The Blacker the Theater, The Better the Image - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 1485Likes
post #901 of 4042 Old 07-01-2014, 09:06 AM
kimg1453's Avatar
Quoted: 41 Post(s)
Liked: 90
Originally Posted by fierce_gt View Post
how about normal black carpet, and a vacuum cleaner...
Had to laugh out loud. Good one. Ha!
kimg1453 is offline
post #902 of 4042 Old 07-01-2014, 09:11 AM
R Harkness's Avatar
Quoted: 2067 Post(s)
Liked: 1770
the problem with velvet this dark is that everything that isn't this black stands out a bit. now I have to reconsider putting the velvet on my ceiling tiles. They are a black acoustic 12x12 that look good on their own but don't hold up to this material..The grid is covered in protostar which looks positively grey in comparison to the royalty 3 material.
uggg... what have I gotten myself into.. this is all SOWK's fault.
Yep. My ceiling is very dark brown felt meant to absorb light and when watching movies it is indeed exceedingly dark and absorptive. It does it's intended job of absorbing most light reflection in terms of preserving image quality, but once I surrounded everything else in black velvet, then the ceiling is what remained more visible than everything else. Which is why a while back I incorporated a black velvet curtain that rises to cover my ceiling when desired.
There is no end, until we are sucked down the black hole itself....
ellisr63 likes this.
R Harkness is offline
post #903 of 4042 Old 07-01-2014, 09:51 AM
humbug2's Avatar
Quoted: 46 Post(s)
The desk chair rolls around and is very wearing on carpets. It will not roll very well on a thickly padded carpet. While I have a hearth rug and fireplace screen, embers do get out of the fireplace on rare occasions.
Carpet tiles can be easily pulled up and replaced. I could put tiles under the desk chair then when they show wear move them under furniture for a better long term appearance. I can stock spares. They can be vacuumed the same as normal carpet.
I have 3 carpet samples on order. If none are satisfactory then regular carpet it is. I also ordered a small quantity of Protostar Hi-Tack for the screen casing and the board under the projector. I will put it on insecurely, try awhile, and either go with it or remove it.
In my less lucid moments I thought about matching the H-D Vertiglide on the windows with another on the West wall gathered where the small media cabinet is and extending the length of the wall. If you have to ask you can't afford it.
Last edited by humbug2; 07-01-2014 at 03:09 PM. Reason: Powered Vertiglide do not exist.
humbug2 is offline
post #904 of 4042 Old 07-02-2014, 03:59 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Has anyone tried using black carpet on their walls. There does seem to be some thin black carpet available but I am not sure it is as dark as velvet. Using felt on the walls might be another option. While felt is not as dark as velvet it might work for some. I would,however, suggest using velvet in the area by the screen since it is darker than felt. Rosco paint on the ceiling is another good option.
rwestley is offline
post #905 of 4042 Old 07-03-2014, 07:43 PM
zombie10k's Avatar
Quoted: 3459 Post(s)
Liked: 3547
Originally Posted by rwestley View Post
Looks great so far. I am sure that when you are finished you will have an amazing home theater. Have you considered installing LED eyeball lights. There are many now available and they put out much less heat. You might even be able to find some that you can adjust the color of the light.
I took your advice and looked for some LED replacements for these 50 watt mini-heaters. My main concern with LED's is color temp and how they project light through those diffusers. sometimes the pattern is a bit odd. I went to Lowe's, they had 2 different brands but both were similar to the photos below. I decided to give it a shot since I need to add 5 more of these eyeball lights. I have to take all the sconces off the walls to make room for the velvet curtains.
These claim to be a 50watt replacement but also claims 520 lumens which is about 100 lumens brighter than the typical 50 watt halogens I had in there before. The color temp is stated as 3K but I'm guessing a bit higher considering how 'white' it looks compared to the halogens. Visually it does appear brighter, i'll have to measure the actual light output with the T10.
The LED pattern is more consistent but the reflector style halogens do have a nice looking pattern on the screen.
I think i'm going to replace the halogens with these. 50 watts a light adds up fast and it would be nice to keep the majority of the lights on without worrying about the heat they generate.
Joann Fabrics called, I have another 40 yards of royalty 3 velvet waiting. I'm hoping to hang up a few more sections this weekend and get started on swapping out the lights.
this is a fun project!
zombie10k is offline
post #906 of 4042 Old 07-03-2014, 08:23 PM
stanger89's Avatar
Quoted: 3369 Post(s)
Liked: 1824
I think halogens are closer to 2700K, so 3000K would be a bit whiter.
stanger89 is offline
post #907 of 4042 Old 07-03-2014, 10:52 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
We have been replacing all of our lights with LEDs... Our biggest savings was our Chandelier which was drawing 800 watts... We replaced the lights with LEDs and went down to 20 watts total.
