d Home Theater Projector , Sony Vpl Vw1000es Projector