Yamaha CX-A5100, JBL 8340A, 4 JBL 8320, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, .
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #908 of 4042 Old 07-04-2014, 04:07 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Zombie, Glad you decided to use the LED's Heat was the biggest issue I had with regular bulbs. LED's are improving and being able to keep on was big for me. I also think that Home Depot has some others that you might want to test. The Phillip bulbs are a little more expensive by may be worth in in your situation.
http://www.homedepot.com/p/Philips-5...3418/203532862
The project looks great. Are you using any kind of adjustable masking? That is my next project.
rwestley is offline
post #909 of 4042 Old 07-05-2014, 09:44 AM
zombie10k's Avatar
Liked: 3547
I built a set of manual masks and was going to use high capacity magnets to affix it to the screen. I have the same material Dalite uses for the Cinema Contour frames so it will match perfect. Automatic would be great but I can't get distracted now or I'll never complete this project.
I hung my 2nd 44" wide section just to the right of my screen where a large wooden bookcase is built into the wall. Very nice in appearance by itself, but it doesn't blend well sitting next to a 142" 16:9. Now it's gone!! hidden is the abyss of the black velvet.
For the side seams, I'm using gaffer tape which is holding well. Also for the top seams where rods go through, I'm using vertical stripes of black gorilla tape every 4-5 inches. This allows for a nice fold when the curtain is hung.
I'm off to pick up the rest of the 40 yards of velvet + some additional rods @ bed bath and beyond. The rods I'm using are very low profile about an inch off the wall and inexpensive. very happy it turned out to be this easy to hang this material.
I'll post some photos once I make more progress.
post #910 of 4042 Old 07-05-2014, 09:47 AM
eyekode's Avatar
Quoted: 23 Post(s)
Originally Posted by johnmi View Post
Thanks for the info. Like you said, it looks good and a reasonable price per yard also.
I bought from them too. Good price and good product.
eyekode is offline
post #911 of 4042 Old 07-12-2014, 04:45 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
What would be best for the stage... Carpet or velvet? I will be picking up some Royal Velvet Sunday from Jo Annes, but I am not sure if it will be a dust magnet facing upward from the top of the stage under the screen. If carpet... Would black car stereo carpet be black enough?
ellisr63 is offline
post #912 of 4042 Old 07-12-2014, 06:45 PM
Edgar_in_Indy's Avatar
Quoted: 70 Post(s)
Liked: 52
Yeah, I don't think velvet would be a great idea for any area that you may want to vacuum from time to time.
__________________________________________________ ___________________________
My home theater gallery Epson 5010 Projector, 133" Cinemascope Screen, Klipsch RF-7, Tuba HT
Edgar_in_Indy is offline
post #913 of 4042 Old 07-12-2014, 07:39 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Would the carpet they use in car stereo shops be good... It appears to be the same as the stuff they put on the outside of Pro speakers.
ellisr63 is offline
post #914 of 4042 Old 07-12-2014, 09:31 PM
R Harkness's Avatar
Liked: 1770
I"m not sure what your room design looks like, but I used black Fidelio velvet for a sort of "stage" in my set up.
I covered boards in black velvet, which are placed under my screen and extend about 2 (or 3?) feet. It acts as a sort of stage area upon which my L/C/R speakers are placed.
As for vacuuming, it's been no problem at all with the vacuum put on a "light" mode. 4 years and it looks as good as new each time I vacuum it (about once every couple months or so).
Black carpet may be more practical in your situation, I don't know. I chose the black velvet because no carpet I could find would go pitch black under the screen like the velvet.
FWIW....
post #915 of 4042 Old 07-12-2014, 10:20 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
FWIW....
This is what my stage looks like...
The ceiling and walls are flat black with a dark carpet.
ellisr63 is offline
post #916 of 4042 Old 07-12-2014, 10:40 PM
R Harkness's Avatar
Liked: 1770
ellisr63,
Personally I'd do that stage in black velvet. It's not like people will be walking on it.
But, that's me.
ellisr63 and cardoski like this.
post #917 of 4042 Old 07-12-2014, 10:44 PM
R Harkness's Avatar
Liked: 1770
I have to say that having "gone black" quite a while ago, it's almost torturous to see many pictures of HT designs with bright ceilings and/or carpet/floors/walls. I don't care how nice the design looks, how beautiful the woodwork, how expensive or inexpensive the room, if the decor in a projection set up is something that clearly fights the actual use of the room, that is will clearly produce significant wash-out of the screen image, it just "looks wrong" to me.
I was looking at one thread recently in which the person had done quite a nice looking HT room and had even gone to the lengths of painting all the walls black. It got tons of praise...but all I could notice was the BRIGHT WHITE CEILING RIGHT OVER THE SCREEN! So I want to praise it but instead all I can intone internally is:..the ceiling...don't you understand??!!...the ceiling! Why? Why?"
Tedd and cardoski like this.
post #918 of 4042 Old 07-12-2014, 11:00 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
ellisr63,
But, that's me.
Thanks, I will do it in the Royalty velvet from Jo Anns Sunday then... I will get some thin foam pad so it looks good when I roll it over the edge and staple it.
ellisr63 is offline
post #919 of 4042 Old 07-13-2014, 08:00 AM
DavidHir's Avatar
Quoted: 1943 Post(s)
Liked: 1582
Agreed, I see images of some really nice home theaters, but it seems cosmetics are prioritized above performance - where as my take is the opposite.
DavidHir is offline
post #920 of 4042 Old 07-13-2014, 08:05 AM
R Harkness's Avatar
Liked: 1770
The thing is I think most people think it's a sort of either/or thing - if you want to do a room suitable for projection, you have to compromise on the aesthetics. I disagree as there are countless aesthetic choices that are beautiful but which make sense given the function of a room using projection.
post #921 of 4042 Old 07-13-2014, 08:17 AM
zombie10k's Avatar
Liked: 3547
please post some photos when your done, I'm working on a similar setup in front of my screen.
I'm about 1/2 way done covering the wall where my screen is located. the before / after is dramatic, it looks amazing. The Royalty 3 velvet is great to work with, it's heavy enough to create a ripple like a typical hanging curtain.
When I'm done the walls, I've decided to take down all 50+ black tiles and cover them in the velvet. My 142" 16:9 is just inches from the ceiling and can broadcast some serious light. I want to make sure it has no chance of reflecting back to the screen.
I'm loving the black carpet I just had installed, it looks classy in my room. it's definitely not as dark as the Royalty 3 but a great looking black shade overall.
post #922 of 4042 Old 07-13-2014, 09:29 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
The more black I get in the room... The harder it is to take a picture with my cell phone.
ellisr63 is offline
post #923 of 4042 Old 07-13-2014, 09:43 AM
DavidHir's Avatar
Liked: 1582
That's the issue I run into mine. lol
DavidHir is offline
post #924 of 4042 Old 07-13-2014, 11:40 AM
zombie10k's Avatar
Liked: 3547
what material are you using? I've seen some folks suggest the foam exercise blocks. I want a rounded 'stage' in front of the screen.
I was going to use those blocks and stack them a few times to give it some height, cut a nice curve in the front and cover it in the velvet.
post #925 of 4042 Old 07-13-2014, 11:57 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
I am using Jo Annes Royalty black velvet. I am thinking of also using it on my soffits which are bass traps too.
ellisr63 is offline
post #926 of 4042 Old 07-13-2014, 12:01 PM
zombie10k's Avatar
Liked: 3547
So am I, I bought a ton of it. I was referring to the material to build the stage/platform.
I like the idea of the exercise blocks, seems easy enough to work with.
post #927 of 4042 Old 07-13-2014, 12:35 PM
john2910's Avatar
Quoted: 109 Post(s)
Liked: 41
Hello there,
I use thin black carpet on my walls and i love it its pure black..
I have a black painted ceiling to(i can never sell my house again hahahahah)..
Its hard to take a picture with my cellphone..
Best regards
john2910 is offline
post #928 of 4042 Old 07-13-2014, 01:02 PM
cardoski's Avatar
Quoted: 1441 Post(s)
Liked: 1500
My room, completely covered in velvet disappears. There would be no point to having any aesthetics because there is no room. I mean there is no beginning or end, it is just a void. Decorating would only be a distraction, well at least in the viewing area, I have posters and such in the equipment area. I do sort of chuckle when see super hi end theaters that have light colored ceilings.
ellisr63 and DavidHir like this.
It's always in the last place you look.
cardoski is offline
post #929 of 4042 Old 07-13-2014, 01:22 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
We built the frame out of 2x4s, the top out of 5/8" OSB, and the front curved area out of 1/8" Masonite board.
ellisr63 is offline
post #930 of 4042 Old 07-13-2014, 01:24 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Are you using the velvet for acoustic panels too? Our soffits are open frame, and we are filling them with Denim insulation. Will the velvet be ok... Or do I need something more porous?
ellisr63 is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Mitsubishi , Panasonic Blu Ray Disc Player Dmp Bd30k
